Question about Amana ARB2217C Bottom Freezer Refrigerator
Montgomery ward refrigerator freezer side by side model hmg 2164
Freezer bulb out. replaced. still won't turn on. no manual. how do i get the light socket out
  • mzvoss Jun 17, 2008
    the light bulb worked fine elsewhere, just not in the freezer. Is th contact switch on the door frame so the light is switched on and off with the opening of the door. if so, i will try to release it. how do i know if the switch is the problem do i replace it or fix also, how do i remove the socket to check for corrosion and is there a way to get the manual if that would help with repair issues thank you for your time and help
  • 1,036 Answers
Hi there!
Was the bulb blown that you removed?
If not, it may be the contact switch on the door. These usually are just a press fit, sometimes needing a screwdriver in a slot to release it.
Hope this helps you. If it does, Please take a moment to rate your problem fixed with Fixya! Thanks.
Posted on Jun 17, 2008
  • Richard Perkins
    Richard Perkins Jun 17, 2008
    With the new / working bulb in there, Push repeatedly on the door switch. You should be able to hear it clicking each time.
    Sometimes this switch is near the top, others on the hinge side, maybe part of the lamp assembly if this moves.
    Wires may be broken behind this.
  • Richard Perkins
    Richard Perkins Jun 21, 2008
    I've had a look at the users manual, and there is nothing beyond replacing light bulb. Which you know already.
    Look for the switch lever on the hinge side. I'm certain the problem relates to this.
Is there a manual for a Montgomery Ward compact mini freezer with this model license # 8113.07 and serial # 54020? SL?
This information is usually readily available direct from the MANUFACTURER and/or ON-LINE. If you don't have access to a computer just see your local store or give the manufacture a quick call ...
  1. Montgomery Ward Refrigerator Support ' > ... > Refrigerator Support
    Montgomery ward refrigerator product support information from Find montgomery ward refrigerator user manuals, instructions, and free ...
Sep 20, 2014 | Refrigerators
Montgomery ward side by side HMG 229637B ... defrost timer does not cycle ... have relaced defrost timer .. STILL DOES NOT cycle ...if i manually cycle coils heat ... defrost etc etc BUT refridgerator does...
turn the allen screws one is under the hindge side of freezer door and one is under fridge hindge side of door turn counter clockwise be carefull turn to far the adjustment screw will come out of the wheel adjustment bracket.also try having someone tilt refrigator back by pushing top of refrigator then turning the two white adjustment screws in same area of allen screw this adjust the front of the refrigator you may want to adjust the front adjustment so the refrigator is slightly tilted to the back this will help close the doors.
Jan 22, 2014 | Montgomery Ward Refrigerators
Water collecting in bottom of refrigerator side under meat keeper. Wards model no. HMG 2290
Check to see if your ice maker is not leaking water. Otherwise, the problem might be a clogged drain in the freezer. Need to remove the back cover in the freezer to check that the drain is clear. If it is clogged, try removing any blockage that you see and push wire down the drain tube to clear any blockage in the tube.
Oct 04, 2010 | Montgomery Ward Refrigerators
A manual for a montgomery ward compact freezer
I doubt it since montgomery ward was bought out by maytag a long time ago, and now maytag got bought out by whirlpool.
Are you having a problem with your freezer? the manual wont tell you anything about troubleshooting
Mar 24, 2010 | Freezers
Model HMG 21674 About how old is this model, trying to decide to repair or buy new! Thanks.
with out knowing the producton number i am showing this model to have a twelve year run
10 years is the expected life of most units now adays, so even if you were at the end of production
your pushing 10 years now
i would just buy new,,,, fixing one problem could only open a very exepensive can of worms
Oct 27, 2009 | Refrigerators
My Ward, HMG - 1400 - 0, refridgerator coils will ice over
Make and model numbers are important to give answers.
Jun 19, 2009 | Montgomery Ward Refrigerators
Amana ARB2217C Bottom Freezer Refrigerator Logo
498 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
