Question about Maytag MSD2756G Side by Side Refrigerator
Hi fridge was not staying cold so i looked at the coils in the freezer and they were cover with snow(ice), I melted the snow and ice and it worked good for almost 2 weeks then started getting warm again and same thing the coils were covered with snow again so i melted the snow and all is working great. I know it is a defrost problem but what is it more likely to be if it works great once you melt the snow. what is it more likelly to be the thermostat or heater Thanks for your time and help Connie
  • Maytag Master
  • 1,344 Answers
Its definatly a defrost problem. The reason it stopped cooling is because there was no air circulation do to the ice build up. For the most part the part you'll need t replace is called an adaptive defrost control, the part number for it is 12002104. This part is located in the refrigerator side of the machine, above the heading so you'll be taking the hole top down to put it in. Take your time and it won't be hard.
Posted on Nov 10, 2010
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
Samsung fridge freezer RL38SCSW fridge isn't cooling freezer is fine please help
Hi Hannipan,
I know this is a bit late but it should help for others. We had the same problem with our RL38SCSW (caused by the freezer door being left ajar for the day) the problem is caused by the freezer trying to cool down the unit and goes into overdrive by freezing all the cooling coils in the back. The air can't circulate (via the use of the fan) and so the freezer stays cold but no cold air travels up to the fridge.
Take out all of the freezer trays and behind there is a plastic cover held in by one screw, remove this and carefully remove the cover (the top part needs to be pressed downwards to release) under there is a grey plastic cover this will most likely be frozen to the back so don't pull it. Use a hair dryer and try to melt the ice. Remove two more screws which hold it in place and eventually it should come out easily. Now you can see the coils behind are frozen up, leave them to defrost (don't chip at them! or alternatively use a hairdryer to help melt the ice) Once it's de-iced put it back together and you'll be good to go again.
(Make sure you don't keep the hairdryer and one area of the fridge you'll melt the plastic and also make sure you turn off the freezer at the plug before working on it)
Jan 28, 2013 | Samsung RL38SCSW (113 cu ft
I have an old kenmore fridge maybe a 90's model it's an off white color probably from age and alittle rusty, it's a top freeze and the freezer works great but the fridge section can barely keep...
all the fridge does is the freezer gets cold and the evap fan blows cold air from the freezer down into the fridge section,so open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,also the drain can be blocked and it freezes up the air ducts so the air can't circulate down into the fridge,is there water under the bottom crisper draws?if so the drain in the freezer is blocked,you have to take everything out of the freezer,remove the back wall,melt out all the ice and clean out the drain under the evap coil.i use a steemer to clean out the drain,if you don't have a steemer you have to melt out the ice in the drain with the hair dryer,then get like a turkey baster or anything that can blow down into the hole,pour hot water into the drain,if it drains out then you're done,if it doesn't keep hitting it,another thing is touch the inside back wall of the freezer,if there's like frost or like snow covering the back in side freezer wall you have a defrost problem,bad defrost thermostat,heater or timer,the last thing is the door was left open,you can tell this by looking at the food packages and the ceiling and walls,if you see frozen water droplets on your food packages or on the shelf or walls the door was left open and the air ducts are frozen,you have to melt the ice out of the air ducts.so open the freezer door,listen for the fan,no fan could have a bad fan motor,look for ice on back inside freezer wall or frozen water droplets,the door was left open or you have a defrost problem. also when was the last time you vacuumed out the coil unless it's on the back wall,if the coil is behind the bottom kickplate vac it out that will make a big difference.you can get back to me and let me know what you find or melt it out with a hair dryer like i said.good luck and let me know what you find.one more thing,if your ice cream is not staying hard just soft you could have a leak in the sealed system,but if i were you i wouldn't put any money into that machine,if you change it out you'll save money on your electric bill and usually once something on those old dogs starts to go wrong it's not long before it totally dies
Sep 22, 2011 | Kenmore Refrigerators
Hi - My refrigerator has begun making a very loud noise - like an airplane engine - when it kicks on. After a few minutes the sound recedes but is still louder than normal. The bottom freezer is way too...
it sounds like ice built up arounnd the fan blade probably from leaving the bottom freezer door open and warm air got in and froze up the air ducts or you have a defrost problem but if you hear a cracking sound it sounds like the heater is coming on but can't melt out all the ice.try this,take out all the food out of the freezer,unplug it,get a hair dryer and blow the hot air at the back wall where the vent holes are and melt out all the ice,when you look into the vent holes and don't see anymore water dripping down you can plug it back in and with your hand feel to see if you can feel the air blowing into the fridge section,if you feel the air then you melted out the ice and if the noise is gone then the evap fan motor is still good,if there's alot of ice and snow on the back wall you should remove the panel and then melt out all the ice with the hair dryer.also if you have another fridge you can unplug the fridge and let it melt out on it's own for like a day
Feb 10, 2011 | Refrigerators
Hi - Our 15 year old GE Profile Fridge is not staying cool enough. Freezer works great - fridge cold but not cold enough. Any suggestions?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
There are many people that have this problem and are searching for answers as to what to do and what could be causing this problem. It seems to be weird that the freezer is working fine and the fridge side is not. Why would the coldest side be good and the warmer side not?
The answer to these questions lies in the way the freezer/fridge combo works. The freezer is where the cooling coils are located. Then air is moved over the coils and circulated through the fridge side by a small blower or fan. The problem arises when the air is not circulated for some reason.
The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Take care.
Jul 24, 2010 | GE Refrigerators
Fridge is not cool. Freezer has soft ice buildup inside
Your website is fantastic... it really helped me and saved me money!!!
I defrosted my fridge overnight. Cleaned all the water up. Plugged the fridge back in and it works likes new. Thanks :):):):)
Mar 19, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
83 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
