Question about Kohler CH25 PA-CH730-0040 Command Gasoline Engine
I have a Vermeer 625 chipper with Kohler Command Pro 25 engine (CH730-0019). This unit has a speed sensor to regulate the hydraulic auto feed. The sensor assembly mounts to one of the ignition coils and picks up off the flywheel teeth. This doesnt seem to be working and I am wondering how to test the sensor.
  • suzie40cycle Feb 20, 2011
    Hey Ken,
    I wish I could help but i have the same issue with my Bear Cat 5" pto chipper. Is there anyone out there with a generic solution??? I'm sure we would both be very grateful for your advice.
  • 152 Answers
SOURCE: Kohler Command 12.5 OHV (starter?)
You should properly test the battery. A dead cell in a battery will absorb the current that you are trying to supply by jumping.
There may be a fault in the wiring system, thus not allowing enough current to properly supply the starter. Construct a way to temp. connect the positive jumper cable lead to the tractors battery cable connection on the starter that will not short circuit and connect the other poss. end to your trucks poss.battery terminal and then connect the ground lead as normal but to the tractors frame, then attempt to start. If this allows the starter to operate properly then disconnect your jumpers and Inspect the positive and ground wires for insulation cracks, blisters and corrosion. Also check the connections for being clean and tight.
You could also remove the spark plugs ( to release compression that will allow the engine spin free) to see if the starter will then turn the engine.
If all fails, sorry to say, your starter may be weak and in need of replacement.
Good luck
Aduz
Posted on Mar 26, 2009
Richie_asg1
  • 1036 Answers
SOURCE: JD LX173, Kohler Command OHV Engine keeps droping mounting bolt
Use a thread locking compound on the bolts - and torque them to the correct spec.
This will prevent them shaking out.
Posted on Sep 08, 2009
Dolfoff
  • 148 Answers
SOURCE: when does 25 command kohler fire on magnet
It fires when the left edge of the magnet is precisely aligned with the left edge of the left leg of each coil. (When viewed from the flywheel and looking straight on at the coils.)
Hope this helps,
Dolf-
Posted on Oct 16, 2009
Testimonial: "This answer was most helpful. Thanks very much."
  • 6 Answers
SOURCE: We are replacing head gaskets
first torque to 16ft/lbs in a x patt. then 30ft/lbs in a x patt. for head the intake gaskets connecting to the head should be 12 to 17
Posted on Mar 09, 2011
SOURCE: Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Posted on Jun 11, 2011
What is the best oil & weight to use in a 2011 vermeer bc 1000 xl with a cummings engine?
call cummins service center for the correct oil to use in cummins engines
the details will be in the user manual or service manual for the machine
Oct 29, 2016 | Vermeer BC1000XL
How do I check for a blown head gasket
Dwayne, the third link talks about the signs and test for leaking head gasket. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
blown head gasket on kohler command pro 25 horsepower
How to replace head gasket on Kohler command
Legacy Kohler engine leaky head gasket repair
May 01, 2016 | Kohler Command V-Twin Horizontal Engine...
How do you change oil in a Vermeer feed roller
I would google the unit model number for oil change instructions, since I don't have the model number I can't do it.
Dec 31, 2014 | Heavy Machinery
I have a brush chipper bc1000xl. during first start it runs about 10minuts and than it stops.after that it starts but it stops imediate.
My bc1000xl was doing the same thing all gauges working fine engine kept cutting out about every 2-3 minutes found water temp sensor wire that goes to the computer and disconected it. Problem fixed but get a new sensor as soon as possible in case of a real overheat
Apr 18, 2014 | Vermeer BC1000XL
When i start stump grinder it works fine. when i start grinding a stump it pops, backfires and loses power. any suggestions?
Hi it looks like i had the same problem with my 252 and we replace the wire harness and got the problem fix.
Nov 24, 2012 | Vermeer Sc 252 Walk Behind Self Propelled...
The auto feed on a 625 works then it dont, I
I had a 625 chipper several years ago with the same problem. It was just that the engine rpm was to slow sometimes. I don't remember exactly what it needed to be but I think it was around 3500 rpm.
Sep 25, 2009 | Garden
VERMEER CHIPPER BC 625AI MANUAL HOW TO GET ONE
if you go on www.vermeer.com you can request a new manual and they will send it out to you.
Oct 13, 2008 | Heavy Machinery
Kohler CH25 PA-CH730-0040 Command Gasoline Engine Logo
412 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
