Question about Whirlpool 33 in. ADP6830 Free-Standing Dishwasher
Halfway through wash machine stops before drainage and shows f6
  • Whirlpool Master
  • 3,247 Answers
It might help to check if a the time of F6 appearing if the water inside the dishwasher is warm/ hot or same as the normal inlet water temperature. Also how much time is still remaining into the cycle when it stops.
Also try if the problem is also showing up in the short cycles (eg. rinse) where the water is not heated.
Posted on Nov 10, 2010
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
My asko w6222 shows F3 and stops. What is an F3 - some kind of error?
Drainage error
If F3 is flashing on the display, there is a
drainage problem. Check:
• that no objects are stuck in the drainage
hose outlet.
• that the drain pump is not blocked by foreign
objects. Clean the pump (see the
"Care and cleaning" chapter).
• that there are no kinks in the drainage
hose.
After taking the necessary action, run the
Drain program or press the Door Opening
button (key symbol) to empty the machine. If
the problem persists, contact the Customer
Care Center at
1-800-898-1879
www.askousa.com
May 30, 2008 | Asko Washing Machines
Washing machine wont complete drainage at end of wash cycle
Look under the washer tub where the drain hose comes out and attaches to the pump. Your pump impeller is either clogged or worn out. Try removing the pump and checking from there.
Jan 07, 2008 | Fisher Paykel EcoSmart GWL15
Washing machine switched off halfway through cycle, water still in machine, door will open but wont switch back on
Pump , pull apart clean or replace drop drainage hose below water tank to empty or emergency drain hose
Sep 20, 2013 | Washing Machines
Stop halfway hygiene wash 90degree
Do you have power to the unit? Does the display light up?
Nov 28, 2012 | Washing Machines
Display reads "pump blocked"
TURN OFF MACHINE AND UNPLUG THEN DO THE FOLLOWING:
Open the pump filter cover:
23294f2.png Remove and uncap drainage hose to empty detergent and then replace the cap.
Unscrew the filter and clean it, inspect the filter cavity inside the machine for matter that might be blocking it. Check the waste hose that leads out of the machine to see if there is a restriction somewere.
Oct 15, 2009 | Siemens WM14S794GB Front Load Washer
Whirlpool 33 in. ADP6830 Free-Standing Dishwasher Logo
192 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
