Question about Dell Computers & Internet
I NEED A POWER SUPPLY FOR MY DEMENSION E520 DESKTOP
HOW DO I KNOW WHICH ONE WILL MATCH UP WITH MY SYSTEM ? I HAVE THE PART # FROM DELL IF NEEDED.
    Champion:
  • 214 Answers
Hai
find out if it is AT or ATX cabinet
AT cabinet will have a power ON/OFF switch just like a 2 way switch
ATX cabinet will have soft switch for ON/OFF
Mostly all the new cabinets are ATX type.
To make it sure, open the cover and check the power connector to the motherboard. If its a rectangular double layer connector, it is ATX power supply, on the other hand if its a two piece single layer connector, it is AT power supply
hope this information will solve your problem
good luck
Posted on Jun 17, 2008
  • Rabby V V
    Rabby V V Jun 17, 2008
    Please don't forget to rate or accept the solution
How can i restore factory settings without password
You can only restore the BIOS settings by selecting F2 on reboot. You need the password to restore operating system settings. Geek squad can break password.
Jul 20, 2014 | Dell Inspiron 560 PC Desktop
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
Dell Demension e520
These features are a functionality of the Processor used in the Desktop. These features are NOT a feature of the desktop itself and is limited to functionality of the CPU exclusively. Refer to this link for more information regarding NX, PAE and SSE2. http://windows.microsoft.com/en-us/windows-8/what-is-pae-nx-sse2
It is STRONGLY recommended you do not mess with these settings in the BIOS unless you REALLY know what you are doing.
99.9% of the time NOONE messes with these settings you should have no reason to do so.
Jan 08, 2014 | Dell Computers & Internet
Restore factory settings
You need to have a Dell "restore" or "reinstallation" CD/DVD that match with your laptop's operating system's key number (it is located on the bottom of your laptop). If you don't have it anymore, then as far as I know, you can use a Dell Windows XP Pro DVD/CD to reinstall the operating system. Later, you need to use other computer to download some necessary drivers; copy them to your D810 notebook and install them. I have this kind of DVD, so please let me know if you need it.
Dec 24, 2013 | Dell Latitude D810 Notebook
How do i install an extra SATA cd/dvd drive in my dell dimension e520 pc with attention to the correct way to connect the cables and power supply
Hello
I have found the service manual for your PC.
Scroll down to the part on how to install a new CD/DVD drive.
http://support.dell.com/support/edocs/systems/dime520/en/SM_EN/parts.htm#wp1056445
hope this helps.
Jan 30, 2012 | Dell Dimension E520 PC Desktop
I have an Asus ASB100 Motherboard. Can I use it in a dell dimension 4700?
Sure, if it fits and the motherboard connections match your needed connections.
Oct 04, 2011 | Dell Dimension 4700 PC Desktop
Hi. I have a Dell Desktop dimentions e520.. 2 months ago, i went on a trip for a weekend and when i came back my pc wont turn on. it was blinking amber or orange. i search online and it might be the power...
The power supply is receiving power from the source but is unable to properly distribute it to the components. It sounds like the power supply but unless you have a power supply tester that indicates if all voltages are present the only way to make sure (and cheaper) is to replace the power supply as opposed to replacing the motherboard.
Sep 10, 2011 | Dell Dimension E520 PC Desktop
I HAVE A FLASHING AMBER LIGHT ON MY DIMENSION E520 DESKTOP
If you mean your Power Button LED is flashing amber then the power supply is receiving power from the source but is unable to properly distribute it to the components.This means that the power supply is receiving power from the AC outlet but is unable to distribute the needed voltages to the other circuitry of your computer. This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD and hard drives. Look at the USB ports to see if any are damaged.
Aug 23, 2011 | Dell Dimension E520 PC Desktop
I TOOK MY LAPTOP TO THE GEEK SQAUD.they said i need to order a system restore cd for a dell latitude 620.something about 5 dl that have been deleted or destroyed.can you help me
The dl's they mention are Driver files.
A Driver file is a small piece of software that allows communication between the Operating System, and a device.
Operating System:
Windows XP, Windows Vista, and Windows 7 are some examples of an O/S.
Operating System
Device:
The hardware components inside the laptop, or outside, that are, or can be connected to the laptop.
Some examples of inside hardware device components;
Harddrive, (Hard Disk),
Optical drive, (CD or DVD drive),
Wireless adapter,
are just a few.
Some examples of outside hardware devices, (Peripheral's)
Printer, scanner, Fax machine, copier, (Or an All-In-One machine),
External harddrive,
The Drivers MUST match YOUR laptop.
Has to be for a Dell Latitude D620.
Also has to be for the Operating System that is installed on your Dell laptop.
You can download the drivers, and install them, IF Dell has what it is needed.
Some of the Drivers are within the Operating System itself.
They will also be matched to THAT particular Dell laptop you have.
The easiest, and best method IMHO, is for you to obtain THE System Restore disk from Dell, for YOUR laptop, and fix your laptop yourself.
(Cheaper too!)
1) Turn the laptop on
2) Insert the System Restore disk in the optical drive tray, close the tray.
3) When asked do a Repair. (Non-Destructive Installation)
After you get the System Restore disk, come back here, and someone will lead you through it, if you have problems.
{I have heard the disk/s are not cheap. Not a 'fanboy' of Geek Squad either)
{OH! Did i say that outloud? lol}
Oct 21, 2010 | Dell Latitude D620 Notebook
Computers & Internet Logo
275 people viewed this question
Alun Cox
