Question about Refrigerators
Do the samsung twin cooling fridge freezer does it need gas??
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Hi . all fridge freezers need gas ? .. depends what wrong with yours .. checck out
samsung fridge freezer problems on youtube
some videos ....
and
Posted on Nov 14, 2010
How to fix the rs 2555 refrigerator is not cooling, but the freezer is fine
1) Twin Cooling System
·The refrigerator and the freezer have two
evaporators.
Given this independent system, the
freezer and the refrigerator are cooled individually as
required and are, therefore, more efficient. Food
odor from the refrigerator does not affect food in the
freezer due to separate air flow circulation.
The Evaporator unit for the fridge may need servicing.
if you handy with tools you can fix it yourself the manual link is below
http://vdmeulen.net/handleiding/Samsung%20SR-S24%20FTBS/samsung%20rs2555sl%20service%20manual.pdf
Aug 16, 2014 | Refrigerators
I have samsung french door twin cooling the refigerator is not cold enough,frezer working fine,ice maker working fine,
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Aug 19, 2011 | Refrigerators
Not Cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
gfad
Jun 13, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Freezer working on gas but not fridge compartment.
Check to see if you have the right gas pressure at the refer
Jan 26, 2009 | Dometic RM2652 Refrigerator
Samsung rs21dcns fridge freezer Ice build up in fridge - twin cooling fan not working Fridge temp not acheivable
very common issue on samsung r21 models , repair kits available and plenty of help videos out now
have a look at this youtube video and the chanel it belongs to
Nov 10, 2008 | Samsung Refrigerators
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
