I, m looking to buy a weatherking ac unit and need to know if this unit will heat and cool? Model# WAKA-048JAZ and if anyone khows the output btus are?
  • 455 Answers
Hello,That is a 4 ton @ 48,000BTU per hour.I'm not sure if it's a heat pump?(heat/cool).
Posted on Nov 10, 2010
Morning, I got a external unit SH24BP2X samsung fro air conditionning, and I'ld like to buy an indoor unit. Is anybody can give me ref which match with this unit. I need 5/6 kw heating power. Thanks...
The 24 in your model number means 24,000 btus. There is 12 thousand btus in a ton of cooling. This makes your unit a two ton. You can buy a air handler sent up for two tons of cooling and then buy what every electric heat pack that you need. let me know. wally
Mar 16, 2011 | Samsung Heating & Cooling
What size ac ?
The condenser is 2 ton or 24 thousand btus.
Mar 08, 2010 | Heating & Cooling
I HAVE A WEATHERKING MODLE WAKA-037JAZ OUTSIDE AC UNIT WITH SPLIT GAS FURNACE-WHAT TON IS THIS UNIT
It appears you may have a 5ton unit, if your house is over
2000sq. feet then Im guessing that 60 thats appears in
the model number is equal to 5ton. 12,000 btus per ton
of cooling
Feb 28, 2010 | Weather King 10AJA6001AH Air Conditioner
Haier model hr36civar heat pump unit . only need work ac please .
All but one heat pump energizes the Reversing valve in cool. Rheem-Ruud-Weatherking. You need to have power to the reversing valve for coolong. Just energize the valve from inside. Send one power wire out just for the Valve and use the ground or blue coming back. Rus
Jul 18, 2009 | Heating & Cooling
I have a weatherking model number waka-037jaz just bought this with a payne furnace from a gentelman who said they worked together when he removed them but furnace doesn't have an A coil in it how do u...
The furnace can handle three tons of AC but you will need a coil and a line set to connect the two. Get a match coil for your furnace and a line set. 7/8 and 3/8 plus tstat wire and tstat. Sometimes you get stuck buying used equipment and it cost you more in the long run. I have owned a company for 44 years and I never never sell used equipment.... If you need help write back I will be glad to help you. RUSS
I would like to know the specifications of my Goodman model CPKE42-18 AC/Heat pump system. BTUs heating and cooling? Thank You,
Many HVAC people talk in tonnage. One ton is equal to 12,000 Btus. Therefore your model specifies your cooling tonnage at 3 and 1\2 tons. Your heating would be determined by how many if any supllimentary heat strips are added. If you live in Anahiem or Miami that's not really important. But if you live anywhere that gets down into the 40's at night you'll want strips. Cooling wise depending on where you live and what your insulation is like, I'd say your unit is good for 1100-1300 Sq feet of living space.
Jul 15, 2009 | Goodman Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Weatherking control board
the fan comes on only after the burner fires. so no stat voltage is expected. it is not powering the blower, the elec board is. only after burner lights will fan be energized due to heat build up. usually on older weatherking there is a heat sensor on the bulhead above the burners. it is stuck sounds like to me. try a sharp rap on the right side about four feet up the side and a foot back . if fan stops you know the switch was stuck . probably needs a new fan switch.
Oct 20, 2008 | Heating & Cooling
Ruud uamc-048jaz
What do you need to know? That is a 4 ton 12 seer straight cool system, with 11 kw heat strip. You may go to ari.org to search perfomance data.
Dec 03, 2007 | Ruud Central System Air Conditioner
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
