Question about Kenmore 57029 Side by Side Refrigerator
I have a Kenmore side by side Model 25351694100 that makes ice great, but will not dispense. I hear things moving, but no ice comes out. Can I fix this, or do I need a pro?
  • Kenmore Master
  • 1,344 Answers
Usually when this happens its becasue the auger, located inside the ice bin itself, has came loose,or popped out of place. If you have the kind of ice bin that slides in, pull it out and dump th ice. You'll see a long, metal twisted rod that runs front to back. At the back side of it is a white cap that the rod attaches to and mounts in a hole in the ice bucket itself. Sometimes you can readjust it and it will work but sometimes you may have to buy a new bin if any of the plastic is broken.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on Nov 10, 2010
Kenmore coldspot refrigerator model 52552100 makes ice but wont dispense it
Below is a fix by another owner of your make and model for the same issue.
Pulled out ice bucket; tried ice dispenser with door latch pressed in and solenoid engaged and motor moved. Tried again and nothing (couple of times). Tried water...all good...good closure of dispensor flap (air pot operated). Opened dispenser (pried off carefully from bottom on this unit not to take off the glued part) and saw the micro-switch broken off of the ice dispenser side. Checked micro-switch (all good). Replaced control bracket...all good to go.
Nov 25, 2016 | Kenmore Refrigerators
I have a problem with my Kenmore side by side refrigerator model # 106.56926600. The icemaker when pressing the dispenser lever from the outside of the door.I hear the ice coming from the ice maker to the...
Your question is worded in a way that I might not be interpreting it correctly. I am guessing that it is making ice but not dispensing,or going into your glass when you push the lever, right?
So when you push the ice dispenser lever do you hear a "click" like you do when you push the water lever? Push them slowly and listen.
If no "click" is heard then it is most likely the bracket that holds the dispenser switches. It is made of plastic and very prone to breaking over time especially if children are using it. Part# is WP2180226 and be aware that this is under live voltage so if you are not mechanical then do not attempt yourself and please call a pro to fix.
If you hear a "click" then can you hear the motor turning inside? If yes then it could be something as simple as a block of ice stuck in the bucket preventing the ice from coming out. The owners manual recommends to dump the ice to avoid this roughly every two weeks but most people never do.
Jan 27, 2018 | Kenmore Refrigerators
Model FRS26R4AB5 Frigidaire ice maker. Unit makes ice but will not dispense. When engaging in-door dispenser switch, I can hear the motor come on, but the auger does not move. This occurs even with the...
pull the ice tray out, you will see a silver thing in the back that turns the auger,, push the ice dispense button ( you might have to hold the door switch in) and see if it turns, if it does you need to replace your ice tray,, if it doesn't you will need to replace the solenoid or the motor itself
Jan 24, 2011 | Frigidaire FRS26R4A Side by Side...
Kenmore side by side fridge - ice dispenser stopped working
You might check out this site and ask a question. They have drawings on many of the fridges and I have bought many parts from them.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Refrigerators
Whirlpool Side By Side not making Ice, but water dispenser works
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Mar 15, 2009 | Whirlpool ED5VHGXM Side by Side...
take out ice bin, make sure you get it lined up when put back together, should click,sometimes they are a little off and you have to keep trying, mine has that defect, it works, but only on its terms, its a pain to do, but that can stop it from working due to a safety thing
Oct 30, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice through dispenser
When you operate the ice dispenser lever, you should be able to hear a little click from a micro-switch that then switches the auger motor and the light on and also opens the flap. If you cannot hear this small click, then the micro-switch is faulty. The ice dispenser only works when the freezer door is closed, so you could also inspect the door light/fan switch for proper operation.
Oct 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore 57029 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
