Question about GPS
I have a roadmaster cb radio with a 4 pin Mic connection. I need the wiring for a replacement Mic. The model # is RE 6000
SOURCE: CB MIcrophone RewireJob. A Diesel Model 360-100 to cobra's
does it have a sheld wire?
Posted on Jan 14, 2009
  • 24 Answers
SOURCE: mic wiring diagram 4-pin
try http://www.cbtricks.com/
they have mic wireing diagrams
Posted on Jul 14, 2009
SOURCE: Wiring Johnson Microphone to cobra 29 CB Radio
Use trial and error systemathically. If still refuses to work, mike and radio aren't compatibles.
Posted on Nov 23, 2009
Ironfist109
  • 3018 Answers
SOURCE: CB Radio - Cobra 29 WX ST - Need Chasis wiring
This one you will need a digram. any wiring you need is on that page. Good luck. www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/graphics/cobra_29ltdwx-st_29ltd_sch.pdf
Posted on Mar 05, 2011
herkimermort
  • 3 Answers
SOURCE: radio shack cb radio trc-481
Red wire is the primary power, this can be hooked to a fuse in the fuse block that shuts off with the vehicle, such as the fan or windshield wipers, the white wire is the memory power, this should be hooked up to either the battery (not recommended as you will pick up alot of engine noise), or another fuse that has a constant flow of power...such as interior lights. Not that both red & white have an inline fuse of there own, anything over 2amps will cook the radio.
If interested in operating without the vehicle running, hook both to a fuse in the fuse panel that has a constant power flow, use the same fuse for both red & white, not going over 3amps MAX!
Black of course, is your ground.
*NOTE-any many radios, the better the ground, the less engine noise your radio will pickup, because alot will be flitered through to the ground. Best to run it to the body, for example the bolts that attach your seat to the body...put the wire between the bolt & the floor...this helps create a capacitor like ground.
Citizen's Band Central~Find us on facebook
Posted on Jul 30, 2012
CB Uniden 4-wire mic to a Uniden 510 radio how to wire color codes please
look up microphone wiring diagram for your cb and mic. more than one way to wire, depending on mic and cb having 4 or 5 on plug end. write down mic numbers and cb plug numbers. if audio on mic is 3 and cb is 4 put 3 on 4 pin check each wire. using power mic make sure red and black wire are on the right pin, can damage radio or mic or both.
Feb 11, 2018 | Uniden Radio Communications
Wire 4 pin Turner Plus 3 Power Mic for cb radio to 5 pin President Washington SSB AM Radio
the best i can find is this
red pin 5 ptt
black pin 4 ptt ground
white pin 1 mic
shield pin 2 mic ground
no connection pic 3
Jan 19, 2015 | Radio Communications
How to wire a mic
This might help as I don't have a color code for the mic. Radio pin code; 1 - Audio -2 - Shield - 3 - Receive - 4 - Sw. Wire -
5 - Transmit
MIKE WIRING GUIDE
Found this by Google searching;
5 Pin Mic Plug Model
Pin #1 Audio Output / White
Pin #2 Shield
Pin #3 Receive / Black
Pin #4 Common / Yellow
Pin #5 Transmit / Red
Feb 01, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Moc plug 4 pin to a 5 pin
it's not possible to wire 4 wire mics to the uniden 5 wire radios without modifying the mic and replacing the mic cord
Jan 06, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
Road king 56 4 pin mic
take a wire or small screw driver across any two pins you are looking for a earth from tx to tx the last pin is mic. on mic side use a multimeter earth is braid, find rx lead next . key mic multimeter shows 0 tx. audio has a higher value .
Apr 08, 2009 | Magnum DeltaForce CB Radio
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
GPS Logo
131 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
