Question about Husqvarna Hand Held Blower 125 B Grass Leaf Blower ()
Need to remove stihl blower flywheel - Husqvarna Hand Held Blower 125 B Grass Leaf Blower ()
Stihl blower won't spark.
check the key in the flywheel,any wear in the key can cause it to be out out of time and it will cause no spark at the spark plug.
Jun 06, 2015 | Stihl Garden
How to replace a flywheel on a Stihl bg55 leaf blower,
it may. just make sure it's centered.
Feb 18, 2015 | Stihl Garden
How to change flywheel on bg86c stihl blower
  1. Remove fan housing
  2. Remove spark plug and install piston stop.
  3. Remove flywheel nut.
  4. If flywheel is struck on use a puller. Stihl uses a knocker type puller that screw on the crankshaft and tapped by a hammer. Be carefully not the damage the crankshaft stud or the bearing.
  5. To install reverse the above skipping item 4. Just make the flywheel engages the slot in the crankshalf. The flywheel nut is torque to 17 nM or 150 in lbs. Don't over torque the nut or damage will occur to the flywheel.
Dec 16, 2014 | Stihl Garden
How to remove a flywheel from a stihl bg55 leaf blower
Here the instructions from BG series service manual.
Dec 02, 2014 | Stihl Garden
How to set the timing on sthil blower br600
you can only adjust the coil to flywheel gap... timing for the flywheel is preset and un-aqdjustable
Aug 31, 2013 | Stihl Magnum Br600 Professional Backpack...
How to fit coil into a br 400 stihl blower
located by the flywheel, held on by 2 screws. When setting the timing gap it should be 0.25 feeler guage.
Aug 20, 2013 | Stihl BR400 Backpack Leaf Blower
Bg86c stihl blower no spark new spark plug new coil gapped right take ground wire off still nothing
Sounds like a tricky one. Have you checked the magetism/functioning of the flywheel.? Tracking back the problem by having a new spark plug and coil would next point you to the flywheel. Coil to flywheel gap should be 0.25 feeler guage.
Hope this proves useful. :)
Mar 15, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
Replaceing keyway
If the timing is out and the keyway on the flywheel is damaged then you must replace the flywheel. There are ways to 'bodge' the flywheel but its not worth potentially damaging the machine.
Flywheel part number is: 4203 400 1200
Feb 26, 2013 | Stihl Br420c Magnum Leaf Blowers
Husqvarna Hand Held Blower 125 B Grass Leaf Blower () Logo
667 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
