Question about Amptron PM-9100A Motherboard
I have tried installing windows xp proffesional on my amptron PM-9100 motherboard pc but i keep getting files that don't copy over to my hard drive and have to retry. If i dont get a stop error mesage while the files are being copied i get it when windows is busy completing the installation. Sometimes my pc wil just switch off and reboot then i have to start again. Please help!
    Guru:
  • 254 Answers
Dear User
It seems that your problem is complicated,
1. try to check the cable of your hard drive
2. Check your hard disk
3. try another O.S. installer
4. check the heat sink if it is seated properly to the CPU.
hope it helps
thanks
Posted on Nov 10, 2010
  • 2 more comments
  • martinnr Nov 10, 2010
    ok alls gud with the connections. Thing is i aint got another os to try and also havent checkd the heat sink bt wil do 2moro
  • martinnr Nov 12, 2010
    alls gud including heat sink and connections. What do i do?
  • DeadDreamer Nov 13, 2010
    install new o.s. now and observe if the heat sink fan is stacked, mostly the caused of your problem is over heating.
  • martinnr Nov 13, 2010
    what do u mean stacked? And if the heat sink the problem then what should i do
When trying to reinstall windows xp, the process keeps failing during setup saying, "The file comct132.dll was not copied correctly. The file Setup on your hard drive is not a valid Windows XP system...
Click start/run Type: cmd
In the Command window type:
SFC /scannow Note the space between SFC and /scannow
You can copy/paste: SFC /scannow
Hit the Enter button
keep your xp cd handy in case you're asked to chuck it into your cd rom
The above should replace missing files and get you to the place where the install can proceed.
Let me know. __________________
If this doesnt work,yes hard drive needs to be replaced.internal hard drives are system specific.u need to contact dell tech support to get the right specifications
Sep 17, 2010 | Dell Dimension 4600 PC Desktop
NTDLR missing error
option 1: you have to reinstall windows
option 2: take out your harddrive. put it in to a compter with same OS and copy that compyter ntdlr file to c:\
Mar 29, 2010 | Acer Aspire 4520-5582 Notebook
Dell Dimension 9100 Blue Screen 0X00000024,00190293,86FA5B30,C000102,00000000. I tried to reinstall XP from CD and it says unable to locate Hard drive. Replaced Hard drive and tried again, same message....
Hope this help you...This is in relation to what your error code means, you'll need to check against the list.
  • Error 0x00000024 - This problem may occur if there is a conflict between Windows XP SP1 and the display adapter drivers that are currently installed.
  • Error 0x00000004 - occurs because your computer processor detected and reported an unrecoverable hardware error to Windows
  • Error 0x0000007b - occurs if your computer is infected with a boot-sector virus.
  • Error 0x80004005 - occurs because the account that is being used to access the page does not have access to the HKEY_LOCAL_MACHINE\SOFTWARE\ODBC registry key.
  • Error 0xc0000005 - occurs because of memory corruption.
  • Error 0xc0000034 - caused by a missing system file (usually Ntdll.dll in the %systemRoot%\system32 directory.
  • Error 0xc0000006 - occur if there is not enough free hard disk space on the NTFS-compressed hard disk partition when the SIS filter tries to read compressed back pointer data streams from the SIS volume.
Another common reason can be malware and spyware that penetrate to your computer registry and started destroying it... that's why it's so important you fix your registry right now!
trust this help.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
I have mainboard Amptron ZX-I945LM4,but i can't install any varsions of windows xp.i try change settings in bios,jumpers,but still same.tahnkl you for help
try to delete all of your partitions.
Then boot from cd the bootable setup disk of windows xp.
try a working setup disk.
1. if you still cant install windows xp,try to make a new partition and add all the contents of the setup disk into that partition. boot from cd and you will be able to go to setup screen.
Pm me if problem persists.
:) thank you
Aug 10, 2009 | Computers & Internet
Maximum capacity of RAM DDR2 can be installed at Amptron 945 LM4
cos actak sa3a wa adwr 3leha y5jkj ikjkadfji jl kalsfjdsa jasdshgsauy uashgdfsafahasd
Apr 08, 2009 | Amptron PM-9100A Motherboard
CANT GET WINDOWS XP PRO TO COPY FILES TO A GX280
The problem is the driver for the sata hard drive. You would need to get that from the dell site and put it on a floppy disk, then at the start of the windows install select to install that driver. I ended up just installing the rc version of windows 7 and it worked out fine.
Mar 02, 2009 | Dell Optiplex GX280 (99301) Motherboard
Can't reboot windows cd on with cd drives
If you have it available, boot to the Dell DImension Resource CD and run the diagnostics on the hard drive. From the description of you problem, you may have a failing hard drive.
Other things to check:
1. Ensure the system BIOS (F2 at boot) sees the hard drive and has the correct date and time. If the motherboard battery is failing, the time and date will not be retained when system is powered off.
2. If you are able to format the hard drive, but the windows XP installation process gives you file copy errors, then you may have a bad RAM module. If the system has 2 or more modules, take out all but 1, retry the install. If you get file copy errors again, try a different module.
3. If the Hard drive passes dieagnostics, but fails to complete a format, replace the hard drive.
Jun 01, 2008 | Dell Dimension 4600 PC Desktop
Window currupt
1- the problem is a software problem your board and processor are ok.
2- the message you saw indicates curruption in the windows files its strongly recomended that you install a new copy of windows even if the erors could be recovered..
reformating your hard disk is necessary to reinstall a new coppy of windows.
May 27, 2008 | Intel Motherboard
Wnidows XP Media Center Edition 2005 search companion
Try Scanning your Computer For Computer Viruses.
then re-install Windows XP.
Your files will remain intact, if you select to leave the hard-drive As it is ( rather Than Format it ) or setup on a different Partition.
Backup your Valuable Docs/Files First.
Windows re-installation will replace any Missing-deleted Corrupt Files.
hope This Helps you.
Mike @ compurepair.
Posted @ 14.28 PM. ( G.M.T )
Mar 03, 2008 | Microsoft Windows Xp Home Edition Sp2...
Amptron PM-9100A Motherboard Logo
51 people viewed this question
Top Amptron Computers & Internet Experts
David Payne
David Payne
Are you an Amptron Computer and Internet Expert? Answer questions, earn points and help others
