Question about Fujitsu Siemens LifeBook® N3430 PC Notebook
Boots up normally to desktop, but cannot access any applications, and when I try, everything freezes. Cntrl + Alt + Delete doesn't even work. I hit the on/off button, restart, but the same sequence is repeated. I noticed in the task tray there is a round blue icon with an exclamation point inside. When I hover over it, it says there is a new Xbox 360 device attached, but i haven never installed anything of the sort. Not sure if this has anything to do with the issue.
  • Fujitsu Siemens Master
  • 6,993 Answers
First, run your computer in safe mode. To run safe mode, turn of your computer, turn it on and constantly press F8 on the key board until a booting option page comes up. Amongst the booting option list, you will see safe mode. Use your keyboard to select safe mode and press enter.
Wait a while for your computer to fully boot in safe mode.
Once its boots to safe mode, perform a system restore on your computer. System restore helps to back date your computer to the time when it was working perfectly.
To restore, go to; Start menu, All Programs, Accessories, System tools, system restore. Follow procedure and your computer will be restarted and that would be all.
This should help put your computer back to order.
Good luck.
Posted on Nov 10, 2010
My computer boots up but i never get into the login screen and when i press the keys on the keyboard it beeps
when the screen goes blank or gets stuck on the loading screen. simply press cntrl alt delete -----> task manager ----> file -----> new task ------> then type explorer.exe and hit ok. Once you are in, please download the microsoft hotfix for this issue at http://support.microsoft.com/kb/948790 hope this helps even a bit.
Apr 16, 2011 | Dell Dimension E310 PC Desktop
I dropped a file on my keyboard and it rotated the screen. Now everything is sideways!!!!!!
CTRL-ALT-Arrowkeys
CTRL-ALT-UpArrow will restore normal desktop
CTRL-ALT-LeftArrow or CTRL-ALT-RightArrow will rotate by 90/270
CTRL-ALT-DownArrow will rotate 180
rate if this helped you.
You must be on Desktop to do this. Close all Applications first.
Apr 12, 2011 | Logitech Wireless Access Duo Optical...
My kids e-machine pc will boot up it just comes on and sounds like the fan is working overtime and the screen is blank
Check the RAM modules and make sure they're sell seated in their slots. If that doesn't work you might try this.
Bring up task manager Ctrl+Alt+Delete and click the applications tab
Click on "New Task"
type in explorer.exe and click okay.
If it boots up run malwarebytes available here www.malwarebytes.org
run full scan and delete anything it catches.
Good luck
Oct 24, 2010 | E-Machines eMachines Desktop PC
When I turn my emachies laptop on it shows the logo then goes to a blank screen I can access setup menu but it won't boot up help it's the64bit version I beleave I've tried everything I know I think the...
Bring up task manager (Ctrl+Alt+Delete)
click applications tab
click new task
type in explorer.exe then click okay
If it boots up go to www.malwarebytes.org and download the free version. Install, update, and run a full scan.
Delete anything it finds.
Sometimes this works, sometimes it doesn't.
Good luck
Oct 05, 2010 | E-Machines eMachines Desktop PC
Computer turns on and works fine once turned off the orange button comes one - then if I cntrl alt delete the system boots? what gives?
If you just hit the button, it's probably set to suspend. You should be using the shutdown procedure, or alt-F4.
Jun 18, 2010 | Gateway Essential 500 PC Desktop
My computer says disk read error press cntrl alt then nada
In most cases, all recent versions of Windows use Ctrl+Alt+Del to bring up the Tasm Manager. You can't usually use that key combo to restart your PC.
When you did that, was any application highlighted as 'not responding?' If so, that is where you should start looking for problems.
Otherwise, try to post additional information for us here.
-a.
Mar 09, 2010 | Gateway Computers & Internet
I have no icons or task bar
you mean desktop is nor accessible.......press cntrl-alt-del. task manager will appear clk on application. clk on new task. type in c:\ and press ok.....it will open windows explorer and also shows the desktop icons and taskbar....good luck and do reply me...
Sep 30, 2009 | Computers & Internet
Starts but cant get to icons .when i turn on i get sound after my welcome come up then i get my screen picture and my curser andit stays like this forever----------- thank you ps is it a virus
Possibly have you tried to start in safe mode? Are you running Windows 7, Vista, or XP? If you can try to boot into safe mode to see if you can access your desktop from their. Once in Windows try to perform a system restore going back to the point to which you last could start your machine normally.
Sep 23, 2009 | HP Computers & Internet
My Desktop Hp Pavilion Elite m9250f goes in deep freeze
Do this it will surely resolve your issue :
1. Start > Search > Type" %temp% " > click > Temp(on the top) > Select all(use " Cntrl " + " A ") > Press " Shift " + " Delete " > Click " Yes " to the prompt.
2. Start > Search > Type" prefetch " > click " Prefetch "(on the top) > Select all(use " Cntrl " + " A ") > Press " Shift " + " Delete " > Click " Yes " to the prompt. 3. Start > Search > Type " disk " > Click " Disk Clean up " and just follow the all screen ionstruction.
This all above removes the unwanted, dump files files from the computer... which are not required by your computer. Alos scan for viruese on the computer.... visit malwarebytes.org or search on google for the same
Aug 01, 2009 | HP Pavilion Elite M9180F Desktop PC
My monitor on my computer is shoing upside down
press Ctrl-Alt-Up - right side up 0n y0ur keyb0ard.
(If that doesn’t work, try Ctrl-Shift-R)
Jan 15, 2009 | Computers & Internet
Fujitsu Siemens LifeBook® N3430 PC Notebook Logo
198 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
