Question about Canon Ultura Mini DV Digital Camcorder
I own a Canon Ultura Camcorder. It currently won't power on. I tried to charge the camera by plugging in the adapter, but the charge light will not come on. I thought there might be a problem with the adapter cord, so I bought a universal battery charger last night. The battery was fine. I put the charged battery back in the camcorder, but it still will not power on. Do you have any ideas on what the problem might be? I called Canon, but they won't help me because they no longer service this product.
Hi, I own a Canon Ultura as well and just ran into the same problem as you. Were you able to find a solution? Any advice would be greatly appreciated. Best, Josh
Posted on Mar 16, 2015
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Nov 10, 2010
I have an older canon mini tape camcorder and my mac pro wont recognize it for uploading
You could try the cannon website to see if there are any driver updates for your model. Cannon may have a users forum, which you might be able to pin point the problem there, If that doesn't work try the mac website for updates etc.
Feb 09, 2013 | Canon Ultura Mini DV Digital Camcorder
My hp does not recognize my canon ultura camcorder why?
have you use firewire cable? because USB won't work!!! make sure your camera in on and on play mode .
Apr 05, 2010 | Canon Ultura Mini DV Digital Camcorder
Camcorder will playback ,but shows no image when recording
Can you make it go while attached to a Power Adapter ? and with battery OUT, try that first. IF it works, buy a new battery for that model. Batteries can go so flat they cannot be charged, without special equipment,and even then they may not resurrect. funnily enough, leaving things without current running through them, or powering up,every few weeks, etc, can often cause a problem, strange huh?
Mar 23, 2010 | Canon MV700i Mini DV Digital Camcorder
My jvc camcorder GZ-MG37U will not charge
Camcorder has charging circuit but it could go defective. The repair would be costly so in this situation, you can purchase stand-along battery charger for around $20 and charge the batteries independently. Make sure all the contacts are cleaned and camcorder is working with direct ac adapter. Good luck -James. for furnter assistance by email, go to www.camerarepairjapan.com
Feb 11, 2009 | Canon XL2 Mini DV Digital Camcorder
I am trying to load my video recording to my PC
I experienced the same thing. The compact power adapter is simply the power cord used also to recharge the camcorder. Plug it into the wall at the same time as you have the USB plugged into the computer and it should be able to download.
Jan 27, 2009 | Canon FS100 Flash Media Camcorder
Can't connect ultura via USB to apple computer
Canon camcorders use DV or firewire cables. If you have a connections for that on your iMac all you need is a firewire cable.
Dec 23, 2008 | Canon Ultura Mini DV Digital Camcorder
Charge Indicator light on HV20 never lights
The battery was shipped dead. I charged it over night and the light started working.
Sep 11, 2008 | Canon HV20 HDV Digital Camcorder
Canon ZR500 no Charge light
From what ive been told, you might have a blown fuse. Unfortunately it is just any regular fuse its a micro fuse. It is at the edge of the motherboard with the etching H or K there are 4 of them. You can test to see if there is conductivity, if not than it could be the fuse, you can replace it or try to solder over the fuse...that would be dangerous but your camcorder will work until excess current fries it. IF not it could be a loose circuit.
Dec 03, 2007 | Canon ZR500 Mini DV Digital Camcorder
Digital video camcorder
Try the most obvious solutions first; making sure the AC adapter for the camera is plugged into the camcorder-- and the plug orientation is correct if applicable, and it is in turn plugged into the wall.
Is the wall outlet working? Try another location in your home to be sure. Is the AC adapter working? If you have a battery, attach it to the camera and see if it charges. Next, look for obvious outward physical damage to the camcorder that could cause it to stop working.
The thin battery you speak of if generally just for backing up the time and date, and is not needed for operation.
The power switch on Canon models is usually a slider that goes from Manual to Auto to VCR mode. If it is dirty or wearing out, move it a small amount to one side or the other, while watching the LED power indicator. If you see it flash, or light dimly, the switch is bad.
Read the manual-- the unit may have a reset function you can access, or require a tape in it to power up. Hope these help.
Nov 18, 2007 | Canon ZR70MC Mini DV Digital Camcorder
Power Failure
Check the output from the AC Adapter first. If no good, battery not charging/dead so nothing works. If good, camera needs service - could be anything. There is probably at least one surface mount fuse.
Aug 20, 2006 | Canon ZR60 Mini DV Digital Camcorder
Canon Ultura Mini DV Digital Camcorder Logo
154 people viewed this question
Top Canon Video Cameras Experts
Chance Miller
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
