Question about InFocus LP70+ Multimedia Projector
Our lp70 projector is blurry from mid screen up. I've cleaned the lens, tried a new bulb, etc. It's blurry on the InFocus screen even before connecting to a PC or Laptop, and moving the focus wheel has no affect. Any advice?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
If there is any discoloration like a blueish hue then the light tunnel has collasped. But if it is just plain ol' fuzzy there is a trick you can try. Grab the focus tube behind the focus ring tightly and put some umph into it and completely unscrew the tube from the projector. Look inside the projector with a light and if you see any of the dried glue hanging from where it screws in remove it with some needlenose pliers. Gently shake out any that has fallen inside. Now look at the tube and clean any glue from it. While you have it off look at the back side of the lens and make sure it's clean. Next screw the lens on till it is on the threads but not completely screwed on. Now put 1 hand on the rear of the projector and one on the end of the lens and push the lens into the threads until it pops and then tighten it the rest of the way in but don't over tighten. Get your palm prints off the lens and fire it up and check the focus. Try to look at a screen that has text from corner to corner and see if the text is clear in each corner. If not loosen the barrel again and keep trying to get a different position when reseating the barrel and check each time until the 4 corners of the screen are in focus. When you get it close enough for your satisfaction and have tightened the tube back up the fun part starts.... Now you need to remove the top cover and be sure to break off the 2 airplane tail-fins in the top cover on either side if a tech hasn't already done in the past (they just get in the way when putting the top back on). Once you have the top off you need to super glue the tube back to the part that it is screwed into, just a very thin bead as far around the tube as you can. This will prevent the tube from unscrewing in the future when you are using the zoom adjustment. Let it dry and good luck !!!!
Posted on Nov 11, 2010
When I power up, I get a great brilliant image; however, there is a black line slightly out of focus on the right side. It looks like key stoning but it's not. Help
Posted on Jul 16, 2011
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
I have a 6year old infocus LP70 projector. its footstopped gripping, so i opened the case and bodged a permanent pastic knob to keep at an APPRPRIATE LEVEL - BU i SEPARATED TWO WIRES ON THE LINK BETWEEN...
if you are talking about the ribbon connection on the rear of the main board, then yes I would scrap it unless you want to try and find a LP70 on E-bay to use for parts. You may or may not get a good board but if the price is under 50 bucks it may be worth the risk.
Oct 16, 2010 | InFocus LP70+ Multimedia Projector
Message reads failure to srike lamp. bulb is less
that ones are total ****... seems like lamp is broken .. my advice would be get a new projector(not LP70) other that get a new lamp...
Mar 02, 2010 | InFocus LP70+ Multimedia Projector
LP70 infocus projector is casting a shadow on the left side of the screen. It seems as if something is blocking the lens from inside? Could this be a bulb issue?
the light tunnel is collapsing and need to be replaced. you could get the part from an infocus service center and do it yourself or send it in to one and have them repair it. speaking from experience, it's a quite involved repair. you have to basically take the whole thing apart to get to it, and make adjustment to it really close to the power supply while it's on. kinda risky. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 15, 2009 | InFocus LP70+ Multimedia Projector
I have infocus lp70 model projector. i replaced the bulb and now it won't light. i put back in the old bulb and the light still wont come on...any ideas? You can tell that the projector wants to run and is...
if you don't hear a high-pitched whir, your colorwheel needs replacing. you can remove the lamp and see the colorwheel inside (colored glass wheel). if you turn it on without the lamp, the colorwheel should still spin. if it does, you have a ballast problem. if not, the colorwheel. you'd still need to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
Oct 22, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
Infocus 4805
You may have got finger prints inside the unit. Use alcohol and a paper towel or q tip/swab to clean all the glass surfaces including the bulb. You should never touch these bulbs because the oils from your hand will decrease the life of the bulb. Also make sure you put all the parts back and that they are tight. Last item is the lens may screw for focus.
Aug 29, 2009 | InFocus ScreenPlay 4805 Multimedia...
Why does picture brightness change up and down on LP70.
Hi there
Sounds like the lamp is going , but it could be the Ballast as well ( lamp's powersupply ) Rather have a certified technician look at.
Mar 22, 2008 | InFocus LP70+ Multimedia Projector
HP vp6162 projector spots on projected image
you may have touched the bulb while changing it and minute traces of skin oil are on the actual bulb, with the machine cold, try and very carefully clean the bulb
Jan 05, 2008 | HP VP6121 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
711 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
