Question about McCulloch Garden
Need to know how to change chain on a 14inch McCulloch Eager ****** gas chain saw
    Brigadier General:
  • 4,088 Answers
Turn the chain adjusting screw CCW a turn or two, release the chain brake, and remove the large nut on the right side cover. The bar and chain will come off after removing the cover. (note: a 16" bar and chain will fit the saw which makes it a little more useful if cutting trees) Be sure to clean the small oil passages in the drive end of the bar that run from the large holes out to the chain groove on each edge. It is common to flip the bar over to equalize chain groove wear. Also, if the outer corners of the bar edges have wear that causes the metal to flare outward, use a file to cut off those sharp edges (at about 45 degrees) so that it doesn't project beyond the bar's flat surfaces. This will help prevent a cut from wandering off to one side. Re-assemble in reverse order after cleaning the engine and cover. You may have to turn the chain adjust screw some more to compensate for the old chain which will stretch with use. Make sure the adjustment 'tang' falls into one of the large holes in the bar before tightening the cover nut down. Hope this helps!
Posted on Nov 10, 2010
Can I buy a clutch for this chainsaw
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw ...
www.fixya.com/search/...mcculloch_mcc1514...15...electric/clutch_nut
McCulloch MCC1514 14Inch 15 HP Electric Chain Saw, clutch nut related issues. Get free help, solutions & advice from top McCulloch experts.
Jul 28, 2015 | McCulloch 14" Electric Chain Saw Mcc1514
What is the fuel/oil mix for a mcculloch 14inch chainsaw 2.0 cib?
If you use newer synthetic oil it covers a broad range of fuel/oil ratios with one mix. it will allow you to use one fuel mix for all your 2cycle equipment
Aug 22, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
What is gas/0il mixture for mcculloch 2.1ci eager ****** model 60013203
Good quaility two stroke oil designed for chainsaws ( not out boards ) and designed to run at 50-1
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I trying to find a bar & chain for a Mcculloch eager ****** saw. Only model numbers I find are 60012416or 12-052701. Saw had 16" bar which has broken.Was using Oragon S54 chain.
Here is a good website for finding bar and chains from the Oregon website.After you get the part # you want you can always purchase from other source.
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Hope this helps.
Feb 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Mcculloch eager ****** 2318av what fuel mix does it use
chain saws are 40:1
3.2 ounces 2-cycle oil per gallon gasoline
Oct 25, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Where do I find a replacement chain for my McCulloch Eager ****** 2318av chain saw (model # 600038-12)?
Your friendly neighborhood chainsaw shop can fabricate one in about 5 minutes. Take your existing chain for use as pattern.
McCulloch.com
http://www.ordertree.com/modelinfo/MCC/11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318/139.11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318.1.59.1.html
If original 18" bar.
part number(pn) MCC 21927533
Oregon Bar & Chain Selector (again original 18" bar)
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your saw with 18" bar returns
Oregon pn 91VG060G.
This can be easily crossed to other manufacturers chain. You might consider a more aggressive chain (dependent on your level of expertise). HTH
Lou
Jan 20, 2010 | McCulloch Garden
Garden Logo
71 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
