Question about Zebra TLP 2844-Z Thermal Label Printer
The print is so light we can't read the label
    Champion:
  • Zebra Expert
  • 285 Answers
Press button until flash 5 times, relese the botton, let the printer run the dark mode, and press again wen the darkness is good for you.
Posted on Nov 12, 2010
I can't read a code bar printed with datamax a4212
try adjusting your darkness settings. if too dark wont read and also if too light wont read. also try a printhead test to make sure no elements are burnt out.
Aug 13, 2017 | Computers & Internet
We have 2 Intermec 4420 printers. We printed the same label out on both printers. Our scanner reads one but won't read the label from other printter. Why do you think this is happening?
if you use the same resolution, and the same print speed, check the temperature use to perform the transfer. The barcodes are not correctly printed on one of your printer.
Feb 10, 2011 | Intermec EasyCoder 4420 Thermal Label...
Have a Zebra 105SE that prints the FEED test just fine, but will not print the PAUSE test nor will it print a bar code label from the computer. The FEED test prints vertical bar codes while the PAUSE test...
Check to see if the pause light is on also. Make sure you are using the correct printer driver. (105se)
Try in ZPL and then try in ZPLII.
Check Delimiter character 2CH
Check Format prefix 5EH
Check Control prefix 7EH
Aug 24, 2010 | Zebra 105Se Thermal Printer
Display reads ready, but when print is press the labels run but nothing is printed on the labels.
Is your label "direct thermal"? or using a ribbon to print.
If using ribbon, high probability that you install the ribbon the other way around.
Aug 20, 2009 | Datamax DMX-I-4208 Label Printer
Printer prints light 2nd half of carbon roll
Sounds like a faulty Ribbon, check the labels as well to make sure they are not Direct Thermal. Regarding the Ribbon, get in touch with your supplier and get reccomendations
Jul 28, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Labels only jam when printing from file
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
May 08, 2009 | HP Color LaserJet 8550dn Printer
The 'eye' won't read the space between the labels,
recalibrate the sensors and check your label lengths and gap size
Mar 31, 2009 | Toshiba TEC B-472 Thermal Label Printer
Zebra 2844 Not printing at all
Antztech,
if the red light is coming on and staying on, it might be a sensor problem. Try pushing on the lid and see if the light goes to green. If it does, it' s the gap sensor. This is how the printer "reads" the labels gaps-the little spaces between the labels. We've solve this in the short term by covering the sensor and manually setting the gap through the programming command prompt,
Mar 28, 2008 | Zebra LP 2844 Thermal Printer
Okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Aug 06, 2007 | OKI MICROLINE® ML390 Matrix Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
64 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Victorman
Victorman
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
