Question about Holmes Products Dryers
I have a holmes pedestal 12' fan model hasf-1301. It ran several hours without the fan blades attached and then stopped. How do i repair the unit?
2 Suggested Answers
vibz
  • 178 Answers
SOURCE: Hello. I have a stand (pedestal) Holmes fan,
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Posted on Aug 18, 2011
Why is my Holmes HASF-1710 not getting power
This may be a duplicate post but here's my advice. Do a little disassembly to get to the "guts" of the fan. It is not uncommon for the speed control switch to break in such a way as to not allow the circuit to be completed. You may have to actually remove the switch and inspect it to be sure of this. I've had trouble finding replacement switches so I have put them back together with superglue. If this is your problem and you choose to use this solution just be sure all the switch parts get put back where they belong. If this is not your problem, break out the ohm meter and start checking your connections. Hope this helps
Jul 06, 2014 | Holmes Products HASF1516 Stand (Pedestal)...
How do I get the housing off my Holmes hasf 1301 fan?
try turning it counter clockwise no need to be gentle.
Apr 09, 2014 | Oasis Hunter 54' Ceiling Fan
I had a holmes HPF 650 MCU outdoor pedestal fan which worked great for five years and then abruptly stopped working. Rather than repair it, I tossed it out thinking I could purchase another one. ...
Hi Bill.
Holmes makes a very good fan.
You can buy a new one here:
http://www.overstock.com/Home-Garden/Holmes-HPF650-U-Oscillating-3-speed-Stand-Fan/3473589/product.html
Good luck from Detroit, MI.
Sep 18, 2011 | Holmes Products (HPF650MCU) Stand...
I need an owners manual for my Holmes fan, serial # HPF-650
Go to the Holmes Group web site and type in your model. Then you can download a PDF copy of the original manual.
Aug 20, 2011 | Holmes Products HPF650-U Stand (Pedestal)...
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
How to remove blades of fan
First, make sure the fan is unplugged. Second, remove the front fan guard. Then to remove the blade you have to loosen the dome like nut nut at the center of the fan. This is a left handed thread so you will need to turn it the opposite direction (clockwise) of a regular nut in order to loosen it.
Aug 05, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
My fan is not rotating when I connected to plug. There is no burning smell or anything. How can I fix the problem? Thanks in advance
Hello.
I have a Holmes pedestal fan that does this every few years. I have had this fan for about 10 years.
Unplug the fan and remove the fan blade guard. The fan blade should spin easily when you tap the edge of the fan blades with your finger. If the blade barely moves and abruptly stops, the bearings are dirty and need to be cleaned and oiled with 10W non-detergent motor oil. A quick-fix is a tiny bit of WD-40 where the motor shaft (the rod that the fan blade is mounted on) meets the bearing (the part of the motor that the shaft spins on). To properly fix this, you must oil both the front and back motor bearings which requires removal of the motor housing.
If the fan blade spins easily and you are certain that the fan is getting power (try a different outlet) the motor may be bad. Likewise, if the fan blade will not move at all. I do not know if Holmes sells motors for these fans. Here is their online support website:
www.holmesproducts.com/Support.aspx
P.S.: Never turn a motor-operated appliance on for more than a second if you know it's not working. That will cook the motor windings.
Jun 12, 2011 | Holmes Products HASF1710-UC Stand...
Hi, I have a pedestal fan (16") for which am looking for spare parts. I need - fan blade (5 blades) - the clips that hold the base grill and the front grill Make: Holmes Model:...
Seriously?? It's a $30.00 fan. IF you could get parts for it, they'll cost you more that the original price of the fan, but I guess if you insist. Go here and call them or chat online, they'll tell you if parts can be had.
https://www.holmesproducts.com/fans/
Jun 09, 2017 | Holmes Products Dryers
Grinding of fan
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Aug 19, 2008 | Holmes Products HASF1516 Stand (Pedestal)...
Dryers Logo
247 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
ray gallant
xkikbxr
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
