Question about Toto Home
The chain in my tto toilet came off of the pink flapper. how do i repair this and will it hold
  • 528 Answers
The flapper assembly alone can be replaced. Turn off the water supply to the toilet and manually lift and remove the flapper from the fill tube - if you have to cut it, that's ok. Inspect the lip the flapper sits on, looking for chips or flaws that make that surface uneven.Go to your local hardware store - they have a large variety of replacement flappers from just a couple of dollars to pricier versions. Matching flapper color is not important - design and style is! Your fill tube probably has ears on the sides - you'll want to make sure you get an eared replacement. Usually the replacement flapper will have "extra " parts cast into the rubber for multiple applications, and these can be removed with scissors or a razor knife. Follow instructions provided with the flapper and know you just saved a healthy amount of cash over a service call!
Posted on Nov 10, 2010
How to change the flapper in a toilet bowl
flapper is a rubber device that blocks and releases water and is conrolled by chain attached to the handle. Make sure you have correct new flapper. The old one removes easily. Unattach chain. REconnect new flapper, the chain and test flush.
Jul 27, 2013 | Home
Flapper closes way to quick. Have to hold handle down for complete flush. This is in an Amer. Stand. toilet. I have adjusted the chain and the flapper dail with no help. I work in the plumbing Dept. at...
Hi, American Standard uses a special large type of flapper that is designed for it. If I recall correctly,
It is black plastic with a device designed to delay the closing of the flap. It also has a special chain that is not like other flappers. Home Depot should stock these flappers. Fluidmaster makes a version of it that they sell.
Hope this helps,
Best Regards,
Mark
Dec 30, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
Toilet runs slightly, can minimally depress the handle to release a bit of water, and it will stop. How to fix?
Toilet runs continuously or doesn't flush adequately
Jiggling the handle might work for a while, but if your toilet is always running or doesn't flush adequately, you need to perform these simple fixes that usually can tame a noisy, inefficient toilet.
Check the Chain
The chain attached to the rubber flapper often becomes loose, causing incomplete flushing and/or continuous running. To fix it, remove links from the chain using needle-nosed pliers until it's tight.
Check Water Level
Improper water levels can also cause problems with your toilet. This can be fixed by adjusting the ball ****, which is located next to the overflow pipe, the open tube to the right of the handle. Adjust the ball **** so the water comes to ½ " below the overflow pipe.
Clean the Surface of the Flush Valve
A continuously running toilet can also be the result of a faulty flush valve. Because the valve is made of rubber, it can decompose or warp allowing water to escape from the tank into the bowl. Clean the sealing surface to see if this will improve the seal. If too decomposed or warped the valve may need to be replaced.
Replace the Flapper
Remove old flapper and replace with a suitable replacement. Attach the flapper to the overflow pipe inside the bowl. Then attach the lever chain from the flapper to the handle lever making sure the chain is taut.
This video will help familairaize you with the flushing mechanism and the repair:
Dec 18, 2010 | Toto Drake ADA Compliant Toilet with...
The toilet has been leaking slowly and it's trying to fill us every few mins, seems like the flapper or the seal is leaking. How do I know which one?
hold the flapper down and see if it stops leaking but it is almost positively the flapper. turn the water off, remove the old flapper, adjust the chain on the new flapper to the length of the old flapper, wipe the port area where the flapper seals to remove residue, install new flapper.
Dec 05, 2010 | Kohler K-11470-0 White Wellworth Complete...
How do i reconnect the chain to the flapper? i can't see a place to connect on the flapper and the chain isn't open on the end link.
You need a new flapper. They are about 5 dollars at home depot it will come with chain already attached.
Nov 30, 2010 | Toto Dartmouth 2pc. E/F Toilet ...
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
My champion 4 two piece comfort height elon toilet keeps running. I have to turn the shut off valve off to stop it. Help! John
take off the tank cover and you'll see "the flapper" not sealed against the hole where the water goes to the bowl, the chain that holds the flapper might be tangled or flapper is real bad,.....you'll see what the problem is,..
Jan 19, 2010 | American Standard 2002.014 - Champion4...
I have water slowly running into the bowl beteen flushes.
Have you checked the flapper at the bottom of the tank? Could be easy to repair in that case.
Other thing is that the chain has snagged and is holding it open.
Hope it helps.
Oct 22, 2009 | Crane Plumbing 3755 Toilet-To-Go Metro...
Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Toilet flapper closes too fast, can't figure out the best position to adgust the chain.
See this PDF document link below for a product from Fluidmaster which allows adjustment for the time for the flapper valve to remain open after flushing:
http://www.fluidmaster.com/pdfs/555c_instructions.pdf
Apr 28, 2009 | Dishwashers
Home Logo
372 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
