Question about Polaroid TDA-03211C 32 in. LCD HDTV
Picture went completely out. Got audio. - Polaroid TDA-03211C 32 in. LCD HDTV
    Problem Solver:
  • 5 Answers
I have the same TV and had the same problem. You can fix it like I did. On the back of the set you will see a big screw in the middle of the black cover and I believe one on each side these would be small. Remove the screws and take off the cover carefully. This will expose the metal cover and remove the screws and I think there are 4. Remove the metal cover. You should now see the inside with 2 circuit boards. The top board will have about 6 screws to remove so you can take the board out. You will also need to unplug some of the componets that are hooked together like a computer or plugs. Unplug them and becareful. Located on this circuit board will be 2 capacitors that are bad. They are located at EC17 & EC18. You can order the new capacitors at Digi-Key.com and the part # is 493-2069-ND. Go to the site and type it in so you know what they look like on the board. If you know how to soldier you can do it I guess. I didn't do this part. I sent my board and the capacitors to JD Electronics in Poland Me. Call the guy and see if he can soldier them in for you. (207)998-5687. His name is John. I put mine back together and it works fine.
Hope this is some help.
Posted on Nov 12, 2010
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
I have audio, but no video, what's up? last night I was watching, and the picture went out, I truned off the TV, then restarted it...the picture came back. Today I tryed to turn it on and no picture, just...
s the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Oct 17, 2008 | Televison & Video
TV picture turned green, then it went out completely
if your set went all green then shut off you might have a shorted anode on the green tube this is not good news if the set went dead then it probably killed your power supply you will have to get this fixeed first then check to see if tube went bad.i need model of your set ill help yo find out k
Dec 27, 2007 | Televison & Video
Sony KP-46WT510 Picture went out (completely
Your Sony TV needs Screen (G2) volts adjustment and I'm not sure that you can do that or not by yourself.
If you are confident and know electronic stuff repair, then let me know to guide you OR call local TV tech to perform adjustment.
Thanks.
Oct 30, 2009 | Televison & Video
Lamp went out about a month ago, replaced, worked great. Turned on the t.v. and now no picture and only get Samsung start-up chime no audio or video after. Any ideas?
It could be the ballast that doens't have enough voltage to keep up with the new lamp, or it just went completely out. This is a common issue with samsung tvs.
Aug 06, 2009 | Samsung HL61A650C Television
The picture works great, but we have lost all audio.
I would buy new rca cables, or hdmi cable, whatever you are using and try that. or if you have any spares laying around your place, try switching it out and see if that works
Apr 07, 2009 | LG 42LG30 42 in. LCD HDTV
Have a big screen tv bought in 2003 and it went black on us no picture...never problem with this tv
Need the model number of your set. Also does the audio work and not the picture or is the set completely dead with no power lights? let me know more details such as model number and I should be able to help you more percisely.
Apr 09, 2008 | Televison & Video
Have a beautiful picture but no sound
your problem is in sound section only. 1 signal line for sound coming from vif section 2 supply to audio section. 3 component fail in audio output section. 4 loose contact in audio section 5 speakr & its connecting wire.
Sep 27, 2007 | Sylvania 6427TE 27" TV
I have suddenly lost the picture on T.V. but still hear audio of program...
sounds like your input board went out. I had the same problem on the ILO version of this panel. Got a replacement part off of Ebay. Search for Ilo plasma on ebay and it will come up
Sep 08, 2007 | Tatung P42BSKT 42 in. HD-Ready Plasma...
Sony kv-32s26 32 inch tv
video card went out in the tv. You are saying you need a schematic. Be real careful getting into tvs. They have very large capacitating capacitators in them that can electrocute you. You need to take it to a repair specialist and have them run a check on it. Sounds like the video card to me though.
Sep 18, 2006 | Sony KV-32S26 32" TV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
42 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
