Question about GE Profile PSS26NGS Side by Side Refrigerator
Hello, I have a GE Profile model pss26ngsc, My problem is that the freezer seems to be going through a defrost cycle every day. this is causing a lot of moisture to build up in the freezer, the temp rises up to 10 degrees. The freezer then cools and the inside is cover in frost, the next day it starts over again. I removed the panel to expose the evaporator, found the seals around the panel where the heating tube is burnt. the heating tube is opaque. the is a frost covering the unit evap unit. Ques. is what is problem. Thanks
jcpark50
  • 52 Answers
SOURCE: Refrigerator not cooling, frosting up
You might try GE customer service and ask where to locate the defrost timer,since that sounds like your problem.
Posted on Nov 07, 2008
Sea Breeze
  • 4654 Answers
SOURCE: PTS25LBM GE Profile Defrost cycle messed up
The GE Profile Refrigerator has circuit boards and sensors are in the freezer that sends a signal to the circuit board to begin and end the defrost cycle. It is very possible the sensor or the circuit board are defective and will need replaced. I will help you solve this if you like. This refrigerator is complex and will take more discussion with you to complete the repair, I am here to help, let me know, Thanks, Sea Breeze
Posted on Feb 06, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Frost build up in freezer and warm temp in a GE Profile TFX22PRXB
Modern refrigerators are designed to self defrost and it is essential to the airflow to have an evaporator coil that is clear for air movement. If the rear interior panel of the freezer has frost appearing, it is most likely a defrost problem and must be corrected before temperatures can be restored to normal. Your refrigerator most likely has a defrost timer located on bottom behind grate, or inside behind control panel. Could you find the correct model number so I can help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Posted on Mar 24, 2009
  • 9 Answers
SOURCE: Fridgidaire 18 cu new defrost timer and evap fan stil freezes
Did you replace the timer with the correct one for your refrigerator? If so you may need to check the defrost thermostat out.
Posted on Apr 02, 2009
Maytag317
  • 1136 Answers
SOURCE: frost build-up freezer back wall
Hi, You will need to remove the rear panel and test the defrost heater and the bi-metal switch. The defrost heater is a very common problem with this model. You can check continuity on both the heater and bi-metal to detern which one need replaced. The bi-metal switch needs to be tested while it is could. If both of these parts prove to be ok, you will need to change the mother board.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
GE bottom freezer stopped cooling sporadically every 1-2 days then cools again with no intervention. Unit is 5 yrs old.
Put the old board back in. See what it does, from your post, sounds like it was working correctly.
Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
GE Profile refrigerator Model # PFSF6PKXCWW motor is noticeably louder
if you are talking about the motor in the freezer the ice build up could be causing the fan to beat against the ice... could be a defrost cycle problem,,,, if ice is building up on rear freezer wall you have a defrost cycle problem and the ice is forminf around fan causing fan blades to hit the ice (loud noise)
Aug 28, 2014 | Refrigerators
GE Performance Profile TFX25PPBB Freezer Defrosting
you may have a fault you may not. if the fridge is ok then the freezer is going through an automatic cycle. If the freezer is not working then the fridge will soon follow.
likely faults causing this are; thermistors; worn out compressor motor; degassed compressor/receiver (can become hot and sluggish if lost gas/lubricant mix; dirt around the fan maybe causing it to be sluggish too. make sure you unplug it before touching anything!
Jan 11, 2013 | Refrigerators
GE Profile Model PTC22MBMBRCC Counter Depth Refrigerator Noise
you have a defrost issue which need to be dealt with. the fans is hitting the ice that has formed after 5 to 10 days of not going through a proper defrost phase, you either have a bad defrost controller, def t-stat, or def heater. and can easily id the issue
Apr 16, 2012 | GE Refrigerators
The freezer on my side by side refrigate won't freeze, It continues to defrost. what the problem
Hello there: The way you described the problem you have seem like the fridge is stuck on the defrost cycle and not coming back on the freezing cycle. Try the timer first and see how it goes. Hope this help.
Oct 05, 2010 | GE Profile 23.3 Cu. Ft. Counter-Depth...
GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Feb 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge/Freezer, defrost cycle leaks water in freezer bottom
Hi, this is because the defrost drain is blocked. Follow this LINK which will take you to my tips and full instructions on clearing the blockage. If you have any additional questions please feel free to comment. Mike
Dec 27, 2009 | GE Refrigerators
Feb 05, 2009 | GE Refrigerators
Ge profile refrigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 05, 2008 | Refrigerators
GE Profile PSS26NGS Side by Side Refrigerator Logo
65 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
