Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Hi my hoover vacuum, stopped working,does not even turn on,I accidently went over a shoelace but stopped before the shoelace went in, ,,becuase of that the belt came off,and then i put belt back on, and now it wont even turn on
5 Suggested Answers
jimtqms
SOURCE: Need help with my Hoover Savvy U8172-900 -- agitator does not spin when on
You probably jammed the roller brush and the gears on the motor stripped the teeth out of the drive belt.  You have to take the bottom and the top covers off the lower unit to replace the belt.  There is a hidden screw that keeps you from taking off the top, thus creates work for authorized Hoover repair shops.  You'll find that screw under the round red label in the center of the top of the lower section.  Peel it up and there is the screw.
Posted on Apr 16, 2008
Agent Don
  • 310 Answers
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
SOURCE: i got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Posted on Dec 28, 2008
  • 4 Answers
SOURCE: Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Posted on Apr 28, 2009
Brush stopped spinning and is sparking
Hi there Amanda, it's Jack at Dyson.
Unfortunately it sounds like the shoelace jamming the brush bar may have caused damage to the cleaner head. It's probably best if you can give our freephone Helpline a call so we can take some further details. If your machine is within our 5-year guarantee period, our experts can confirm if we're able to replace the cleaner head for you.
You can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
We'll look forward to speaking with you.
Mar 19, 2014 | Dyson DC28 Animal Bagless Upright Vacuum
Dc24 has started sparking
Hi Amanda, it's Jack at Dyson.
Mar 19, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi, I have the Hoover d14194 bagless pet vacuum..when I switched it on it worked but kept cutting out, I emptied it and cleaned the filters but now it won't even switch on.is there something I can
You could check the motor brushes, if they are worn and check for loose wire connections.
Another possibility is that there may be a break in the lead, plug it in and shake the lead, if it starts and stops you have probably found your problem with a broken lead.
Jan 01, 2013 | Vacuums
DC21 how do I change the belt
Hi Shirley,
Your Dyson's Motorhead has a belt designed to last the lifetime of the machine, which cannot be accessed by the user. The Motorhead is equipped with a safety device which shuts off the brushbar if something - for example, a shoelace or a rug fringe - jams it. If the brushbar in your Motorhead has stopped spinning, it may simply need resetting. This is simple to do - please follow the steps shown in the video below.
If you need any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US) so we can help.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Jan 12, 2012 | Hoover Vacuums
Not turning on
Most likely the switch went bad...you will need to pop that switch out and then check for power coming out of it...
heatman101
Apr 28, 2010 | Hoover U6630-900 WindTunnel Bagless...
Vacuum not working
Enter "Tempo" into the following location bar once you get to this link:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
There are a few different models including bagless and bagged versions of the Tempo of which you should be able to find any one of the pdf. adobe files.
Good luck and don't forget to rate.
Mar 27, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover only two years old an stopped working!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=564949
Hoover only two years old and it stopped working!
Posted by baby_nurse on May 02, 2008
My Hoover self propelled wind tunnel was working great until a couple of days ago when it started shutting on and off while vacuuming. I thought it was the outlet but when I plugged it into two different outlets it did the same thing. Then finally yesterday it just stopped working it won't even turn on when plugged in. I thought it was the switch but it is not. Is it the motor? Has the motor burned out? Do I need to buy a new one? Help!!
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Hoover U6616-900 WindTunnel Bagless...
Power brush SEB234/236
Hi Clyde,
Before you start, unplug the vacuum from the wall socket.
First remove all the shoe laces from the beater brush. Then make sure the belt in installed correctly. If this doesn't correct the problem, open the unit and find any fuses that it may have and replace any that are blown. That sould correct your problem. It sure seems that vacuums get hungry for more than dirt at times. lol Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vacuums
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
117 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
