Driver for USB key
Hi
i have a usb key and i need its driver to work on Windows 98.
the problem is that i don't know the brand of the key...i got it without the packing and nothing is written on it
thanks
    Master:
  • 788 Answers
Get the driver here: http://www.technical-assistance.co.uk/kb/usbmsd98.php make sure to pick the right version of for your flavour of Windows 98, you most likely have the SE or Second Edition version.
This one might also work: http://toastytech.com/files/cruzerwin95.html
Posted on Jun 17, 2008
Good morning, I have a windows 98 os, mouse (m-rn67) stopped working. no luck using newer mice, doesn't recognize. can i update computer using usb w/driver for newer mouse?
Hi janettgordon,
I am not exactly sure what you mean by "can i update computer using usb w/driver for newer mouse", but if you want to know if you can update the USB component of Windows 98 I regret to say to you that it's not possible.
USB support on Windows 98 always been tricky and Microsoft never officially supported it before Windows 98 SE. I don't know what version you have, but either way USB support under Windows 98 never been great. You also need to keep in mind that Windows 98 is quite an old system and no recent hardware like mouse, keyboard, printers is supported on it anymore.
My advise would be to upgrade your current Windows installation to Windows XP or Windows 2000. A friend can probably lend you a copy and I'm 100% positive that it will solve your problem with newer mices. You will need to make sure your computer can handle Windows XP or 2000, but they can run under pretty old hardware so it should not be a problem.
Cheers!
Mar 01, 2011 | Logitech Cordless Mouse
I want a software which helps to make my usb alive
Hi.
USB memory sticks do not require additional drivers if you use Windows XP or later.
Here drivers for Windows 98: Windows 98 USB Mass Storage Device Driver.
Please let us know if you need more help.
Regards.
Ginko.
Feb 14, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Data traveler c10 driver for windows 98
Windows 98 does not support USB automatically, You need to install Windows 98 USB driver. Please click on this link to download the USB Kingston driver for Windows 98 :-
http://www.kingston.com/support/USBFLASHDRIVES/downloads/default.asp?s=DTI_HS
Sep 18, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I'm tryin to install the sierra wireless card 598 on win 98 manually. Does anyone know how to do
Hello sir, hi, installing a USB device on windows 98 is kinda hard but possible. here are some things that you should do:
  1. you may need the sierra CD device driver that comes with your wireless card.
  2. next is that your PC should support USB 1.1 or 2.0. If you are using windows 98, make sure that your USB port is working fine, you can insert a flash drive to confirm if your usb port is working.
  3. depending on the setup files they may need you to plug in the device as the setup file loads the driver or later.
  4. run the sierra CD setup file to install your wireless card. (hope win 98 supports this device)
  5. after the setup, plug in your wireless USB device, windows 98 should detect it.
If things didnt work out as listed above, do it setup several times, ............ still no progress call your dealer for proper installation on your PC.
Nov 09, 2009 | Sierra Wireless 598U USB Modem
Windows 98 drivers for usb flash drives?? are there any?
What brand of flash drive do you have? Win 98 is known for that.
I use one for sandisk and maybe it'll work for any brand.
You could try this link:
http://usbflashdrivers.com/
Feb 09, 2009 | Toshiba Satellite 330CDS PC Notebook
HP 1210 c/ps will not print
you will need the usb port drivers for windows 98 and the usb drivers for the printer as the earlier windows 98 had'nt the usb drivers included with operating system an as the new motherboards came about with usb ports then a new in 98 was needed to catter for this that's why you have win 98 first edition and win 98 se edition please chech that you have the driuvers installed for both parts to work.
good luck
Nov 22, 2008 | Microsoft Windows 98 for PC
Nokia N72 driver for windows 98
Just follow the following steps:
1) Locate the USB port of your Nokia N72 phone. See Manual if needed.
2) If your mobile phone has a USB Data Cable supplied, connect the end that matches the hub while connect the USB end to your USB port of your PC.
3) If your mobile phone has a CD supplied, this contain the PCSuite software bundled with drivers for your PC operating system.
4) Insert the CD to your CDRom drive.
5) After step 4, you will see a window saying install PCSuite then choose Yes.
6) Choose which operating system. If you use Windows 98, then choose the driver for Windows 98.
7) After installation, reboot/restart tour PC to complete the setup process but never disconnect yet your USB Cables from your mobile phone to PC.
8) Once restarted click on the icon of the PCSuite on your PC, then check if your PC can communicate with your mobile phone and vice versa. To do this click connect via USB if the datas in your mobile phone is seen then connection is correct.
If your problem is USB Driver for Windows 98, i suggest you upgrade your PC operating system to Windows 2000 or Windows XP. Old operating platforms have driver problems when new devices are attached to. But if you choose Windows 98, you will have to browse the internet in search of drivers. Just let me know if you have not found a driver. I'll assist you with this.
Jul 03, 2008 | Microsoft Windows 98 for PC
Win98 USB Driver
Im afraid your out of luck. Unless the printer or storage device you are using came with one or you can get them for their support website that is the only way.
Jun 30, 2008 | Microsoft Windows 98 for PC
Possible usb malfunction?
hi,
well xp is a better OS than 98 ( i think) ...
few things you should know that xp is pre-installed with lotsa drivers..but on the other hand 98 isn't .. so each time you put in a USB device you need to install the driver for that device( eg your camera, pen drive etc...) . this drivers would be there accompanied with your device.
hope it helps
regards
bzoy
Jan 14, 2008 | Computers & Internet
Need driver for this camera for windows 98
debra_s,
You'll have to explain what you want to do? If you want to download your images, you don't need a driver, just attach a Windows 98 compatible card reader to your USB port and download your pictures to your favorite photo manager. You should be able to attach your camera via USB, and if the USB drivers detect the camera's disk, then a new drive will appear your My Computer.
If you have Windows 98 Second Edition, you should be set to go, if you have Windows 98 First Edition (where it doesn't say Second Edition in the My Computer properties), you'll have a tougher time with the USB connections. It would be best to upgrade your machine, or find the Windows 98 SE upgrade from a friend.
The CD that came with the camera will have the necessary software for Windows 98 SE.
What have you tried to do? What isn't working? Let me know some details and I'll help you out.
Hope these ideas help. Clarify some things and I can give you a more narrow answer.
Nov 14, 2007 | Nikon D40x Digital Camera
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
