Question about Canon PowerShot A75 Digital Camera
Sticky lens cover doesn't open and close smoothly
  • 4 Answers
This may cause you camera to break, be very careful
Get a damp wash cloth and slowly stick the corner of the wash cloth in the lens.
Try to but a needle in the lens cap slowly pry it open.
Hope it solves your problem :D
Posted on Nov 10, 2010
Spilled soda on my camera sticky lens
Buy lens cleaner, to wipe off what you can, but in truth the lens should be dis-mantled to clean it properly not to mention the rest of the camera.
Mar 29, 2012 | Sony Cyber-Shot DSC-H70 Digital Camera
Sticky shutter inside the lens
Not sure that you really mean shutter, or the automatic lens cover. See the description below for a stuck shutter. If that's not what you meant, then see this instead. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 05, 2011 | Olympus Cameras
Foldable lens cover doesn' t open and closed fully... Thanks.
It's usually merely a grain of sand or dust jamming it. But it's also usually easy to fix. This link outlines repair techniques for a stuck automatic lens cover. Recommend trying the less "risky" ones first before considering the end of the lens.
Dec 27, 2010 | Canon PowerShot A610 Digital Camera
Doesn,t read and start disc
Clean the lens with a soft cotton cloth but be careful not to touch it with bare hands. Make sure the lens is not soiled with dust.
Note: if it says 'NO DISC" immediately after closing the tray, check capstan motor if spins smoothly. It is the one spinning the disc. Open the unit's casing to have a view of the disc when playing. If it doesn't spin, replace capstan motor.
Oct 08, 2009 | Toshiba Televison & Video
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Lens cover error
Hi
Your camera does have a small door or lens cover that slides up and down to cover the lens when the camera is turned off. Is it not closed and now the camera will not work at all?
You can try tapping the camera in your hand, but not on a table... though I don't think it will accomplish much. Most likely there is dirt or a sticky liquid that has caused the cover to jam, so you will need to open the camera and clean it out with alcohol if it's sticky.
You can try compressed air, but not extremely powerful air.. be gentle; digital cameras are very advanced pieces of technology, just remember what you're holding in that little square in your hand, its an amazing piece of equipment!
My best advice, if you're comfortable with it, is to open the camera and clean it and see if something is broken. If you don't want to do it yourself (and I don't know what country you live in...) but we can do it for you for $35 total if you are in the US, slightly more for shipping costs if you are outside the US.
Let me know if you have any other questions and please don't rate me low and move on... ask for more help so that I may earn a higher rating from you. =)
Thanks, Darntoothysam com
Thomas
Oct 13, 2008 | Cameras
Lens cover stays open
hello lmsmith, the reason the lens protection shutter does not close, is that it is either jammed by sand, dirt or sticky substance. it is going to need cleaning by a qualified technician.
Jun 04, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera lens cover is sticky
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jul 27, 2007 | Casio Exilim EX-Z55 Digital Camera
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Canon PowerShot A75 Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
