Question about Texas Instruments TI-84 Plus Calculator
My TI-84 Plus graphing feature is connecting my trig functions across the asymptote. How do I make it stop doing this?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press MODE and change "Connected" to "Dot".
Alternatively, you can change the style for individual graphs. In the Y= screen, move to the line then press left-arrow to move past the = sign, then press ENTER repeatedly to cycle through the different graph styles.
Posted on Nov 10, 2010
When graphing the function (x+6)/(x-7) I'm getting a vertical line showing up on the graph connecting the two curves that shouldn't be there. do I have something turned on that shouldn't be?
The vertical line is called an asymptote, it is not connecting the graph, it means that the function goes to infinity as the function nears the line. In this case the graph goes to infinity and negative infinity as the x nears 7. This is because the function becomes undefined at x = 7 , plug 7 into x and we get 1/0, dividing by zero is undefined. Thus, the calculator puts the vertical asymptote in the graph to symbolize the action of the function nearing infinity.
Apr 02, 2011 | Texas Instruments TI-83 Plus Calculator
When I try and graph on my TI-84, "ERR: INVALID
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Dec 09, 2010 | Texas Instruments TI-84 Plus Calculator
Graphs on some TI-84's and TI-83's appear connected where asymptotes should be, like f(x) = 2/(x-squared - 1). Most don't show these connections. How do I get rid of them.
I have drawn the curve for your function. On my TI84Plus with OS version 2.53MP the spurious asymptotes do not show, while on a TI83PLUS OS 1.12 they do if the graph is drawn as connected lines. It might be a bug that was corrected in newer OS (for TI84PLUS)
The graph from a TI83PLUS (the last one above) shows asymptotes when drawn connected, but no asymptotes appear if graph is drawn dotted.
2d0269e.jpg.
Sep 29, 2010 | Texas Instruments TI-84 Plus Silver...
How can i turn off vertical asymptotes on a ti-83 plus
The asymptote you see is in truth a spurious effect. It appears when you draw connected graphs. There is no command that turns that "non-existing feature" ON and OFF.
If you do not want to see the "asymptote" draw dotted graphs. The drawback is that you will have fewer points near the asymptote because the curve grows too fast. If you decrease the x-step to have more points, the graph will take longer and you may run out of RAM.
Sep 19, 2010 | Texas Instruments TI-84 Plus Silver...
Calculator is drawing vertical asymtotes.
There is no vertical (or otherwise) asymptote feature on a TI84PLUS. It seems to you that the calculator is drawing the asymptote. However when you plot a CONNECTED Graph a line is drawn from one point to the next: The last point on one side of the asymptote is thus connected to the first point on the other side, effectively mimicking the drawing of the asymptote.
To get rid of this spurious effect, draw dotted graphs, but you will see fewer points, because the points are drawn at constant intervals in X. This is set by the Xres variable, in the Window configuration screen.
Here is a function that will "show" you a vertical asymptote on the TI84PLus, when graph is drawn connected, but on a calculator with a higher resolution, you see none. A calculator cannot handle infinity. You can with the help of your mind's sight, so to speak, see the asymptote on the graph.
Aug 20, 2010 | Texas Instruments TI-84 Plus Silver...
How do I turn off the vertical asymptote feature?
There is no vertical (or otherwise) asymptote feature on a TI84PLUS. It seems to you that the calculator is drawing the asymptote. However when you plot a CONNECTED Graph a line is drawn from one point to the next: The last point on one side of the asymptopte is thus connected to the fisrt point on the other side, effectively mimicking the drawing of the asymptote.
Hope it helps.
Nov 05, 2009 | Texas Instruments TI-84 Plus Silver...
TI-84 silver: Black arrow instead of line in function mode
I have answered this question multiple times. I have no idea why you calculator refuses to allow you to choose more graph styles. Maybe you should reset it by clearing the RAM.
Concerning the connected asymptotes.
In truth your function has one aymptote namely the straight line x=2 but your graph has two asymptotic branches, one tends towards -infinity, the other toward + infinity. That they seem connected is an illusion due to the finite resolution of the screen. This is made worse if you select a connected graph instead of a dotted one. I am enclosing a screen capture of the graph for the same function, drawn on a calculator with better resolution.
This clarification being given, it remains that you still have a problem since you cannot choose other styles. Do try to reset the RAM, and choose dotted graphs. If that does not work, maybe you should update the OS or reinstall it from education.ti.com.
I hope it solves your problem. If it does not, do not blame me, and remember that I tried my best.
Oct 16, 2009 | Texas Instruments TI-84 Plus Silver...
Graphs with asymptotes connect?
The calculator can't tell the difference between a function with an aymptote and a function that rapidly goes from a large positive number to a large negative number in one step.
One way around this is to plot with the asymptote at one edge. Press the WINDOW key and change the limits. Another way is to change the plot type from Line to Dots. Press Y= to enter the Y= editor, select the function being plotted, press Left to highlight the = sign, then press ENTER repeatedly to cycle through the different graph styles.
May 23, 2009 | Texas Instruments TI-84 Plus Silver...
Graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
Dec 31, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
209 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
