Question about Whirlpool RBD245PDS Electric Double Oven
I have a Whirlpook Double Oven Model #rbd275pdb14. Everything works but the bottum oven will not come on at all, the lights work but no heat? can you help me please? can't afford a new stove too close to Christmas.\r\nMy name is Vince....
  • Vincent Shepherd Nov 10, 2010
    The Oven temp. sensor circuit or the ERC, is this something I can repair? or is this a job for a professional(I am electronicly inclined). If so, how much might this cost? just trying to see if I need to look for a new stove.....
  • 4,323 Answers
Hi Shepherdvinc
It means failure of oven temperature sensor circuit. Check that the reading of oven temp. sensor circuit is not more then 1100ohms.If so, then it will be required to be replaced otherwise it is the Electronic Range Control (ERC) going bad & needs replacement. Hope this helps...you can post back if you need further assistance.
Daniel
Posted on Nov 10, 2010
  • Daniel Scott
    Daniel Scott Nov 10, 2010
    Hi
    You'll need a multimeter to check the oven temp sensor for continuity. Remove the oven temperature sensor probe(par and disconnect the two wires. The temperature sensor probe is likely removable from inside the oven cavity (Check the diagram). Disconnect the sensor and with multimeter leads on either end of the sensor wire check for resistance, it should read between 1050-1100 ohms. If the value deviates from this range then ERC is faulty.
    Part#29-- Temp Sensor
    Part#3(ERC)---
    You can buy the parts from this link---
    Whirlpool Double Oven Model #rbd275pdb14 Parts
    ERC- $120-125
    Temp sensor- $70
    Hope this helps... Please post back if you need more information.
    Daniel.
Whirlpool RBD275PDB14 Double oven digital display board off.
Had the same problem. I repaired the board myself and ordered a replacement from sears parts direct. It is a repaired board not a new one but has the same warranty. You can get this board a lot faster. Here is the link. http://www.searspartsdirect.com/partsdirect/part-number/8302319R/0022/664. If you would like to repair your own board leave a post and I will help you.
Nov 16, 2011 | Whirlpool RBD305PD Electric Double Oven
Neff oven not heating have replaced fan element
it has to be the temperature control itself...thats the only other component, aside from the high-heat cut out switch which rarely goes bad.
Jun 05, 2010 | Neff U1721 Double circotherm Electric Oven
No heat! Lights work, timer etc - everything "appears" to be working but there is no heat!
Probably your heating element has failed, dependant on appliance the element can be found in the oven itself at the back behind a panel that normally has a couple of screws holding the panel in place. reasonably easy to fit yourself and not very costly.
Hope this helps
Apr 01, 2010 | Whirlpool RBD305PD Electric Double Oven
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
My AEG Electrolux fan assisted oven does not heat up. The lights and everything works just no heat.
If the fan and light work o/k, then you need to replace the oven element.
Please rate my solution.
Thanks.
Nov 02, 2009 | AEG U3100-4 Electric Double Oven
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Jan 04, 2009 | Neff U1721 Double circotherm Electric Oven
Fan oven not heating up
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Whirlpool RBD245PDS Electric Double Oven Logo
313 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
