Question about Epson Stylus CX5800F All-In-One InkJet Printer
When I turn on my Epson 5800 printer it goes through its self tests and then all of the lights come on and I can't do anything.
  • barcircleg Nov 10, 2010
    The printer is a few years old. There is no display therefore no error messages. As I stated before after the self test all of the lights come on and none of the buttons work.
  • 2,567 Answers
If it is still covered by warranty, I recommend that you contact Epson's support center.
Otherwise, is there any error message displayed on the LCD display?
Posted on Nov 10, 2010
  • Mohamed Omran Nov 10, 2010
    I am afraid this seems to be a controller board failure. These kinds of failures are usually too expensive to repair, & in most cases non-repairable.
Error: printer error. turn off then on again. for details, see your documentation.
Hi I have a similar problem with Epson px660, it does not complete the self test after powering on then it flashes all lights with a printer error of fatal code 0x71, can you assist me kindly.
Best regards
Mar 13, 2015 | Office Equipment & Supplies
Maintenance request 0040
Maintenance request code:
The pump counter is near end of life, replace the cleaner kit ASAP.
This is what 0040 means.
May 03, 2010 | Epson Stylus Pro 9800 InkJet Printer
Every time I try to print the paper jams. All the paper has been removed, turned it off, still jamming
Found this on the Web, hope it helps you.
If you find this helpful, pls rate me.
Turn your printer off for about 10 seconds, remove the printer cable and then turn the printer back-on. Does only the Green Power Light come on solid [not blinking], as would be normal, or does the Red Error Light also come on? If only the green power light comes on, then try running your printers self-test page, directly from the printer. On most epson printers you can usually run an self-test page to determine whether a problem comes from the printer itself, or possibly from your computer system. Of course if there are actually any red error lights/leds, already showing on your printer, that would indicate that there is already a problem in your printer. Not all epson printers are always the same, but the following information applies to most models. If this self-test does not actually work on your particular printer, then you should refer to your "User's Manual/Owners Manual" for the correct procedure on how to run your printers self-test page. First unhook/unplug the printer cable from the back or side of the printer. Leave the power cord still plugged in to the wall and leave the paper loaded, as normal. Turn the printer off for 10 seconds or so, to clear out any remaining DATA or information that may still have been in the printers system, from when the computer was previously connected. Normally [on most models], you turn the printer off and then you simply reach over and hold-in on the paper button, while you reach over and turn the power button back on, as normal. Continue to hold in on the paper button for about 3 to 5 seconds, but release the power button after turning your printer on. Release the paper button once you can hear and see the printer starting to initialize and start to pull-in a piece of paper. The printer will normally print out the self-test copy, which will also have a nozzle test on it. If that test fails, or cannot actually be ran because the "Red Error Lights" come on, then you know that there is an actual problem in the printer. Depending on the combination of which lights are on SOLID, or FLASHING or OFF, will actually indicate the possible service error condition. Be sure and let us know if you recently had to remove any bad paper jams, by yanking out the paper with force, especially towards the rear of the printer, in the backwards direction. There is a common problem when you get a constant jam condition, or paper won't feed in correctly after a bad jam was removed, or even when the printer or your computer thinks that the paper has not been correctly loaded. If that is the case, then its possible that a part was unhooked/unseated or even damaged, causing a possible constant paper jam condition. If you did have a bad jam, prior to the paper feeding problem, then let us know and we can try to help you further...ON THE OTHER HAND: If everything is working correctly in the printers Paper Feed Assembly, Carriage Assembly/Cartridge Assembly and the Printhead Assembly, then the self-test copy should be printed out and correctly fed thru the printer. If the self-test page prints out correctly and the nozzle test looks ok, then that indicates that your printer thinks it is working normally [as far as the self-test goes].
Thanks and Good Luck.
Jan 25, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Printer won't print self test page and all lights flashing. Beeps 5 times when starting. Print head moves freely. What could be wrong?
tried making a copy from the pritner itself also pull theprinter upside down and see if anything comes out from the printer and then turn it on andthen try printing a test page
Jan 08, 2010 | Epson Aculaser C1100 Printer
How to self test the epson lx 300+ printer
hold down Font botton while turning on the power, then press font botton until the self test finish printing up to 6 pages...
Jun 17, 2009 | Epson LX-300 Matrix Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
May 09, 2008 | Epson TM-U220 Matrix Printer
Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot print  the print out is a symbol . same on the printest on the...
To do a Default Setting Mode to an Epson LX300+, you need to:
1. Power OFF the printer (for at least 10 seconds or more);
2. Press Tear Off button while simultaneously powering ON;
3. Release button, maintain power ON, printer will print basic/default settings.
At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
Should you want to do a printer self-test on an Epson LX300+:
Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
* Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
* While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
* Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
* Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
* Press the PAUSE button. The printer begins printing the self test.
* To stop printing temporarily, press the PAUSE button.
* To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | Epson LX-300 Matrix Printer
Epson Stylus CX5800F All-In-One InkJet Printer Logo
527 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
