Question about HP Office Equipment & Supplies
New pc with Windows 7 and 3 yr-old HP Officejet 6210 All-in-One. The pc acts are the base for my home network. When connected to printer the new pc loaded proper driver and works with printer without even installing the printer software. The problem is that the laptops on our home network don't recognize the printer as being insalled. I am unable to install the printer software from disc on new pc.
  • 46 more comments
  • thebahers Nov 11, 2010
    Unfortunately this did not fix the issue with laptops on my home network being able to send print jobs. I uninstalled printer device and drivers on new pc, then I loaded the patch from the suggested site, and as for loading the driver, it again advised me that as soon as I plug in the printer to new pc, then the driver would install as it did before. Printing works from that pc, but still not from other laptops in the house. We use Network Magic for our home network. I am still unable to load printer software from original disc and I think that is what the laptops on the network are requiring.
  • Anonymous Mar 11, 2014
    When I drive sometimes the truck will start to make a knocking noise. It only happens sometimes.
    name of plastic cover under winshield wipers 2005 escape
    my abs light is on/
    External USB harddrive keeps disconnecting when I'm trying to use windows backup.
    LG50inc plasma pic is blank power light flashing when we pressed remote buttons
    New battery installed
    i have a peugeot 106 the red light for the immobiliser doesn't always work so therefore cannot put the code in
    wire diagram kenmore dishwasher
    the motor quits when it is not under load, must raise it up and restart
    Pottery barn toddler bed made in 2004
    I have a 2004 chevy cavalier that the transmission will not go into gear. The shifter has no tension on it, but the clutch still holds normal tension. The transmission has not stuttered, stalled, or grinded during normal use, so I believe the wrist pin on the transmission side is sheared and needs to be replaced. I don't know how to replace it. Any information as to how to do this repair myself, or thoughts as to if the problem may be something different?
    I have a pioneer vsx 07tx when I go to system setup it doesn't let me make any adjustments and the fan doesn't seem to work
    when i start the mobile is work only for 5 second after that mobile became hang...after few second mobile start automatically...
    dont know procduer after replacing battery
    airbag light flashes code 15,what does this mean
    how to strip down a yamaha clavinova cvp70
    sensor touch nimbers 1 and 2 doesn`t work. Kenmore Elite mod.721.67903601
    Har tappat manualen till Brauns Combi Max 750
    LOOKING FOR CODES ON A ONE FOR ALL REMOTE ON A HISENSE ER-31607A
    Have cleaned ducts etc. out
    My friend is trying to connect 2 hp dt2000i 2tb hdds at the same time but the computer seems to want to only connect one at a time.
    Is there any way he can get around this problem?
    can not take picture with probook 4320s
    1992 CHRYSLER NEW YORKER STARTER
    Head lights aimed to low
    where are the mounting bolts located on the starter on a 2000 eclipse 6 cylinder?
    Wheels locked up if I use steering system wheels move, but only one drives. Things look ok when I took one side of steering apart.
    Keep getting OCR error when trying to scan
    I've inherited my mother in laws embroidery machine. I cant find the magic card. she never had a magic box as her other daughter downloaded the programmes for her onto her card. I need to buy a new card, and am interested in buying myself a magic box. i'm based in Gauteng
    my 2009 doge caravan 3.3 l engine is making a radiling sound when its running what could it be
    i have a serious pain on my left lower rib is been more 6 years now but i could not explain this to the doctor cause i was not sure where the the pain come from whether from the heart or the rib.
    Softener dispenser not releasing the softener
    I have a santo 2340-8 kg and the warning light and sounder keeps beeping. temperature seems ok but i have turned the freezer on and off several times but it will not clear can you help
    Senseo 7810 adjust temperature
    I've checked the bag and installed a new one but the light stays on.
    CAN FINE IT
    Copied and pasted new password to my wireless laptop and mobile. Mobile Ok but laptop does not connect.
    it has no injector pulse
    first rear wiper not working then central locking not working then interior light,front & rear heated windscreens sorry first energy relay buzzing elec problems just seen to great greater one by one.would be greatfull for any help or a point in the right direction.
    a explanation mark wont go off or reset tires wont
    When I try to play and tap on doubledown, only a black screen comes up forever
    when full gauge shows empty or all over the place
    Cannot receive mail from scampark@btinternet.com
    what fuse shuts off airbag light for 92 Cadillac Fleetwood
  • Anonymous Mar 12, 2014
    the remote works to change channels. the red light on the outside lights and it turns blue when its turned on
    Sound when idle
    canon IR2830 error code e000014-0001
    e 3
  • 4,281 Answers
Click here Click on above link download driver and patch update then install in computer. First uninstall old driver of your printer from computer then reinstalling driver from above link will fix this issue. Let me know if you need further assistance.Thanks for using FixYa.
Posted on Nov 10, 2010
Computer says hp 6210 is offline
Make sure your printer is on.
Then check your connection between your PC and your Printer. Make sure your connectors are not loose.
If nothing happens, try restarting your printer together with PC.
If its not able to detect check your connections with your printer by clicking Windows icon then "devices and printers".
Once there right click on printer icon and see if it is enabaled.
If your Printer connection is actually connected to another PC or in other words in a network. Make sure that the PC that the printer is connected to is on.
Good day.
Jun 19, 2011 | HP OfficeJet 6210 All-In-One InkJet...
I want to conect my hp officejet6210 all in one printer and fax machina
This step-by-step guide describers how to obtain and install HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP drivers for Windows.
1. Define your HP Multifunction device model.
2. Define your operating system to install your HP Multifunction device. Note: Update Drivers in Win Vista
3. Browse Multifunction Drivers.
4. Find HP Multifunction Drivers.
5. Select HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP.
6. Download HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP. Note: you can update all Drivers automatically with RadarSync (Freeware) or DriverScanner (Shareware).
7. Install HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
Sep 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 All-in-One Colour Printer does itb work with windows 7 (64 bit) ?
NO, it is not work.The most severe problem in Microsoft Windows 7 is incompatible device drivers. Most application software can run in a 32-bit compatibility mode.
Aug 12, 2010 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One not printing color
The issue sounds like it is with windows 7 you are going to have to go onto HP website and find the driver for windows 7 and update your driver for you printer on your computer
Jan 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hp solution center will not open
1.right click on my compter icon click manage disply conected status your usb printer status was yellow ? simple.
2.printer installation
first disconnect your printer and uninstall printer software on add remove programme then re install your printer this time connect printer status on yr computer then connect ur pusb cable for this time only now printer installation on sucessfull msg on ur computer ok
Feb 18, 2008 | HP OfficeJet 6210 All-In-One InkJet...
21 people viewed this question
Seeker5211
Seeker5211
