Question about ASUS (90N951W1000) DVD-RW Burner
Nero 8.3.2.0 cannot communicate with Lightscribe
Dear Sirs / Madam,
I have got a problem that Nero 8.3.2.0 cannot communicate with my Asus DVD-RW model DRW-2014L1T, and I cannot use the function of Lightscribe.
I have upgrade the firmwire to a newer version from Asus site, but the problem cannot be solved.
Please kind help resolve this problem.
Thank you.
Yours truly,
Huynh Cam Hung
E-mail: wongcamhung@gmail.com
17-Jun-2008
  • 63 Answers
Please make sure you have the Lightscribe system software installed.
http://lightscribe.com/downloadsection/Windows/index.aspx?id=810
If you install it and still cannot use LightScribe, please post back.
Posted on Jun 17, 2008
My dvd rom will only play some dvds
some DVD are negative or positive recording....try to change your DVD player software to NERO 8 i think some formats your old software has none...
May 23, 2010 | HP LightScribe dvd640i (DVD640I)...
Nero 8 install
Download the Nero clean tool, clean & reboot computer. Readd Nero 8 again.
http://www.nero.com/eng/support-nero8-tools-utilities.html
May 05, 2009 | LG Electronics GSA-H42LK LightScribe 18X...
Lightscribe not detected
go to lighstrcribe.com and dowload all the software there.
there are special programs/drivers there that you need to have.
then reboot and nero should pick it up
Apr 24, 2009 | QPS Que! Fire CD-RW Burner
Hp 740e Burner
"Nero only recognizes the drive as 4x dvd+/-r..." ...
  • 4x for which media format (e.g., CD-RW, DVD-RW, DVD+RW, etc.)?
  • Have you had/used Nero during the entire year you've used this drive?
  • Is it ACTUALLY burning at a slower speed than before that you know of, or is it only the Nero indicator that you're going by?
If you've updated both the driver(s) and device firmware, there's nothing further that can be done in that department.
Both these sources (1) http://www.videohelp.com/dvdwriters?DVDnameidnew=1336&orderby=Price (2) http://cgi.ebay.com/HP-DVD-740E-R-16X-External-USB-LightScribe-DVD%B1RW-Drive_W0QQitemZ270319806919QQcmdZViewItemQQimsxZ20081219?IMSfp=TL081219114003r29076 corroborate each other with the following speed spec's for your drive:
4x DVD-RDL
6x DVD-RW
8x DVD+RW
8x DVD+RDL
16x DVD+R
16x DVD-R
24x CD-RW (up to 32x)
40x CD-R
Are you getting at-or-near these speeds with your specific applicable disk media (i.e., DVD+RW @ 8x)? In other words: Make sure you are comparing apples-to-apples.
NERO TOOLS:
Here are a couple of very helpful and comprehensive software diagnostic tools for you to download at http://www.cdspeed2000.com/download.html. They are both FREEWARE and the same tools licensed to Nero for inclusion in their software products.
Installation: Simply extract/unzip the file to any chosen directory and run the executable (*.EXE).
1. "Nero DiscSpeed". Thoroughly tests speed and performance of your optical drives(s).
Download: http://www.cdspeed2000.com/files/NeroDiscSpeed_41140.zip
- Refer to the program's Help for guidance.
- User guide also available at http://club.cdfreaks.com/showthread.php?t=192563
2. "Nero DriveSpeed". Adjust/control your drive's spin /up/down times and noise levels.
Download: http://www.cdspeed2000.com/files/NeroDriveSpeed_300.zip
HOWEVER, since you say you have Nero, you're likely to have them installed and available already. Perform an objective test using "Nero DiscSpeed" to determine the actual burn speed of you drive.
Good luck, and please post back to let me know how things work out, or if you have any further questions.
"Today's the best day of my life...and NOW you're part of it!"
Dec 21, 2008 | HP DVD 740VI 16X16 Dual Layer LightScribe...
HP DVD 1040i not recognised by software
Try using device manager to remove the drive, restart and Xp will load the drivers again. This fixed my errant drive. Hope it helps you too.
Dec 11, 2008 | HP LightScribe dvd640i (DVD640I)...
Lightscribe
Hi, the lightscribe is a great feature, its part of the nero software that should have came with the liteon dvd-rw. if you go into nero you should see a lightscribe label part, just click on that and put the disc unside down, and you should be good.
Hope this helps
John
Jul 26, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Serial number for nero 7
i downloaded the nero 8 trail version from the net but it needs a serial key to activate please send me the serial key for the activation and aslo tell me how can i crack it to make it full version
Apr 28, 2008 | LG GMA-4020B Super-Multi...
Power calibration eror
Just install Nero 6 and that will fix it!!!
Nero 7 and 8 have communication problem with DVD RW drive!!
good luck
Jan 22, 2008 | Imation 16575 2.4x DVD+RW Storage Media
Software problem
Nero needs to be uninstalled (using Nero Clean Tool) and then reinstalled after you have added a new lightscribe DVD drive. To correctly uninstall Nero go to Nero website to download Clean Tool application specific to your version of Nero. http://www.nero.com/nero7/enu/Clean_Tools.html
Sep 16, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
Lightscribe error
Update the lightscribe software. Update the burner hardware. Download the Lightscribe diagnostic software. It will locate the problem and offer to fix it. I had the same problem and the software worked perfectly. It's more than likely a software conflict.
Aug 21, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
ASUS (90N951W1000) DVD-RW Burner Logo
196 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
