Question about Pentax Cameras
I have a pentax optio 8.1 megapixel camera. I have a 1gb scandisk. The memory is full. I want to delete some of the pictures. When I go to a picture, I push the trash can button. The response is the trash can followed by All images/sounds. I don't want to delete all the pictures, just the one I am looking at. If I click OK will all the images be deleted or just the one I am looking at? Bottom line, how do I delete one image at a time?
    Sergeant:
    Champion:
  • 333 Answers
What model is your camera? 8.1 refers to the pixel count.
Posted on Jun 17, 2008
  • boff1 Jun 17, 2008
    Looking at one of the optio manuals, if you press the trash button twice you get the option to erase all the pictures but if you press the trash button once then you can erase a single image.
Manual for optio 50l
Hi
Is this the camera memory or the SD memory card.You can opt to transfer some of your pictures to a secondary storage device probably a computer.
To delete,just scroll the picture, select on options and then delete.
Or just replace the SD card and store the full one.
Download the manual from the link below,
www.retrevo.com/support/Pentax-50-Digital-Cameras-manual/id/200dj878/t/2/
Feb 21, 2012 | Pentax Optio 50L Digital Camera
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
May 09, 2011 | Pentax Optio M30 Digital Camera
Internal Memory on Camera wont allow format
You usually have to take out the SD card, close the door and then delete images in camera in the normal way (press delete button in play mode, when confirmation dialogue appears, press delete button again, select >delete all< and press OK). Most cameras default to the memory card when one is inserted, that's why you have to take it out to delete data from the internal memory.
Hope that helps
Aug 01, 2010 | Pentax Optio M60 Digital Camera
How do i delete pictures when card is full ? help!!!!.
Hi there.
If you have copied the picture to your computer or you don't want the pictures that are on it, just use the camera's menu to format the card, that will delete all the pictures on it and it will be ready for use with the camera again.
Good luck and thanks for choosing FixYa!!
May 29, 2009 | Pentax Optio 60 Digital Camera
Camara won t delete photos
Is your memory card locked? It won't let you delete pictures if it is. Check the little switch on the side of the memory card and move it in the opposite direction and then see what happens. Good Luck.
Apr 09, 2008 | Pentax Optio S50 Digital Camera
My Pentax Optio E40 Camera
The built-in memory only has about 8 pictures or so. You have to buy a memory card to insert in the same section where the batteries are inserted.
Apr 03, 2008 | Pentax Optio E40 Digital Camera
Memory card error and deleted some saved pictures
try using another memory card. I would take the memory card back to the shop and ask for another one. I had the same problem. it was the card, not the camera.
Feb 10, 2008 | Pentax Optio S Digital Camera
Pentax otio 33lf camera suddenly won't go
Try removing the card and see if it will turn on with just the internal memory--or try different memory card if you have one.
Had a somewhat similar problem with a new 1GB card when I shut camera off while it was still saving an image. Camera would come on, take a picture all by itself and freeze up. After using a couple of other cards it magically worked on the bad card
gmcn
Oct 14, 2007 | Pentax Optio 33LF Digital Camera
Cameras Logo
50 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
