Question about Toshiba 40H80 40" Rear Projection Television
Toshiba 40H80 --- When the TV is off, there is red light that is turned on which is on top of where green light is. UNderneath where the green light is, there is a red light that keeps flashing even when the TV is off. Then when we turn on the TV - The green light goes on for 2 minutes blinking and then the green light goes out and the bottom red light keeps blinking. If you try again - Same thing happens except the green light blinks for even longer than 2 minutes but never goes steady and turns off. No Sound and no picture ever comes on. Tried pulling the plug and re-plugging in.
  • Kevin LaCarrubba Nov 10, 2010
    Given prices of 40" LCD or LED TV's these days, would you say it is cost prohibitive to try to repair the set?
  • 4,889 Answers
The reason why its not powering on is due to a protection fault. That is the reason why the green light comes on, blinks for a while and is turning off. We should perform component level testing on the components, to locate the faulty ones and replace them. This gonna need skills in 1) Using a multimeter 2)Using a soldering gun(to remove the faulty components and replace them with new ones). I do have a service manual for this model and I will guide you to do this yourself if you have worked on electronics circuits before. Note that the set holds residual voltages that can cause permanent disability due to electrocution if not handled carefully. If you want to continue let me know. Otherwise get me your zipcode and I will get you a list of techs in your area.
Posted on Nov 10, 2010
  • eagle338
    eagle338 Nov 10, 2010
    Considering the fact that this repair is gonna cost you about 200-300$, it might be a good idea to get a new set. This set is rather old anyway right(10-15 years?).
Toshiba 40h80 red light blinking
I would suspect the problem is in the convergence circuit---only one simple way to know---get at and un-solder all 18 pins on both the STK chips it uses.
Once they are free try to turn set on--if it comes on one of the chips is bad and both will have to be replaced.
Dec 05, 2012 | Toshiba 40H80 40" Rear Projection...
My tv toshiba 40h80 the red and yellow line up but the blue doint it moves up down but i caint get them to line up with the reds and yellow.
Ur convergence is dead.U must know how to solders?Must replaced 2 STK convergence ICS and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 19, 2010 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 TV - looking for original remote.
You can buy them at any of these sites:
http://www.toshiba.newremotecontrol.com/catalog_item.php?catnum=23306458
http://www.remotes.com/store/toshiba/40h80.html
or ebay
Aug 17, 2009 | Televison & Video
Toshiba 40pw03b stuck on standby
the red light comes on and off tv dont work
Jul 28, 2008 | Toshiba 40H80 40" Rear Projection...
Toshiba 40pw8db with colored lines horizontally
there are some boards in the tv that plug in (push down) have the power off and unplugged have a look around, and see if any boards have come loose, stay away from any thick red wires (EHT) DO NOT PULL At the Gray Rubber Caps that go to each gun (tube) RED GREEN Blue, this can carry a heavey charge even if the tv is off and has been for days, regards mark
Mar 15, 2008 | Toshiba 40H80 40" Rear Projection...
Tv has died!!!!
Sarahp_21,
Check the 2amp pico fuse at F470 and if open replace it and Q404 2sc5570 the HOT (horizontal output transistor).. If not open check HOT for short EtoB and inspect the solder connections of Q801 in the SMPS.
If any of that sounds greek you need to take it to a shop or find someone handy with a meter and a soldering gun that can do the work for you.
If I can help any further just let me know.
Bill
premtech@willapabay.org
Dec 21, 2007 | Toshiba 40H80 40" Rear Projection...
TOSHIBA 40H80 projection TV - no sound / no picture
it could be, that would be the first thing i would do to rule out I would first check for loose connections on the board.
Dec 06, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba 40h80 picture problem
replace c449 and also the damper diode
Nov 19, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba Rearprojector TV
you didnt say if the set was working?? if its not I would first try the power regulator IC in the power supply It will start with an STR#####.. This goes bad alot in these sets. Good luck
Apr 17, 2006 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
