Question about GE JBP90 Electric Kitchen Range
I have a GE JPB76 electric range. Bake element needs replaced. When I disconnected the old bake element the wires popped back into the stove. I was able to retrieve 2 black and one yellow. Should there be another yellow? When I connect the wires back up do the wires go on top of the element or below to screw them down?
jsrock516
  • 5911 Answers
SOURCE: oven bake element
If you're talking about the wires attached to the BAKE element, normally RED is on the RIGHT and YELLOW is on the LEFT, but it really doesn't matter. Theoretically, this is a resistive heating coil and it will work with the wires connected in either direction. Normally, its fairly easy to determine how these wires reconnect, because the lengths are normally only sufficient enough to connect them one way.
The RED wire connects from the BAKE element to the terminal block, to one side of the BROIL element. The YELLOW wire is connected to one end of the BAKE element and runs to the electronic oven control (EOC) board.
I hope this clarifies this for you.
Posted on Aug 23, 2008
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
SOURCE: Probe and Bake blink alternately.
I had the same problem. I resolved it yesterday. Detailed instructions can be found if you access my inquiry under the user name bhmlton. If you can't find them, then let me know and I'll get them to you another way.
Posted on Sep 23, 2008
MNTECH
  • 1543 Answers
SOURCE: JGBP33 BAKE IGNITOR
You did not post a complete model number, but this should help:
Take racks out of oven. Remove two screws at the very back of the oven bottom. Lift back side of bottom up and back a bit to remove oven floor. Remove flame spreader (one nut at center). ignitor is at the back left of burner, most likely a WB2X9154 (round style) ignitor. The entire burner can be removed rather easily at this point if you remove the two screws at the front and disconnect the ignitor wire (if you wish to have easier access to ignitor mounting screws.)
Posted on Nov 23, 2008
  • 29 Answers
SOURCE: ge range electric oven won't heat up
WHEN BAKE CYCLE IS SELECTED?
Posted on Jan 29, 2009
GE electric range Model: JBP24W084WW
You can order one from Repair Clinic Here is a link to the part and a video on how to change it
http://www.repairclinic.com/PartDetail/Bake-Element/WB44X10016/260870
Oct 08, 2012 | General Electric Stove, Range, Oven GE...
Was baking in oven on a baking stone and inside the oven there was a flash and loud pop (what you would expect if you had metal in a microwave). Is this worth the service charge to see if it can be fixed?...
Was the baking stone resting on the element? It sounds like the element has shorted out and it should have tripped the circuit breaker and/or blown a fuse in the unit. Replacing an element is not difficult and is carried out from the inside and the back if the oven. With the power off, locate which element has blown, it will probably be the bottom one and there should be a hole at the site. Remove the back if the unit, remove the wires from the element, remove any screws that may be holding itin place, ease the element out of any clips that retain it and pull it out through the front, Refitting the new element is the reverse of the removal.
Jan 18, 2011 | Amana AER5712AA Electric Kitchen Range
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Dec 14, 2008 | GE Ovens
Cooking element
You do not list a full model number. Typically a JBP78_____ uses a WB44X10013 bake element. Disconnect power to range. Take out two 1/4 inch hex head screws holding element in at back of oven. Pull element out a few inches into oven. Disconnect wires. Reverse to install. Not too hard if it is an exposed element. A bit more involved on ranges with "hidden" bake elements (which are under the floor of the oven).
Oct 11, 2008 | GE Spectra JBP78 Electric Kitchen Range
Baking element
Aug 29, 2008 | GE JBP90 Electric Kitchen Range
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE JBP90 Electric Kitchen Range Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
