Question about Jet Air Tools & Compressors
Jet JWB-237 Has power, two top 5amp fuses good. Start button on, green light but othing else coming on. Transforme sending ou 33 volts. Both brakes are on for drums. Nothing will start. Is there interlocks on air switches ?
SearsTechToo
  • 261 Answers
SOURCE: Kenmore Elite Oasis Electric Dryer
These are awesome solutions, L1 or the black hot wire supplies the lights and one leg of the heater while L2 the red power wire completes the circuit for the heater and powers the board. A great test is this, if the light is on and the load doesnt go, bad load. In this case trace the L2 line and find where the power stops, the first is the interface and the same goes for Frigidaire. I would also get the part number from Sears, tell them you will wait for money and then look for other local sources, it is worth the wait to save 80 dollars for a back order.
Posted on Sep 13, 2008
Mr BrokRench
  • 1623 Answers
SOURCE: BRAKE LIGHTS AND SHIFT INTERLOCK NOT WORKING
Hello Joe...The Aveo has had it shares of problems, and this is one of them....NHTSA issued several bulletins on the 04 Aveo...this following is the one pertaining to the shift interlock.....
Make : CHEVROLET Model : AVEO Year : 2004
Manufacturer : GENERAL MOTORS CORP.
Service Bulletin Num : 070730007 Date of Bulletin: APR 01, 2007
NHTSA Item Number: 10022265
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
AUTOMATIC TRANSAXLE/TRANSMISSION SHIFT LEVER MAY NOT SHIFT OUT OF PARK (REPLACE BRAKE TRANSAXLE SHIFT INTERLOCK (BTSI) SOLENOID). *KB
Take that bulletin number to your dealer and see if they can help.
Untill you can get it repaired heres a little tip for getting it out of park....There is a a little hole in front of their gearshift lever that can correct the problem, temporarily. It should say "brake interlock release" or something like that. With car running, put a key-size object into it and push down while moving the lever. It does not damage the transmission, it just releases the lock. (make sure your foot is on the brake)
Now for the brake light issue...do you have power at the switch you replaced? If so go to the relay and check there...if no power there it's probably a bad ground.
Also...you may or may not know, but the timing belts on these Aveos are prone to failure at aprox 50k ...these failures have caused severe engine damage.
Good luck...i hope the information i've provided you find useful.
Please time to rate me.
Posted on May 23, 2009
CorvetteKing
  • 108 Answers
SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Posted on Jun 05, 2009
SOURCE: When switched on there is no power at the printer.
www.scribd.com/doc/.../Canon-iP4200-Service-Manual
Please find above, a service manual, for a similar model, however this has the same troubleshooting steps to perform to sort out your problem. If there is NO LED's NO sign of life at all at power On, then probably your PSU, has gone faulty, or you have a fault, bad enough to shut down the PSU. The troubleshooting steps should help you sort your issue.
Posted on Jun 20, 2010
eagle338
  • 4889 Answers
SOURCE: sony kdl-40s4100 no red standby light.When power
Does it make a click sound when powered on?
Posted on Nov 02, 2010
97 chevy truck stuck in park after replacing brake booster
Check to see if your brake light come on when the brake pedal is depressed. If the brake lights do not turn on, check that the brake light switch is connected. More than likely, the switch was disconnected when the booster was replaced and not reconnected.
Other things to check if the brake switch wiring is attached.
Check fuse #16 in the instrument panel fuse panel; it is a 20 amp fuse. If it is good, check the wiring at the brake light switch. The light green wire at the brake light switch should have +12 volts when the ignition is in the run position. If you do not get +12 volt, it may indicate that the neutral safety switch is not functioning. The dark green / white wire at the switch should should be +12 volt with the ignition in the run position when the brake pedal is NOT applied. With the brakes applied, it should be almost ground. If you do not get ground, the shift lock control solenoid may be your problem.
Sep 04, 2012 | 1995-1997 Chevy 1500 Truck Ignition...
Dodge 1500 1995 pickup 7.5 volts to fuel pumpwill not start applied 12 volts pump runs book sayes pcm de-energize booth relayes and will not send proper voltage to fuel pump
There is a red and white wire feeding the fuel pump relay from a 30 amp fuse. Both the shutdown relay and the fuel pump relay are grounded by the PCM, so if the fuel pump relay is grounded it should be "on" and providing a direct link from the pump to that fuse.
You should have battery voltage on that 30 amp wire before the relay and then on the dark green and black wire going to the pump.
