Question about Fujitsu fi-5120C
How do I set up my scanner to scan multiple pages at once, without having to keep hitting the scan button. ( fi-6140 )
  • 3 Answers
Hi, are you using Scannedallpro software? If so, press the batch scan setting button (2nd right after the white drop down menu). This will give you access to your settings. Select add, name your new profile appropriately, then select SCAN, Click SHOW CONFIRMATION WHEN NO PAPER IN ADF, then click on Detail Scanner Settings. This will take you to your options screen. Select either Duplex, for double sided or ADF Front side for single sided. You can choose to drop out blanks by clicking on the OPTION button at the bottoms of the screen, then JOB/CACHE, click the selection button for Blank Page Skip and choose the sensitivity. (I usually use a low setting). Click OK.
when happy with your settings click OK again, then apply.
Use your new profile to batch scan. The system will scan until the hopper is empty and should ask if you want to continue with the same batch scan, allowing you to add paper until the job is complete.
NB Always ensure you have selected Multi Page Tagged Image File Format as the system will not save your scan as one document without it.
Hope this helps!
Posted on Dec 14, 2010
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
I am scanning multiple pages at once however I want them to all save as separate pages onto my computer. how do I set this up? It doesn't seem to be working for me.
when you feed multiple pages i guess you are hitting the star button
in order to save them as separate pages you will need to select finish key not the start key this finish key is added with firmware if it is not on your copier already you may need to have a technician do this for you. good luck hope this helps.
Feb 19, 2014 | Konica Minolta Bizhub C224 Color Copier...
Fujitsu fi-6140 scanner making ticking noises during scanning
The tick tick noise is produced when the gears in the ADF upper unit is worn off. You are recommended to contact a Fujitsu expert for replacement of the faulty gears.
Thanks,
ScanCare
Jan 25, 2012 | Fujitsu FI-6140 Flatbed Scanner
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Fi-6140-Rollers keeps moving even when doc feeder is empty.
There may be a piece of paper stuck in the sensor area, the scanner assumes there is paper and it keeps working. Blow gently and remove all shreds of paper.
S. Mohan
Aug 09, 2010 | Fujitsu fi-6140C Document Scanner Flatbed...
Don't know how to set scanner for multiple page scan into single pdf file
The supplied Canon software is horrible, but it can be done!
Launch ScanGearStarter, choose advanced tab and click preferences button, then select scan tab.
Untick box "Automatically quit ScanGear....." then click ok.
(This box being ticked totally prevents multipage single file scanning).
Now choose simple mode tab, select the document type, dpi and document size.
Now click the green "Multi Scan" button, place the document on the scanner glas and press next in the new window.
The page will be scanned and the ScanGear window will return, just click "Multi Scan" again and place next document, press next. Keep repeating until all pages are scanned, then close the ScanGear window.
This will bring up a third window showing thumbnails of each page, any of these pages can be deselected if required.
The other important step is to choose from the pull down list Saved as Type: "MultiPagePDF".
Choose the location for saving the file and click save.
Hallelujah! .......stupid software.
Jun 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Number of Pages the fi4120c will scan
Try to get to the separation rubber and clean it.
Nov 04, 2008 | Fujitsu fi-4120C Path-Through Scanner
Blank Pages
The scanner's paper sensor may be jammed. IT is sensint there is paper and hence scanning!. Try and fix it. Sensor may be optical or mechanical. If optical remove shreds of paper or dust. If mechanical ensure it moves forward and backward.
S. Mohan. Chennai
May 09, 2008 | Fujitsu fi-5750C Flatbed Scanner
Scanning trounleshooting
Open the paper feeder tray gently. see the rollers which intake the paper. Clean softly those rollers and tray with a dry medium. Pleasedo not touch any senser there. Read the open instruction from manual.
Aug 20, 2007 | Fujitsu fi-5120C
Fujitsu fi-5120C Logo
814 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
