Dell 5150 blue screen error Stop:ox0000007b (0xc0000034,0x00000000,0x00000000) doesn't allow safe mode
  • 11,800 Answers
0x0000007b - INACCESSIBLE_BOOT_DEVICE this means that the hard disk can't be accessed because there's a severely corrupted bootloader or registry file. The only way to reliably fix that is to reinstall Windows. If the problem returns quickly then the hard disk is about to die - replace it and reinstall one more time.
Posted on Nov 10, 2010
COMPUTER - BLUE SCREEN
what is the error of the blue screen showed? etc Stop :0X00000FE
Jun 08, 2012 | Dell Computers & Internet
Im haveing unexpected shut downs on my laptop? and i can onl use it in safe mode. how do i fix it to regular mode with oout it shuting down again?
When you boot it up that same screen that gives you the safe mode option will probably give you an option to disable or stop restarts on boot. This will allow you to see the error message. Since you can get into safe mode try doing a System Restore to a day before the problem started. System restore does not destroy your data, docs, music, pics, or videos. System Recovery destroys everything and sets the system back to when you first purchased it. If system restore does not work you'll need a system disc to fix the blue screen by running a chkdsk /r command at the dos command line prompt. Chkdsk will run for an hour or more so be patient. If chkdsk doesn't solve it then you probably have a memory issue. I would remove one memory chip and reboot, the if you have a problem move the chip that is inside to the next slot and reboot again. If if fails on both slots for that chip, set it aside and insert the other chip and do the same thing.
Mar 19, 2012 | Dell Convertable Inspiron Duo Notebook...
Hi, Everytime I turn on my DELL Dimension 5150 I am faced with the following message: A problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE...
This sounds like it can not mount your boot file from hard drive which needs to load windows. Sometimes this will happen if you leave a floppy, cd or some kinda usb flash drive in computer when rebooting and it does not happen always. I would try to boot in to safe mode as message is saying. To boot in to safe mode modet computers use F8 key. Turn off your pc and then as soon as you push power button start tapping key F8 located on top of keyboard. You can stop once you get screen that says Advanced startup menu. Choose option Safe mode and press enter. You will need to use arrows to make selection. Once you choose safe mode wait for the loading to be done and then choose ether your windows name or Administrator. Once in safe mode you will get error message just ignore it and press yes. When windwos comes up try to do a restore to previous date. Go to start-programs-accessories-system tools-system restore.in system restore choose restore to earlier time and on the calendar choose date that your computer was working fine. I usually go even week prior to when computer stopped working. Your data will be saved but if you have installed some programs you might have to reinstall them. Hope this helps.
Nov 06, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Haii.. i got a dell dimension 5150 pc desktop the problems is always when i boot time ,its shows a blue screen thats tells the system have to shutdown and check ur hard disk,i have changed the hard disk...
Boot machine then press F8 till u see Advanced Boot options, then go into Safe Mode with Networking and follow instructions on the link below to turn off Auto Reboot on Blue Screen.
http://www.tunexp.com/tips/maintain_your_computer/disabling_blue_screen_of_death_auto-reboot/
Then, get BlueScreenViewer application to Debug what is causing it.
http://www.nirsoft.net/utils/blue_screen_view.html
Do a Find on the site for the word 'Download'
Sep 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Blue Screen error, Windows not loading, How can i reset Password?
Vist this page.
you can diagnose the error with STOP: 0x0000000A error.
Go to http://www.make-pc-faster.com/ and visit Blue Screen column.
Feb 28, 2010 | Dell LATITUDE D400 D500 D505 D600 D800...
Stop: c000021a {fatal system error}
start in safe mode with command propmpt and type chkdsk /r/f and let the system get scan.
Jan 20, 2010 | Dell Inspiron Notebook
Windows xp tries to start in safe mode screen then as program starts gets brief blue screen then back to safe mode start selection screen once again this keeps repeating
your system will do this as it has shut itself down to protect itself, to make the blue screen stay on so you can write down the error code (e.g stop 0x0000007B),you need to choose the option of `disable automatic restart on sytem failure` (this will be on safe mode screen, reboot, then when you get the B.S.O.D it will stay on and display an error code, google it and you get the answer or post the code on here and i`ll tell you
Jan 14, 2010 | Dell Latitude D800 Notebook
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
Computers & Internet Logo
152 people viewed this question
Alun Cox
David Payne
David Payne