If you don't have battery voltage coming from the 30 amp fuse, the problem could be before the fuse.
That 30 amp fuse is hot all the time, so it is powered by a fuseable link coming off the battery.
Jun 24, 2012 | Cars & Trucks
2006 santa fe, rear brake lights will not go on
Check fuse number 14 in the passenger compartment fuse block it should be a 10 amp fuse. If the fuse is good you will need to find the brake switch under the drivers side of the dash. It will be mounted on the brake pedal lever. You may need to remove a trim panel to gain acces to it. There should be 12 volts on the green wire all the time. The green with black wire should have power when the brake pedal is depressed. If there is no power you will need a new brake switch. If there is power than yu will need to pull the taillight assembly and check for power at the socket. If the third brake light is working than you can skip all of the above and start by checking the bulbs. It is still possible for all the bulbs to be burned out so it wouldn't hurt to at least check one of them to see if it is good. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Jan 10, 2012 | Hyundai Santa Fe Cars & Trucks
Tail lights and brake lights are combined. I have tail lights but no brake lights. fuses look good.
No they are different systems going to the same place, the tail lights use one fillament in the bulb and the brake and turn signal use the other, a couple things to check, brake light fuse, brake switch (located on the brake peddle) check for power, I have also run into the 4 way flasher that were the problem, more than likely the brake switch
Apr 14, 2011 | 1997 Chrysler Sebring
No brake lights but fuse is good. Wiring appears okay.
Isnt there a switch on the brake pedal inside under the dash? There should be power going in and out when depressing the brake pedal. If there is a pressure switch, then check it when the brake pedal is up and then depressed. it should have power on one side up, and both when depressed. One thing to keep in mind that I think it goes through the turn signal switch, so if blinkers work, that tells you the wiring is good to the lights, so concentrate on power getting to and out of the turn signal switch.
May 12, 2010 | 1999 Ford Super Duty F 450
Can`t locate the fuse for the Brake switch. Brake light not working as well as 4 ways. Also shifter locked in Park
There are 3 fuses related to the problems you mentioned. fuse #13 20amp for the stop lights/fuse #15 5amp for the generic elec. module/powertrain ctl.
module/anti lock brake module and one you need the
shift interlock. Fuse # 28 10amp for the brk. shift
interlock/day running lights/bu lamp/tlr bu lamp and
4wd shift on the fly solenoid. The fuse block is behind
the panel on the left lower dash. You can check these fuse's first. But also, use a 12v test light to
check for power out of the bl switch on top of the
brake peddle assy. There is a red/lt green wire from
the bl switch into the colum to the shift lock actuator
check for power at this wire with brake peddle pushed
down. If the fuse's are good but no pwr. out of the
switch, replace the switch. Hope this helps.
Mar 22, 2010 | 1999 Ford Super Duty F 450
No reverse lights on 2000 grand am or shift out of park lock
try disconnecting the plug off the reverse light switch (on the transmission) and bridging out the 2 terminals and then see if your revers lights work if they do replace the switch
Oct 01, 2009 | 2005 Pontiac Grand Am
Television Toshiba TZ50V51 power light just blink.nothing else happend Tanks Roger
check f 889 or f 860 .this is a fuse in the power supply this is the location # written on the board (brown side of circuit board-top ,or under the circuit board-green side
this fuse may be open (5amp pico fuse replace with exact one)
Nov 29, 2008 | Televison & Video
No turn signals or side brake lights on 94 chevy suburban
the problen is probably the turn signal switch with a test light check for power at brake switch if no power check for power at turn signal switch the brake lights are incorperated through the turn signal switch
Oct 18, 2008 | 1994 Chevrolet Suburban
Locked gearshift, no brake lights
If you are SURE that the brake light fuse is good? If so, check the brake lamp switch above the brake pedal, see if it is somehow disconnected. Check for power, at both sides of the brake fuse...and, check for poweer coming into and out of the brake switch (when pushing the brake pedal) with a 12 volt testlight. If the brake fuse is good, and you have power coming TO the brake switch, and not out of it, you need to replace the brake light switch.
OTOH, the brake switch just might need a small adjustement, too...If power is at both sides.
Note that the brake light switch ALSO powers/releases the shifter lock solenoid. You cannot take it out of park without pressing on the brake pedal.
Hope this helps you solve your problem.
Oct 07, 2008 | 1994 Toyota Camry
Air Tools & Compressors Logo
108 people viewed this question
Top Jet Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Jet Air Tool and Compressor Expert? Answer questions, earn points and help others
