Question about Samsung SCX 4200 All-In-One Laser Printer
Hello everyone, I keep getting paper jams in my Samsung scx4200 keeps. At the beginning I had to keep the back tray open and printed paper got out that way. But that is not working anymore either. I am desperate, please help. Thanks so much in advance.
  • 2,427 Answers
Hi,, ok your problem is the mechanism that lifts the paper out of the tray, Remove the tray and slide the printer slightly off the table where you can look under it at the mechanism..
now make sure its tight ... rock it a bit ,, if it rocks ,, there are 2 screws holding it in place Tighten them..
use a napkin (DRY) and clean the threader wheels..
IF all appears fine then your problem is very simple.. Moisture!!! ,, Ok what happens is moisture gets inbetween the paper causing them to bunch up and stick..
here is what to do,,
1.) store the paper in a dry warm place ( normally a light cupboard) but if your a home user a draw wrapped with other paper,, to keep it dry and warm as possible.. Leave it in the package it came in..
2.) before loading the paper,, fan them out on both sides and blow inbetween them to loosen them up...
most of the paper jams are caused by cold paper ..
Posted on Nov 12, 2010
Hp 2515 no paper on tray but indicating fake paper jam
May i know the printer model # / name ( full ) to assist you better. ?
Mar 24, 2014 | HP Officejet Pro L7680 All-In-One Printer
My paper keeps jaming
paper keeps jaming - Brother MFC-3240C All-In-One InkJet Printer
Nov 09, 2010 | Brother MFC-3240C All-In-One InkJet...
What does e073 0003 error mean on canon 1180.
E, 0, 7
FINE Cartridge is not installed in the correct position
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
Techbelkin please rate me
Nov 03, 2010 | Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Summary
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
The paper jamed now I get a 41.3 error message and can't solve
The error 41.3 is unexpected paper length and was caused by the printer pulling more than one sheet. Now the problem is clearing the paper jam in the paper tray. The only way I have found to get it clear is to put the printer on its back with the paper tray facing straight up. Now push the tray in just a little bit if you can and try to shake it to get the paper to shift to the other end. After a minute or two put the printer back down and try to open the tray. If you can then just put the paper back where it goes in the tray. Be sure the pickup roller is clean, no paper dust and such. then try printing again. If you still can't get the tray out then you will have to dis-assembly the printer to get it clearer. Let me know if this gets you going.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 19, 2009 | HP LaserJet 4 plus Printer
HP 4200 printer paper jam. No paper is jammed
OK, if the printer says jam but no paper inside and prints after you open and close the cover the paper likely never made it out of the tray. Or the machine thinks the page never made it out of the machine.
As far as input check your rollers 1 in the tray and the pick up roller in the machine if you don't have alot of pages on the machine these likely OK.
Next (and this I have found often) check the paper back stop in the tray. This is the guide to set the length of paper. If it is set just a little long the roller cannot catch the edge of the paper. Sometimes the teeth the guide sets in are broken or worn.
The output would be the sensor in the fuser replace fuser.
Hope this helps
Feb 19, 2009 | HP LaserJet 4200 Printer
Paper jam in tray 1
Hi glenpcr,
I had the same problem and solved it.
At my printer it was a problem of the MP-tray (multi purpose tray).
There are two hinges which keep the open MP-tray in a horizontal position. One of this hinges was broken and I just received it.
Just try it.
regards,
Stephan
Feb 10, 2009 | Samsung CLP-510 Laser Printer
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
53 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
