Question about Frigidaire FRS266ZDSB Side by Side Refrigerator
Part and Installation
I did a search and I think the part is called a Control-Temperature part#240383703. Is this correct? Also to replace this do you just remove the panel where the dial is also where the water filter system is on top?
Hopefully it is not to complicated.
Thanks
    Scholar:
  • 149 Answers
Yes it's a thermostat. inside the refrigerator theres where you should see the dial. carefully pull out the dial and there should be a cover with about two phillips screws take them out. (for this part please disconnect the fridge from your power supply) when you lower the top you will see the control and the copper coil (be careful because if you break the copper coil on the control it will not work at all!!) just disconnect the wires from the old control there's 2 or 3 (if there's a green one. the old control is like snapped in a compartment you mange to get it out with some patience. connect the wires to the new control and put the sensing bulb from the new control in it's place . it's not that complicated just e-mail me @ hvac.tech7872pr@gmail.com for any questions
Posted on Jun 17, 2008
  • Alexander  Figueroa
    Alexander Figueroa Jun 17, 2008
    here's a pdf so you can see how it goes look an page 10 it shows the part and where it goes
    ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/5995446597.pdf
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Install cold control FRS6R5ESBS
easy remove power and then unscrew the control part from fridge and unplug the prongs and take note of where they connect to so u can replace later correctly
Mar 12, 2015 | Frigidaire Refrigerator Cold Control -...
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
Electrolux dryer will not start code E-63 appears on the screen
Hi boltonjamese...
E63 error code means that your dryer thinks the temperature is too hot.
If your unit is still under warranty they should fix it under warranty so I would highly recommend calling warranty to correct this issue as any problem to fix this will involve replacing a sensor or a control board.
Please take time to rate me
Sep 24, 2011 | Electrolux Dryers
What doe error code E63 refer to? thanks
"E63" error code means that your dryer thinks the temperature is too hot. Most of these units should still be under warranty so I would highly recommend calling warranty to correct this issue as any problem to fix this will involve replacing a sensor or a control board which involves high risky things to be done. So its safe to reach the company service technician to fix this issue.
Thank you!!
Jun 01, 2010 | Electrolux EIED55I Dryer
Refrigerator freezes food regardless of dial setting. Control board?
Thank you. The part number you need is 240383703 at $146.18 thru Sears and is the control for the refrigerator not the freezer. The refrigerator control operates the opening and closing of the damper door which lets air pass from the freezer to the fresh food. The control is keeping the door open longer than it should. Hope this helps. Worth the repair and has been one of the most common problems with this model.
Feb 04, 2010 | Kenmore 52642 / 52644 / 52649 Side by Side...
The oven warms up and then starts beeping and flashes f10 err.
The "F10" oven error code means "Runaway temperature".
If you have technical skills, you can try to diagnose and repair yourself, otherwise, call a qualified appliance repairman.
Locate the temperature probe wire plug at the Electronic Oven Control (EOC) and measure its resistance. It’s supposed to be about 1100 Ohms at the room temperature.
If the reading is wrong, replace the oven temperature probe.
If the reading is correct, replace the EOC.
Jan 28, 2010 | Kenmore Ovens
F3 f4 f8 on a ge modeljtp15wdw2ww
GE Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC). F8 Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. F9 Lock switch Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. FC Problem with door lock circuit such as pinched wires between control and door lock switches on motorized lock circuits Check wiring and test operation of switches. FD Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. Replace probe if all else checks out ok. FF Loss of door motor safety switch Replace the oven control (also called clock or ERC). FFF Control error, failed EEPROM Replace the oven control board (also called clock or ERC).
The main control operates a series of software commands, which control the various features and functions of the oven. Each function or operation has a numerical value assigned to it. The numerical values can be added up - this is called the check sum operation. Every time the system is powered up and after each clean cycle the system performs a check sum and compares the value to the value programmed into the software (stored in memory).
An EEPROM check sum error or FFF code occurs when the values differ. If this happens, replace the oven control board (also called clock or ERC).Here is a list of error codes and corrective action that should be taken. Mike
Nov 23, 2009 | GE JTP15 Electric Single Oven
My oven keeps beeping F2 and it won't turn off. The top broiler coils are bright red and heat is pouring out of the oven. I have held down the off button, pushed start, pushed bake, anything I can think...
Control senses oven temperature above 615F-630F. shut down the breaker switch asap.
Jul 08, 2009 | GE JGRP17 Gas Single Oven
Whirlpool AWG338 - Missing temperature control knob
whirlpoolpartssurplus.com call me and i can ship one out
Jun 24, 2009 | Whirlpool AWG329 Front Load Washer/Dryer
Frigidaire FRS266ZDSB Side by Side Refrigerator Logo
165 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
