Question about Bosch Dishwashers
I recently bought a table top model SKS 40e02GB/01 Type SE5P18 and have no complaints about its washing action but find the basket very difficult indeed. The prongs do not allow normal household china etc to be fitted. Also the cutlery basket does not fit anywhere without wobbling. the last model I had had a very efficient basket -why the change? Very disappointing. Any solution?
2 Suggested Answers
  • 360 Answers
SOURCE: new cutlery basket for D3100
Here is a source for your basket click here
Hope this helps.
Please take the time to rate this solution
Posted on Jan 31, 2009
My sks wont cycle
SKS for home defense is not a good idea unless your nearest neighbor is a couple miles thru the woods and down in a valley.
I'd do a really good cleaning and lube. There may be some cosmoline still in some of the parts.
12gauges make a much better home defense. #4 buck is nice. Twenty or so pellets the size of a .22.
Two-legged predators run just hearing the action cycle on a pump 12ga.
Oct 05, 2017 | Optics
WHat is the capacity of the Whirlpool LLR9245BQ1 top load washer?
Hello there
  • Washer Type: Washer
  • Load Type: Top Load
  • Volume Capacity: 3.2 cu/ ft
is one of the better, super-sized porcelain-on-steel wash basket, combined with the Xtra roll action plus agitator, which ensures that your really big loads get really clean! The dual action of the Xtra Roll Action Plus agitator rolls even huge loads to the bottom of the wash basket where cleaning takes place. It can effectively roll over and clean twice the average size load! Plus, wash fewer loads to save time, money and energy! Ultimate Care washers offer both five and six speed combinations providing flexibility for the future in fabric care. Plus, the easy-to- use consoles makes it simple to select the desired wash/spin speed combination. And the enhanced agitator vanes ensure clothes roll over for consistent cleaning -
Jan 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaks under the washing machine Kenmore top loadin washer, model 110-234642300
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to remove the cabinet and gain access to the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?
newsPath=16&newsdesk_id=134&osCsid=b547cd9bb24b4ffaef51e860554a9cb0
Check the areas for the motor and pump and the Agitator Basket and Tub.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Jan 11, 2010 | Kenmore Washing Machines
I have a kenmore 80 series topload washer. It washes the clothes just fine fills and drains just fine, but it has a leak. I looked under the machine and found nothing wet. Checked all the lines still...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Nov 04, 2009 | Kenmore 24032\24036 Top Load Washer
70 Series Kenmore washer pouring water underneath washer.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the areas for the motor and pump and the Agitator Basket and Tub .
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Will not spin, therefore will not drain
Hey Joe,
Let’s check to see if the wash basket will rotate CCW in Spin Only Cycle with no clothes in the wash basket
1. Open the lid and rotate the wash basket by hand Counter Clockwise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clockwise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 3. (See page 33 of the Service Manual for putty knife insertion point).
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it should begin to rotate CCW does it?. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction. If the basket does spin CCW and the tumblers are rotating then you have a broken clutch spring. Let do those checks and observations and see what the next troubleshooting steps will be. Rich
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The neptune TL model 6800AWW makes a terrible noise at what seems to be the end of the wash cycle. Is this a rebalance? Because it sounds like metal against metal. Or could this be a belt issue. The...
Hello acelmo3,
Thank you for the model number, can you give me the first two digits of your serial number. That number is located on the back right side of the console. I only need the first two digits.10, 12, 16,,,etc.
Let's try to troubleshoot the grinding noise issue, You mention the spin cycle. Have you taken any dc or UC errors in spin cycle? Can you try the following and let me know what you find?
1. Open the lid and rotate tie wash basket by hand Counter Clock Wise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clock Wise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 2. (See page 33 of the Service Manual for putty knife insertion point). Also see pic attached.
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it will begin to rotate CCW. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction and the Spin Cycle will fail with dc/UC errors. If this is not the situation move on to step 3. This is what I refer to as a soft failure and possible clean up of the clutch roller bearings in the clutch hub may restore normal clutch operation. A hard failure would be the clutch spring has failed, the roller bearings are rusted beyond clean up. A replacement clutch is required.
Pic attached for top cover removal .
Let me know if you see the tumblers rotating in Spin Only cycle and if yo hear the grinding noise. Rich
Mar 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore frontload clothes washer (Canadaian Model #970-C42062-00) bearing in the back is making noise and leaking - please recomend how to remove the rear bearing and replace it
Wow! Mine also looks just like this - a large hole in the back of the spin basket. Same timing too - about 59 months for me.  All of a sudden, during the spin cycle we heard a huge bang,...and then the banging continued. There is no way I'm spending $200 + labor to get his fixed. If the part is only going to last 5 years, then I may as well go ahead and get a new washer....and it definitely won't be this make or model!
Jul 18, 2008 | Washing Machines
Ge harmony top load model wpgt9350copl washing machine
This is a very complicated machine utilizing no transmission, rotor/stator type drive motor, and a locking/unlocking clutch mechanism design to either engage or disengage the wash basket. These machines are tricky even for professionals to properly diagnose.
Jan 19, 2008 | Washing Machines
Washer basket has dropped 1.5"
Different models use different devices to "suspend" the tub. Please verify the exact make / model.
Dec 31, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwashers Logo
24 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
