Question about Casio Computers & Internet
One of the speakers is making a static noise when I turn on the organ . Model #CTK-900 . Thanks Heather
  • 91 Answers
It sounds like the organ and the computer's speakers power source is on the same circuit. I would suggest purchasing a outlet strip that has noise reduction/surge protection, and plugging the speakers power source into it.
Posted on Nov 10, 2010
How to fix speaker in Sylvania projection clock radio SA 85018 2
if it is too loud it will make static and make a weird noise in the speaker my arlarm clock(very old) does that but when i turn it down it stops the static and the noise.
May 03, 2016 | Sylvania Audio Players & Recorders
Loud speaker static when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to get it to stop. Any ideas?
I GUESS that the speakers are driven by an after market amplifier. An amplifier needs to be connected to a power source that is only on when the radio is on, through a relay.
So I GUESS that:
  1. The wiring is incorrect. Or
  2. If is has a relay, the relay is stuck.
Feb 01, 2015 | Cars & Trucks
Loud speaker static from 2002 Mitsubishi Eclipse when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to g
The fuse might be built into the cable to the lighterand/or radio. It's called "fusable link", this type of fuse looks like a cable. Or another type of fusable link might be in the fuse box under the hood near the firewall.
Feb 01, 2015 | 2002 Mitsubishi Eclipse
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
Casio CTK-651 keyboard wont switch on
An internal fuse is UNLIKELY.
More likely is either a bad connection/connector at power input or a bad or intermittent power switch.
Jun 24, 2010 | Casio Music
Baldwin Model 230 DE when turned on makes a loud thunk like the volume is turned way up, then when you disturb or shake the organ or stomp on the floor it makes a loud noise like if you twanged a coil...
If the organ has a reverb spring "tank" in it, that is likely where the spring sound comes from.
The initial noise is likely due to the initial unbalance of the power audio amp.
Lesser organs don't disconnect the speakers till the amps attain balance so the inrush pulses the speakers..
Mar 10, 2010 | Michael Kelly Music
Getiing static noise through my logitech speakers when power on and volumn turned off,they sound perfect when using but to get rid of the noise i have to turn off
Hi , just make double sure all the plugs from the Speakers are plugged in correctly , and none of them are touching your Case , as that does cause that noise aswell.
Thanks
Dec 29, 2009 | Audio Players & Recorders
Lowrey catillion organ with loud static noise
Try posting on the organforum.com.
It sounds like the power amp has a problem. Probably filter capacitors have gone bad.
Oct 24, 2009 | Music
Looking for a schematic of the Casio ctk-700 to
The keyboard is LIKELY scanned as a matrix.
You have two problems:
The contacts in the Thomas will have to be totally disconnected rendering use of any of the Thomas organ unlikely.
The second problem is that the keyboard LIKELY has velocity sensing. This means TWO contacts must be used PER note. One contact "makes" first and "breaks" last. This is used for velocity sensing on synths. The Thomas foot pedals likely only have a single contact per pedal, and even if they had two, it is unlikely they sequentially close..
The matrix scanning is accomplished by sensing the connection of two crossing points on a matrix of circuit lines. USUALLY each of 12 wires tie to all of one note across the board. Then two other lines for each octave "strobe" the first make contact and then the second of those strobes the second make contact. There are two of these strobe lines for EACH octave on the board.
Remember that these lines scan at digital logic speeds so wire length and NOISE/STAIC DISCHGARGE PROTECTION is a must.
Aug 22, 2009 | Casio Music
Static noise from car stereo
change youre speakers they are blown if they are making staticy sounds i have recently chnged my speaker cuz of the static and it was kuz they were blown
thats all i can think about
hope it works
Oct 28, 2008 | iLO XM-MP3-CD Car Stereo
Computers & Internet Logo
201 people viewed this question
Top Casio Computers & Internet Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
