Question about NetGear Computers & Internet
I am trying to install my netgear Universal Wifi Range Extender WN2000RPT. I have green lights for my connection to the router, the extender is on and it is connected to the main PC. But I only have local internet access. I put in my correct passkey and it's still not allowing me to go online. What can I do about this?
  • Anonymous Mar 22, 2014
    Difficulty in installing
  • 4,281 Answers
For that you need to check WAN settings and also make sure local ip settings gateway should be your router ip address. Make sure WAN settings are fine connect internet cable to WAN port of router. Then check. You can configure router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 10, 2010
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
Gigabyte b49g wont link with wireless extender
first, Keep in mind that you bring the device into the same room as your wireless router.Use NETGEAR, Linksys Router.
second, Green LED on the extender is showing green to be able to get the optimum performance on your devices.
third, if not get it than just reset to factory defaults
then manually changed the security settings for your router .
Apr 14, 2014 | Gigabyte GN-B49G Router
Setup wizard
the password should be the same password of your wifi on the router...
Aug 21, 2013 | NetGear WN2000RPT Repeater
Why can't i connect to mywifiext.net
3 lights on every time last two days one light is on first last we dont on its the problam
Sep 30, 2011 | NetGear WN2000RPT Repeater
I just installed my netgear extender WN2000RPT and the connection bar is strong but i cannot go online
Are all lights green on the front of the device? If you were to remove the extender, do you still have Internet access?
Feb 20, 2011 | NetGear Computers & Internet
Hi, I have a universal wifi range extender wn2000rpt installed and a wireless adapter installed aswell. Now reading the next set of instructions it tells me to connect to NETGEAR_EXT, open a browser and...
NETGEAR_EXT is the name or SSID of the extender. ie Netgear EXTender ;-]
What you need to do is first search for available wireless networks. It should show up there as NETGEAR_EXT if it is running and far enough away from your wifi.
Then open your web browser which should then open the connection wizard . If not you can try www.mywifiext.net. If you can't see it you may need to connect to it using a wire so you can set it up. sometimes if it is really messed up you may need to reset it to factory default.
Nov 11, 2010 | Computers & Internet
Do not know where to find NETGEAR_EXT
hi, I have a universal wifi range extender wn2000rpt installed and a wireless adapter installed aswell. Now reading the next set of instructions it tells me to connect to NETGEAR_EXT, open a browser and type in a http to recieve the wizard to connect the extender to the router. But i cant find this NETGEAR_EXT the only thing i have to it is wlan_ap_EXT which i cant connect to.
Oct 29, 2010 | NetGear Computers & Internet
Computers & Internet Logo
470 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
