Question about Stairmaster 4400CL Stepper
When I input all of my stats when i get to time and press enter the machine starts over again. Will not do the program choice (fat burner, fat burner plus etc.)
I don't have a solution but have a 4400CL with the same problem.....does anyone have an idea what is wrong? I called the Sportsmith tech assistance and was advised that the panel is no longer working and it is very expensive to replace. It does work int he manual mode. The tech support at Nautilus said that the battery was bad and not providing enough power but the tech at Sportsmith said that could not be it because there is resistance to the pedals on start up. Any thoughts
Posted on Feb 09, 2011
I have a Stepmill 7000 pt. I have a terrible time trying to start a workout program like quick start, manual, fat burner, etc. I have to push the program button multiple times to start the program.
It sounds like you may have a faulty keypad. The following link will take you to this item. Stairmaster Stepper 7000PT Stepmill Parts Transmission SPORTSMITH net You might also be looking at a faulty ground or insufficient power coming from your power supply. Check this out put with a multimeter. You should be getting between 12-19 volts DC.
Dec 05, 2017 | Stairmaster Stepmill 7000 Pt
Adding new PLU problem keep getting PLU Program Error
Those machines have a memory allocation section where you need to define the file sizes for products, etc. If your file size is smaller than the machine you are copying from, then it wont work. Try setting the memory allocation first.
Apr 04, 2014 | Samsung SAM4s ER-650 Cash Register
Guided input for Distributions
Press the Mode button/key. Scroll down to the line Stat Wizards and highlight ON. Press ENTER. to validate the choice. Exit the Mode setting. Now Press the key sequence [2nd][VARS] (DISTR) to access the distributions. Scroll to find your distribution, select and press ENTER. You will have your entry screen.
Feb 12, 2014 | Texas Instruments TI-84 Plus Calculator
Where is the reset button on a TI-84
Instructions
Enter the memory options by selecting "Mem." Press the "2nd" key followed by the "+" key. Select "Reset" from the memory choices. Use the arrow key to select and delete all memory.
After choosing to delete all memory, select "Reset." After this reset, your screen should show "Mem Cleared." Once you have reached this screen, press "Enter." If you installed programs or applications, you may need to remove them manually. Once again, enter the "Mem" command.
Press "2" to select Memory Management. If you are deleting programs, input that option from the subsequent menu choices. If you need to remove applications, input that choice and press "Enter. Select the application or program from the list displayed. Press "Del" to request the deletion. Choose "Yes" to confirm your choice.
Repeat this process to delete remaining programs manually. After completing this, exit the memory menu and press the "Apps" button. Make sure no applications remain. Additionally, press the "Prgm" button, and check that all programs have been removed
Aug 29, 2012 | Texas Instruments TI-84 Plus Silver...
How should I set my ti 83 plus for my statistics course? I keep trying to sort L1 in ascending order and every time I get ERR: INVALID DIM 1: QUIT ...
If some of the lists are missing press the STAT button then select SetUpEditor and ENTER to restore all of them (without data, of course.)
If the statistical plots are turned OFF you can turn one of them back ON again. Press SHIFT Y1= to access STAT PLOTS. Press 4:Plots Off. A good habit to avoid problems. After you turn all plots OFF, you must turn one of them ON if you intend to draw statistical graphs. You can for example Turn Plot1 ON.
  1. To do so Press SHIFT Y1=, select say 1:Plot 1 ENTER.
  2. Highlight ON and press ENTER.
  3. Press DownArrow to move to line TYPE
  4. Then you can set the plot type. You have 6 choices. Use the left/Right arrows to select one of the 6. The selected plot type icon will remain highlighted when cursor is moved.
  5. Use DownArrow to move to XLIST line and select the x-values LIST. etc.
  6. When finished Press 2nd QUIT to exit the stat plts configuration settings.
One statistical value that may be of interest to you is the R, R^2 coefficients. To have it displayed (if the regression model has it), you must set DiagnosticsON.
Press SHIFT 0 to enter catalog. Press x^-1 key to jump to the first command that starts with D.
Scroll down to reach DiagnosticsON, highlight it and press ENTER then ENTER.
Sep 16, 2011 | Texas Instruments TI-83 Plus Calculator
Switches to "Quick Start" before I enter all information
The Maintenance Mode allows you to query and modify the basic settings of the Star Trac Pro
Stepper.
Engaging Maintenance Mode
Press and hold the0 , 2and OK keys together.
A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information
window.
Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode
The following keys are used to modify Maintenance Settings:
Upper and Lower Data Information Window SCROLL keys: Display the next and
previous settings.
Increase and Decrease Level Keys: Adjust the value of the displayed
setting up and down respectively, in increments of 1 unit.
OK Key: Updates (saves) the value of the display setting in the Flash memory, and exits
Maintenance Mode.
The Keypad Test can be used to verify that all keys are functioning on the display assembly.
To engage the Keypad Test
Enter the Maintenance Mode (see Settings – Maintenance Mode).
Press until Keypad Test is displayed in the information window.
Press to enter the Keypad Test.
