Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Trying to play a vcr tape and we are supposed to select the input, and we don,t know what the correct input is.
  • Philips Master
  • 6,993 Answers
Check the back of the VCR, you will see Video, Audio Out and Video, Audio In.
Connect a RCA wire from output of the VCR to Input of your TV.
The RCA comprises of Yellow, white and red. The yellow wire is for visual (display or video) and the red and white part is for audio (sound). Find an image of RCA wire below:
Connect one end of the yellow wire to "video out" of the VCR and the other end to "Video In" at the back of your TV. This is responsible for display.
Also, connect one end of the Red/white wire to "Audio Out" of your VCR and the other end/part to "Audio In" at the back of your TV.
Make sure the VCR is turned on, then press Source/AV on your TV remove and the VCR will display on the TV. Also make sure a VCR Tape is already playing in the VCR so that you can get a signal.
Good luck.
Posted on Nov 10, 2010
My vcr tapes play too fast
If I remember correctly, VCR players had three speed settings. SP-short play, LP-Long play, and SLP- Super long play. The vcr is supposed to be able to tell what speed the tape was recorded at, thus playing it back at the correct speed. If your unit has lost the ability to sense the speed the tape was recorded then you will have to set the speed manually, if possible. Other than that I would have to say it's time to get a new vcr.
Feb 20, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I can not accrss either a VCR tape or a DVD.
Is the TV saying no signal? Are you on the correct input? Is it SCART or composite? Are you getting sound? If no sound then it might be on the wrong input on the TV
Dec 14, 2011 | Philips Televison & Video
Will a Funai 31B750 Nicam VCR play analogue tapes on a Samsung UE40D5520 TV and will it record from this TV?
Yes of course if the TV has composite video inputs ( Yellow/White/Red ) sockets at the back. Just connect a 3 RCA to 3 RCA cable from your Funai video out to the TV's AV input. Make sure you don't get the colors mixed up. Select the corresponding AV input on the TV and one should get the VCR image provided the head of the VCR is clean. If not you won't get any picture nor sound.
Sep 26, 2011 | Televison & Video
How do i record on the vcr
do you hve anything going into either the cable in or the rca (red white yellow)?
if you do then make sure the correct input is selected
Jan 19, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I insert a tape to play and I can tell from the front panel that it is playing, but does not show up on the screen. Everything seems to be working fine, I just don't know why the tape does not show on the...
Make sure your cables are on the out jacks of the vcr to the in jacks on the tv. Also, you will have to make sure that you have selected the proper external input on your tv to where your vcr is hooked up. Example: If it is hooked up to video one on your tv then you have to select video one on the tv when watching your vcr. I hope this helped.....
Nov 08, 2009 | Samsung Televison & Video
VCR WON'T RECORD
you may have the outputs hooked up correctly however you may need to set the inputs to the selected type of cable you are using. S video 1 cable or video input witch is an rca adapter yellow in color. you will find these setting in the "setup section" on the remote set up button will get you there and then input or source.
Dec 04, 2008 | Philips Magnavox MWR10D6 DVD Recorder
VCR won't record
Check to make sure the cables on the VCR are hooked up correctly. If the in and out are reversed, this might cause your problem. Hopefully it's as simple as that. if not leave a comment and I'll get back to you.
Oct 03, 2008 | Quasar VHQ400 VHS VCR
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
How to record from a VCR onto a canon mv530i
OK get a set of cord that can be used, on the back of most VCR's there is RCA Sockets for Video & Audio out... generally Red & White & Yellow these go to the corresponding inputs on the camera's Video & Audio inputs, OR Correct adapter. The camera must have the correct A/V INPUT selected. Then start the VCR to "Play" the tape, and set the Camera to "Record" this will/should then record the output from the VCR to the memory in the Camera.
Aug 21, 2007 | Canon MV530i Mini DV Digital Camcorder
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
461 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
