Question about Whirlpool Gold Series GI15NDXT 15" Automatic Ice Maker with 25 Lbs. Storage Capacity, 50 Lbs Daily P...
My icemaker makes large hunk of ice
But it wont let the ice slide down to be cut on the wire to be dumped.
Check to see if the sensore bracket on the bottom of the freeze plate is conected. mine came loose so I turned the machine upside down and used JB weld To reconect the bracket and it has run great for the last two years. PS besure to let the machine stand upright for 24 hrs before you plug it back in
Bill L
Posted on Aug 16, 2008
    Genius:
  • 1,122 Answers
IF YOU REMOVE THE FRONT COVER OF THE ICE MAKER THERE ID A SCREW TO ADJUST THE SIZE OF THE ICE CUBES TURN IT DOWN AND YOU WILL GET SMALLER ICE CUBES ALSO SOME MODELS HAVE A OUTSIDE KNOB TO ADJUST SIZE,LET ME KNOW-MIKE
Posted on Jun 17, 2008
  • MIKE major Jun 17, 2008
    FIRST OFF MR INAPPROPRIATE THERE IS NO WIRE IN THE ICE MAKER,IT HAS A DEFROST HEATER UNDER THE ICE TRAY THAT HEATS UP AND THEN LETS THE ICE SLIDE OUT.I ASKED YOU NICELY TO LET ME KNOW SO I COULD HELP MORE BUT INSTEAD YOU LEAVE ME AN INAPPROPRIATE RATING,BUT THAT'S OK,IN LIFE WHAT GOES AROUND COMES AROUND,HAVE A NICE DAY-MIKE
  • MIKE major Jun 18, 2008
    HEY DUDE,WHY DIDNT YOU SAY IT WAS A FREE STANDING ICE MAKER? YOU MADE IT SOUND LIKE A REFRIGERATOR ICEMAKER!!!!! YOU NEED TO CHECK THE WIRE GRID CUTTER WITH A OMS METER,IF YOU DON'T GET ANY READING REPLACE.IF IT GETS A GOOD READING THEN YOU HAVE TO REPLACE THE WHOLE GRID ASSEMBLY
Will transformer cause icemaker not to cut icee
I have questions for you, does the cutting grid have voltage, is so how much? Check the cutting grid for a broken wire also as a broken wire on the cutting grid will cause the same problem. Good Luck
Aug 22, 2014 | GE Monogram ZDIS15CWW High Production,...
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Its not producing ice anymore.
Sep 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice cubes form a mass that do not dispense
Sep 11, 2009 | Kenmore Refrigerators
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Why is the ice maker not droping ice / Mod. ET1FTTXKQ00 / Type C21TFA01 Whirlpool 08-01
Take a 4 inch piece of 14 gauge insulated wire and strip 1 inch of insulation off each end. Bend the wire into a U shape.Remove the plastic cover from the front of the icemaker. Insert the bare ends into the terminals marked T and H on the face of the icemaker. The wheel should move and dispense the ice into the bucket. If it does not move and drop the ice replace the icemaker.
Aug 30, 2009 | Whirlpool Refrigerators
My icemaker is making huge chunks of ice in bin
You will need to replace the termination thermostat. What sounds like is happening is. Every 8 to 10 hr. your freezer goes into defrost for a set period of time. There is a termination thermostat that senses the temp at you evaporator coil in you freezer. When you heaters come on they defrost the ice from your coil. once the termination thermostat senses the temp has gotten to a preset degree, it cuts the power to the heaters. This keeps the heaters from staying on the whole period and making your freezer warm. After the pre set time period the timer turns the compressor back on. What it sounds like is happening is the termination thermostat is not opening, cutting the heaters off. By not doing so, it's letting your freezer get above freezing, melting your ice some. When the timer advances into cooling again it freezes your ice together. I would say it's your water valve leaking but that would make large pieces of ice that the ice maker has trouble dumping and also sometimes a large chunk that does not look like cubs. That would also eventually freeze the inlet tube closed..
Please rate solution
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker wont make ice
Put about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water inlet valve . If the ice stays in the icemaker , replace the icemaker . Also , make sure the fill tube to icemaker is clear of ice and the coils under refrig are clean of dust , lint , etc..
Aug 12, 2009 | Roper Refrigerators
Open Questions:
See all Whirlpool Gold Series GI15NDXT 15" Automatic Ice Questions
Whirlpool Gold Series GI15NDXT 15" Automatic Ice Maker with 25 Lbs. Storage Capacity, 50 Lbs Daily P... Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