Press each key on the display. Each time you press a key, the information window will display
which key has been pressed.
To exit the keypad test, press .
If any of the keys do not respond, they may not be functioning and the display keypad must be
replaced.
Jan 23, 2010 | Startrac Fitness Products Sc4130 Star Trac...
How do i find the variance if i'm given the x
Set the [Mode] to [3:STAT]. You are offered the choices
1:1-Var
2:A+BX
3:__+cX^2
etc.
If you want to do 1-Var statistics, you press 1:1-Var. A column template opens where you put the X values. If a value is repeated you enter it several times. (there is no frequency column.)
When you enter all data you press [SHIFT][STAT]
You have several choices among them
4: SUM to get SigmaX^2 and Sigma X
5: VAR to get n, the mean X bar, the sample and population standard deviations
6:MINIMAX to get MinX and MaxX
7: Distr the Distributions.
If you want to perform 2-Var statistics
You press [MODE][STAT] and select one of the Regression models
2:A+BX
3:__+cX^2
etc.
The selection of any of the 7 regression models, opens a two-column template where you enter the X and Y values
When finished press [SHIFT][STAT]
The choices offered are
  1. Type takes you back to select type of statistics to perform
  2. Data To edit the data in the columns
  3. Edit To insert or delete a value
  4. SUM To access the calculated values of SigX^2,SigX,SigY^2,SigY,SigXY,SigX^3, SigX^2Y, SigX^4
  5. Var : To access the calculated values n, Xbar, Sample STD for x, S STD for Y, Pop STD for X, and Pop STD for Y
  6. MinMax : MinX, MinY, MaxX, MaxY
  7. Reg: Gives you the regression coefficients for the particular regression model you want to test.
The mean is represented by X bar.
The variance is the SQUARE of the Standard Deviation.
Hope it helps.
Nov 06, 2009 | Casio fx-300ES Calculator
MFC-8820D we have moved our office and have a new phone numder. How do we re program that number into our fax. Thanks matt
The following procedure will reprogram a new station (home fax number) for your machine. Thank you for using Fixya and please post back with any questions or to rate the answer provided.
Greg
  1. Press MENU 0,3
  2. Enter your new fax number (if the old still exists, move the cursor/arrow back ward to the first position to change the number displayed
  3. Press SET
  4. Enter telephone number (if it's the same as the fax number, enter the fax number again)
  5. Use the dial pad to enter your name (if your name still exists, leave it as it reads)
  6. Press SET
  7. Press STOP/EXIT
You will be given a choice to press 1 to continue with the change or 2 to exit without changes.
Press 1
The date and time will now appear and the change is complete
Sep 10, 2009 | Office Equipment & Supplies
Sharp 5316E how to enter code
Did you mean the account control code ( 3 digits code ) ? If you forget this code, either you disable the account control mode or change the old user accounts. Here's how :
1. Enter the USER MODE PROGRAM by pressing and holding the Light key indicator ( the white half circle ) at the bottom left of the machine.
2. After the all the lights at the panel goes off ( except the quantity copy display, it will show 3 lines ). press 10 with the 10 key and START, change the value from 1 to 0 and press START again to save the value. THIS IS DONE TO DISABLE THE ACCOUNT CONTROL MODE.
3. If you want to show the user account and cange it to a new account, repeat the above step but enter 12 instead of 10 and press START. It will shows you your current user accounts ( up to 20 accounts ). If you still want the old user account, remember that code and press the light exposure key 1 more time withou holding it.
4. If you want to change the old user accounts, after the machine shows you the user acccount press START and input the new 3 digits code and START again.
May 26, 2009 | Sharp Office Equipment & Supplies
Boot in TASCAM 2488
thiagofo,
Formatting of the hard drive is outlined on page 66 of the 2488 manual (assuming this is the old grey 2488 and not the newer blue MkII).
In case you don't have the manual handy, you can either format the entire drive (excluding the fat partition) or just one of the partitions. There is also another option to refrormat the fat partition.
To format the drive, (and create new partitions), go to the 'disk' menu, highlight 'format' and press 'enter'. You'll be asked to specify the new partition size (all partitions will be the size you choose). The press 'enter' again to proceed with the format. A new blank song will be created on each partition. Do not power off the 2488 while the format is in progress.
To format a single partition, from the 'disk' menu choose 'reform' and press 'enter'. You then choose (by highlighting) which partition you want to format and press 'enter' to format. You'll get the warning/confirm message and press 'enter' again to proceed.
The fat partition (visible via usb from a PC) can be formatted also. To do this select 'fat reform' from the disk menu and press 'enter' and then 'enter' again at the warning.
irvingsr3 - I'm not sure if resetting the unit is the easiest way to fix your problem. You might be able to perform a redo, or you might be able to just go and start a new song which will reset most of the control settings to their defaults. When you hit 'undo' it may have rolled back some of your input assignments or tracks which were armed for recording and that could explain why you can't seem to record now.
bd.
Jun 23, 2008 | Tascam 2488 Portastudio Multitrack...
Stairmaster 4400CL Stepper Logo
160 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
fordexpert
Craig Butler
Craig Butler
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
