Question about Toys
My R2D2 bot quit running around.He still makes his sounds,just will not move.He has fresh batteries never been dropped or been mishandled by kids. How do I fix him?
  • 528 Answers
R2D2 has plastic drive gears inside - finding replacement gears will prove to be a major challenge, let alone trying to INSTALL those gears. Your only hope is if it is still under warranty and you have all the original packaging, warranty card and receipt. They pretty much bank on you throwing all of these items away, blocking the return. I suggest contacting the store or outlet you purchased him from for return information, as it should have a 1 year warranty on it.
You can also try contacting the manufacturer for warranty info - maybe they'll send you the replacement gears in the mail, as they could be shipped in an envelope.
Good luck!!
Posted on Nov 10, 2010
Testimonial: "Thanks a lot.I would have had no idea about that being the problem."
Quit moving
Have you tried replacing the battery?
Jul 19, 2012 | Citizen EcoDrive Calibre 8700 IonPlated...
Just started making "clicking" sounds with a deep
Mine did this also. A regular popping on and off of the Noise Canceling feature, making it impossible to hear music/sound. If while this is happening your green battery indicator light is flashing on and off with the rhythmic popping on/off of the NC, try replacing your AAA battery with a new, fresh battery. I did, and all was well again. I had to do this twice since the first replacement battery came out of the TV clicker and were too warn to fix the problem (ran out of AAAs, it was raining, and late at night, etc...you know the Emergency battery replacement drill - run around the house shamelessly cannibalizing the kid's toys, Grandpa's insulin pump, the wife's ********...whatever you can find). Anyway, the next day I sprung for a new set of Energizers and all was well with the world again. Hope this helps.
Feb 22, 2011 | Bose QC15 Headphones
Camera turns off when snaping a shot
its either broken or something in it needs to be moved around in it,this happens often becuz sometimes they can get dropped or mishandled,take it to an expert or buy a new one.
May 31, 2010 | Polaroid i631 Digital Camera
R2d2 robot has a voice but is not moving. Any handy fixes you can recommend? Could it be a low battery? Carolyn
With your R2D2 make sure his red button is not engaged as this stops him from moving. Be patient with this toy and read the instructions carefully he is an amazing robot to own and play with and will suprise you as he did with our family.
Jan 24, 2010 | Toys
1988model starter does not engage more often than it does engage
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} What is the difference in the sound when it engages and when it does not?
What does engage mean to you.
To me it means a loud click sound followed by the engine cranking.
Actually engage is just the click sound.
Cranking is the small electric starting motor forcing the engine to move as if it were actually running. Once it moves just a bit a spark plugs fire and the resulting explosions makes the engine keep going until one of the following happens.
Loss of air/fuel mixture (i.e. run out of gas or air intake blocked)
Loss of spark (i.e. battery low or dead, bad coil, bad plugs)
The two above do not come together at correct time (timing)
Something physically stops the engine from continuing to operate (engine seizes, too much load)
If battery is low starter will not engage or crank.
If electrical connections are bad (usually loose or dirty) current will not flow properly and starter will not engage or crank.
Both can be checked with a multi meter.
Measure battery voltage when attempting to start.
It should be 12-13.2 volts and should not drop below around 10 volts
If it is not dropping but still not engaging/cranking, continue to take voltage readings move from battery toward the starter. When you find a sudden voltage drop, investigate wiring just before that point upstream toward the battery.
Nov 14, 2009 | Harley Davidson FLSTC Heritage Softail...
My 55-200 automatic lens will not auto focus on the lower focal lengths, but will on the longer ones. It hasn't been dropped or mishandled and the standard lens works fine. Nikon D40
From the sounds of things it sounds like a part is worn in the lense, my advise is to contact Nikon and send away to be repaired, they have a great service department. I have used them and they are quite inexpensive to.
Oct 29, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
I lost instructions for r2d2 i need to know all comands
duh,,, the best solution for you is to move out of you parents house and start watching big person movies!!!!!!1 40 year old nerd!!!!!
Apr 03, 2009 | Computer Gear R2D2 Doll Doll
Peg Perego John Deere Gator not working at all
It sounds like you need a pedal switch or it has a loose connection in the wires. It is a specific Peg Perego Switch that will fit under the foot pedal. I have a gator that was doing the same thing so i replaced the shifter switches and the foot pedal switch, but I bet you could start with just the foot pedal switch.
I bought mine at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html but you could also call them as well.
Hope this helps
Dec 21, 2008 | Peg Perego 12 Volt Rechargeable Battery
Toys Logo
267 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
