Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
My mitsubishi 55" will not turn on... when I press
    Genius:
  • 1,112 Answers
Hi:
The most common failure for this model is the deflection board assembly or commonly known as a Large Signal board. The unit is going into shutdown, mode because no high voltage. Unless you are strongly electronically inclined I suggest you try to replace the deflection board.
Posted on Nov 10, 2010
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
I push the power button the power light come on i hear a click the the light goes back off what is wrong with my tv
Do the self check this model has:
Turn set on and when green power light goes out: press and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and then release both buttons.
The power light will blink a two digit error code: most common one is 2 blinks, pause and 2 blinks---it will repeat the error code at least 5 times.
Let me know what you find--2,2 is the most common and may be a do it yourself repair.
I am here to help you--if this information is helpful rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi Medallion 72 inches Tv support does not turn on, when we touch the power button the green lights turns on and there is a clicking sound and the green light goes out
Please try the self check feature this set has:
when power light comes on and then goes off: On the front of the set press and hold both Menu and Input (or device) buttons both for at least 5 seconds and then release both.
The power light should blink a two digit error code--like--2 blinks, a pause, 2 blinks..........it will repeat the error code several times.
Let me know what you find and I will tell you what the error may mean.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi 55" rear projection TV, wouldn't turn off
um . that model doesn't have a reset button . but if no lights on front of the set even blink when you press the power button on the front or on the remote .then suspect front panel buttons ,with that model.
Sep 29, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Green flash of doom!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} . (LED does not stop blinking after plug in) On the DM PCB (part # 934C116001) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them regardless if they look good or check ok
Sep 01, 2009 | Mitsubishi WS-55513 55" Rear Projection...
TV WON'T TURN ON
You might have a bad power supply or convergence circuit, I also suggest you to check for fluid spill on the circuit board. if the convergence is defective one of the 5A picofues on the power supply is open. Hope this help you.
Jun 20, 2008 | Mitsubishi WS-55311 55" Rear Projection...
Blinking green light
Please verify Model # and mo / yr built off back of set...
critical for correct solution........T.
Dec 02, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
