Question about Microwave Ovens
Sharp microwave door will not shut and the oven light stays on continuously.
Sounds like a broken latch. You will need to unplug it or unscrew the light to turn it off.
Posted on Nov 10, 2010
  • 144 Answers
The door has a switch , probably two, that engage and disengage when opening or closing. ( a failsafe so it switches off ) when you open the door, this is the problem also like a fridge the light should go off when door is shut, it may just be stuck but Dont mess with it , clean it if its got food stuff , a mild detergent round door etc , otherwise just change microwave ,
pete
3 Suggested Answers
  • 52 Answers
SOURCE: Microwave oven stays on continuously and won't heat food.
Spacemakers have had problems with there magnatron, part is around 170.00. Depending on the year it is covered under a warranty however the labor is not. I have replaced 3 spacesavers for people already due to this issue. Unit runs but will not heat.
Posted on Jan 11, 2009
jharvey572
  • 447 Answers
SOURCE: i have a sharp over
take it toy your local repair shop and have the door latch replaced
Posted on Sep 07, 2011
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Troubleshooting- microwave turntable and fan run constantly when door closed, door switches test good, timer can be set and oven runs otherwise; need amana microwave ACM1580AS wiring diagram
I'd look for a defective relay or shorted triac on the control panel circuit board. Either could cause this problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 24, 2015 | Amana Microwave Ovens
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
Sharp combo microwave: Turntable wont stop unless I leave the door ajar. Light stays on too while turntable is going. Everything else works fine - it just doesn't know when to shut up! :)
It's a door switch that's bad. Probably the secondary interlock switch. You need an ohm meter to verify switch not 'making' electrically. Usually the only thing that causes this switch to fail is from opening the door when the microwave is cooking, secondly, by cooking at very extended lengths of time.
Aug 28, 2013 | Sharp Microwave Ovens
When I shut my microwave door, the light staays on and the carousel starts going around. I can program my cooking time but, it will not engage and star cooking. Meanwhile, the carousel continues to go...
It's probably a bad door switch or door switch mount, probably the top one, which is the door sensing switch.
We have the actual service manual for this model and have uploaded it to our site for you here.
You can order Sharp parts from
Encompass here or from the Sears Parts Direct Web site.
Jan 15, 2011 | Sharp R930AW Microwave Oven
Sharp R-1750 Microwave
the door switches need adjusting. remove casing and adjust door switches
Jan 25, 2009 | Sharp R-1750 Microwave Oven
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Dec 18, 2007 | Sharp R-1470 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
