Question about EliteGroup P4M800PRO-M Motherboard
Copy and Paste
Hi , my pc won,t let me paste although it sometimes does let me copy ,however the paste section isn,t highlighted ,thus i can,t paste emails ,etc;can you please advise as it used to let me copy and paste headers ,mails etc but now doesn,t? Thanks in advance ,Mandy
  • Mandz1 Jun 17, 2008
    Hi,thank you for replying however my AVG has scanned and infact i did have a virus problem previously as my windows kept closing down ,and the corrupt file(s) were removed/fixed.I also recently purchased a brand new keyboard and mouse ,therefore this can,t be the problem either?
    I had a pc repair man call out to fix my pc as it wasn,t booting a few weeks ago and he replaced various parts etc and since this ,my copy and paste has ceased to operate? Many thanks again for any advice ,Mandy
    Hi jomama , i tried as you suggested ,but still no joy :( when i go into system icon in the control panel ,there is no copy and paste tab showing? All i can see is Repeat delay -long > short ,then Repeat Rate slow> fast and Cursor blink rate none> fast .
    In the taskbar panel though ,there is a section showing re keep the taskbar on ,view and a tick with lock the toolbars?? If you have any further advice ,i,d be very grateful as even when i go into edit ,view etc ,the copy and paste is not highlighted there and can,t click this either?? Cheers again ,Mandy
  • 87 Answers
A virus will not have anything to do with copy and paste. (i know, i make them) but it will make problems with other things, but since copy and paste is the problem, then the virus is not causing it. what you need to do is go to start>settings>control panel>keyboard. sometimes your problem is caused by a setting in the keyboard area getting turned off by a computer crash, unsafe shutdown, etc. if there is nothing under this category that sticks out to you, then try the "system" icon under the control panel. look for a copy and paste tab and look to see if it is unchecked. if none of this helps, let me know
Posted on Jun 17, 2008
  • 96 Answers
Maybe your computer have some virus, that would interrupt some movements. If it is not the virus, try to replaced your keyboard and also the mouse.
How to Copy and Paste a Link?
Right click on whatever you want to copy. Push copy. If you want the whole page, highlight it, if only a portion, then highlight that. After you push copy, go to where you want to paste it, then right click and push paste. This will put it where you want it.
Oct 18, 2016 | Computers & Internet
How to copy and paste
Hi
Highlight the link and then press CTRL+C put the cursor where you want to paste the link and press CTRL+V this assumes your using a windows PC
Cliff Cook
MCP
Aug 03, 2014 | Computers & Internet
How do I copy and paste?
On a PC to copy and paste, you just need to:
  1. Highlight text
  2. To copy hit "ctrl+c"
  3. To paste hit "ctrl+v"
On Macs:
  1. Highlight text
  2. To copy hit "cmd+c"
  3. To paste hit "cmd+v"
Jul 08, 2014 | Televison & Video
How do you copy paste
If you mean, " How do you copy & paste?" then here is what you do:
Using Mouse
Use your mouse to highlight the text you would like to copy. Right click on the highlighted text and select copy. Go to wherever you will like to paste the copied text and right click on the empty space, also known as the text field, and select "paste"
Using Keyboard
Using the shift button plus the arrow keys you can highlight the text you want. Press the Ctrl button plus the C button to copy (Ctrl + C). Go to the text field where you want to paste and press the Ctrl button and the P button to paste (Ctrl + P).
Jan 05, 2014 | Computers & Internet
Simply highlight the text or item, then you can either press and hold Ctrl + C to copy then Ctrl + V to paste the item in the place you would like to copy it to or highlight item then right click which will give option to copy then right click where you want to paste the item then paste it.
Dec 20, 2013 | Computers & Internet
Cut and paste
Learning how to cut and paste can make your life on the computer much easier.
It saves time and is more accurate that retyping the information, particularly if you do it several times.
If you know how to highlight words on your computer, you can easily copy sections of text and paste them somewhere else.
Open a text document or an email that contains some type.
Click at the end of the block of text you located in Step 1 and drag with your mouse back to the beginning of the text to highlight the entire block of type you wish to copy.
Release the mouse. The selected area should be highlighted in a color, usually blue.
Right-click the mouse on the highlighted text and a drop-down menu appears.
Select "Cut" to copy the highlighted text and remove it from its original position.
Select "Copy" to copy the highlighted text and leave it in its original position.
Paste the text you copied.
Right-click in an editable text box and select "Paste" from the drop-down menu.
The text appears in its new location.
Alternatively, highlight the text and hold down the "Ctrl" key on your keyboard while you press the "X" key to cut the text or the "C" key to copy the text.
These keyboard shortcuts copy the text that is highlighted.
To paste it, click in a text box and use the "Ctrl" and "V" shortcut to paste.
Cut and Paste Techniques in Microsoft Word
http://www.homeandlearn.co.uk/mw/s3p2.html
Aug 25, 2013 | Computers & Internet
How can i copy and paste a link.i am inexperienced.
Whatever it is that you need to copy, just highlight it, right click, and copy. Or just highlight it, and press ctrl. c, this means copy. To paste, same thing, right click where you want to paste, and click paste, or left click where you want to paste and press ctrl. v. This will paste it.
Jun 18, 2013 | Computers & Internet
What is copy and paste,and how do you do it thanks
"Copy and paste" is a phrase that, in the computer world, means copying material from one page to another. Material may include text, images, symbols, files, folders, an entire page, or sometimes even an entire disk. Here's how to do it. -http://www.wikihow.com/Copy-and-Paste
Click the link below, watch the video and learn how to copy and paste.
http://www.youtube.com/watch?v=c66pvfilotA
Apr 16, 2013 | Computers & Internet
Copy paste function does not work
Copy and Paste has to work. Maybe you are doing something wrong.
For example if you copy three rows of excel data then when you get ready to paste it you must select and highlight three rows to paste it.
There are other ways to copy and paste something tool For example highlight what you want to copy then put the mouse pointer on it and do a Right Click and select copy. You can also Right Click Where you want to paste it.
Also you can highlight what you want to copy then Press and Hold the CTRL then hit the letter C key. When you want to paste it you can simply put the mouse where you want it to go, then Press and Hold the CTRL key then hit the letter V key.
Of course there are the way most people know which is to hit File/Edit/Copy at the top of the window or File/Edit/Paste.
Apr 25, 2012 | Computers & Internet
Is there anyway to highlight and cut and paste for email or notes
use your sylus and press and hold at the end of what you want to copy and drag the stylus back to the start of what you wanted to copy. once you have it highlighted, you can press and hold on the screen with the stylus and then there you will see your cut/copy/paste options.
Nov 11, 2009 | HTC Touch Pro2 Smartphone
EliteGroup P4M800PRO-M Motherboard Logo
1,246 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
