Question about Panasonic NN-H965 Microwave Oven
Food left in the oven has left a smell even after thorough cleaning.what action should i take
Have you tried putting a microwaveable bowl with a mixture of water ,vinegar and some slices of lemons or oranges in your micro for about 2 minutes. It should help eliminate the bad odors and leave your microwave smelling freah and clean.
Posted on Nov 10, 2010
Food fire food overcooked and smoked in microwave bad odor and now the food is gone but the smoke odor is left. how do I get rid of the smell now. microwave itself is unharmed thank you, hank
You should be able to get a cleaner spray suitable for use in microwaves. Give the insides a good spray and a good clean, it should take it away. Make certain there is no burnt deposits anywhere.
Apr 27, 2017 | In Microwave Ovens
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Answer call sound
I think you have food splater on the plate. It is possible to remove it and carefully wipe both sides clean. Make sure it is thoroughly dry before replacing. I left mine to dry most of the day on a sunny window ledge before replacing. Have had no sparking since I did this.
Sep 25, 2013 | Microwave Ovens
How do I clean the stainless steel interior of my electrolux icon microwave
Hello - Interior cleaning after convection, mix or broil cooking:
Spatters may occur because of moisture and grease. Wash immediately after use with hot, soapy water. Rinse and polish dry. Harder to remove spatters may occur if oven is not thoroughly cleaned or if there is long time/high temperature cooking. If so, you may wish to purchase an oven cleaner pad with liquid cleaner within it-not a soap filled steel pad-for use on stainlessor porcelain surfaces. Follow manufacturer's directions carefully and be especially cautious not to get any of the liquid cleaner in the perforations on the wall or ceiling or any door surfaces. Rinse thoroughly and polish dry. After cleaning the interior thoroughly, residual grease may be removed from the interior ducts and heater by simply operating the oven on 450 F for 20 minutes without food. Ventilate the room if necessary.
Interior cleaning after microwave cooking:
Cleaning is easy because no heat is generated to the interior surfaces; therefore, there is no baking and setting of spills or spattering. To clean the interior surfaces, wipe with a soft cloth and warm water. DO NOT USE ABRASIVE OR HARSH CLEANERS OR SCOURING PADS. For heavier soil, use baking soda or a mild soap; rinse thoroughly with hot water. NEVER SPRAY OVEN CLEANERS DIRECTLY ONTO ANY PART OF THE CONVECTION MICROWAVE OVEN.
Nov 09, 2012 | Electrolux E30MO65GSS Convection Microwave...
When I put a bag of popcorn in the microwave, it started but noticed it was making a funny noise so I stopped it and opened the door and there was a little bit of smoke coming from the side wall and it...
The first thing I would do is thoroughly clean the inside. Take particular care when cleaning around the upper left side. Sometimes a buildup of food steam or spray can cause the problem you are having. Never spray anything into the microwave, in an attempt to clean it.
Hope this helps.
Jan 20, 2010 | Bosch HMB402 Microwave Oven
Sparks coming from inside of oven
This is a simple fix.
You need to remove the rack and all of the holders.
Clean the metal thoroughly where the rack mounts fit.
Replace all the rack mounts with new ones, insert the rack and you're all set.
Then be sure to keep it really clean, even if you have to remove the rack and new mounts periodically to get it really clean.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Dec 27, 2009 | GE Profile Spacemaker Over-the-Range...
I HAVE OVER HEATED SOME BOILING EGGS AND IT BUST IN SIDE THE MICROWAVE NOW ITS MAKING THIS POP AND CRACKING SOUND IS IT SAFE FOR ME TO STILL USE IT
Chances are it just needs to be cleaned thoroughly.
If there's any food debris or grease left in the oven, it can arc and pop.
Dec 06, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Little plastic ring with wheels broke in several places
the purpose of the turntable is to more evenly cook the food. it shouldnt effect the mics ability to cook, just might take a little longer to thoroughly cook food
Apr 21, 2009 | Emerson MW8625W Microwave Oven
Burning smell from microwave
This is the waveguide cover / stirrer cover.
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Please reply back with your brand and model number so we can help you in obtaining parts.
Otherwise, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Whirlpool MH6130XEB/Q Microwave Oven
Put in food and then started pooring out? smoke smells like plastic??
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Emerson Microwave Ovens
Panasonic NN-H965 Microwave Oven Logo
74 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
