Question about Neff H5642 Convection / Microwave Oven
Neff H5642NOGB not heating
Hiya
I have a Neff H5642NOGB microwave which isnt working. It does not heat the food and cuts off after 20-30 seconds. Any ideas?
I dont mind having a look inside for loose/corrupted conncections etc, i willl need some guidance.
Hope you can help
Lenhez
  • Anonymous Sep 05, 2008
    Yep same problem, runs for about 3 to 4 seconds then switches off...been told it's the inverter/magnatron....apparently it's expensive to replace......so was the microwave and at three years old I'm a little annoyed!!! Any thoughts out there please?
  • 8909 Answers
SOURCE: hi i have a neff
The magnetron is probably not working and the main board senses that.
Call an authorised repairer to fix it for you. There are no user serviceable parts in that section of the machine.
Posted on Feb 18, 2011
Is neff h5642nogb microwave oven discontinued
Discontinued? how much do you want to spend? Replacement could be less expensive, better options and more features.
Old standard may be familiar, but is it worth repair costs?
Nov 21, 2014 | Neff Microwave Ovens
I have a neff combi microwave oven and it stops working after 20 seconds and doesn't heat the food
It is one of three things, the microwave oven, "heart of the system" inverter board, "if less than 7 years old" and the keypad control board. all parts mentioned are not cheap.
Apr 16, 2012 | Microwave Ovens
The oven cuts out after counting down from 1 minute at 38 seconds and no heat
No heat is typically failed micro switch's that act as the door safety interlock. Remove the cabinet to find the tiny switches. Test them for proper action. Should show open or short depending on whether the door is open or closed.
May 14, 2011 | Neff H5642 Convection / Microwave Oven
Hi i have a neff microwave h5642nogb/02 when i switch it on to heat up food it cuts out after about 10 seconds can you please help
Feb 18, 2011 | Neff H5642 Convection / Microwave Oven
My H5640 microwave has stopped heating food and cuts out after 40 secs - is there a reset button or is it a "bin and buy another one" job
Sounds like it's time for a new oven. The magnetron tube that makes the microwaves is overheating and causing the safety thermostat to cut off power. Normally, with the cost of the replacement tube and repair labor, it's more economical to buy a new oven.
Jun 13, 2010 | Neff H5430 Convection Microwave Oven
Microwave starts as normal but cuts out after
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Mar 24, 2010 | Neff H5642 Convection / Microwave Oven
Switching off after 23 seconds without heating
Hi Paul, did you get any answer for that?? My neff is giving me same problem.. if you know what is the solution can you please e-mail me to alinaseer1@hotmail.com? Regards
Oct 31, 2009 | Neff H5470 Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Neff H5642 1000 Watt Microwave
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Apr 04, 2008 | Neff H5642 Convection / Microwave Oven
Neff H5642 Convection / Microwave Oven Logo
235 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Gerry Harvey
Gerry Harvey
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
