Question about Whirlpool Duet GHW9150P Front Load Washer
Open washer door and the rubber smells. What should I do? Have tried clean cycle numerous times.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip about how to clean your washer
How to have a Clean Washer
heatman101
Posted on Dec 27, 2010
Hi, the machine/drum area keeps smelling of stagnant water, no matter how many times i clean it. Is there anything i can do to stop this?
Things to do make sure despencer draw is clean and the rubber door seal is clean do a maintenance cycle every year this is the hottest wash cycle with cleaning detergent. also leaving the door open after cycle will help hope this helps
Jul 10, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a he2t wash comes out smelling like mildew really tired of it please do not tell me to leave the door opened I do still smells
The trick is to clean the interior using regular detergent, baking soda, and hot water; run a complete cycle without any laundry in it. Wash the rubber boot where the door seals with same mixture at which point the interior should smell fresh and clean. Now is the time to leave the door open after use so that the remaining moisture can evaporate out to prevent mold growth. Hope this helps!
Sep 23, 2010 | Kenmore 44072 Front Load Washer
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Oct 02, 2009 | Bosch Washing Machines
Kenwood elite washer is spurting water 3 to 4 times during the agitate cycle. i do not know how to take it apart. it does not leak water at any other time.
The smell in my Kenwood Elite washer is horrible. I use bleach, I use the new TIde Washing Machine Cleaner, I have tried the hot cycles, I have left it open between washings but can't leave it open very much because we have a door out to garage that would hit the washer door if left open too wide. I can't leave clothes in there too long or they smell too much and have to rewash. The clothes never come out of washer smelling super clean. After I dry them using a scented dryer sheet, they are acceptable, but I never have really clean smelling scented clothes any more.
Apr 26, 2009 | Kenmore Washing Machines
Egg smell when using the top loading Maytag
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 20, 2009 | Kenmore 24832 Top Load Washer
Smell coming from washing machine
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Apr 18, 2008 | Hotpoint WMM39 Front Load Washer
Washing Machine smell
The problem comes from the design of the front load washers. There is always a little water left in the tub after the machine is used. Running a bleach load will deal with the mildew until the machine is used again. I leave the door open when I am not using my washer, and this does help.
Apr 10, 2008 | Washing Machines
Smells of mildew and so do clothes
If the odor does not go away, it is probably time to change the rubber door boot, or you have something stuck in the drain. Take a good look at the rubber around the door. If it has mildew spots and/or mold, it generally won't go away. Pull the rubber back a bit and look BEHIND the boot as well. You may have some lost items stuck in the boot causing the odor. Last of all, UNPLUG the washer and remove the lower kick panel under the door by removing the three 7mm screws and check the drain pump for foreign objects. There's only one pump inside the washer so it won't be too hard to find. It is usually white in color and has a screw off access cover. There is a bit of residual water that remains in the wash tub all the time. You will need to drain this first or you will have a mess to clean up. You can use some towels or use a shop vac. If you use towels, lay them down around the drain pump and remove the access cover. If you use a shop vac, pull all the residual water from the wash tub through the drain line. Sometimes this pump will build up with all kinds of scunge from soap residue and/or foreign object getting caught. Clean it out real well and run the washer on a bleach cycle with the hottest water setting you have. Let me know if any of this helps you. If you decide to change to door boot, post a response to this solution and I will give you step-by-step procedures.
Aug 26, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
