While trying to format my notebook and installing a fresh copy of windows vista i am encountering this error: I cant see my storage drives. Why this is happening? Thank you in advance.
    Problem Solver:
  • 11 Answers
More than likely you will need sata drivers for the hdd from the manufacturers website. Load them on a USB stick and during setup, it will ask you if you need to load additional drivers, then have it load up the drivers for the sata hdd off of your usb stick.
Best of luck
Kevin
Posted on Nov 10, 2010
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
How can i reformat my windows vista
If you have the windows install disc, you can insert it, restart your computer and press any key when it tells you to. This will boot from the DVD and enter the Windows Setup. From there, it will show you a list of partitions on your hard drive before you install windows. Choose the partition on which Vista is installed and click "Delete" under advanced options. The partition will be formatted. If you want to install a fresh copy of Windows Vista, you can do so now. If not, exit windows setup and install whatever OS you want to use.
(Make sure you BACK UP your files before formatting - once you format the partition, you can NEVER get the files back.)
Aug 07, 2011 | HP Compaq Presario v3000z Notebook
DVD Write error in Dell Inspiron 1525
This issue may can be of Nero means product of DVD wrighter, Now you should uninstall the nero from Add or Remove programe also remove from registry and again install Nero after completing this process you should try for wrighting DVD.
I hope that this has been very helpful for you
Dec 12, 2009 | Dell Inspiron 1525 Laptop
Installation for xp problem
all the hardware on the laptop is most likely configured for windows vista meaning it will not allow xp to load up because your hardware cant run it
Oct 09, 2009 | Compaq Presario Notebook
Activation error
The problem is Vista see's your second format as a second partition on the hard drive. It never gave you a clean format, and just internally added another partition. I solved the problem by formatting with a copy of XP and just stopping the process after the format was completed. Partition Magic works just as good to give you a clean format. Because you should format first with your older copy of windows, if you have more than one partition is the reason for the error. Vista see's your first copy as the older copy and just gives you a second partition.
Being actually in the second partition is why you get the error when you try to activate the actually second copy too. It actually trying to activate your copy but, the copy of the activated copy (your first copy), is still activated and is still on your hard drive and working.
The two NTSC formats for Xp and Vista are not the same, and is really why this error happens.
Oct 06, 2009 | Microsoft Windows Vista Ultimate Edition
Vista installation givs error
hi..the problems has your encounter is came from the installer are not reading properly the player...u need to clean a DVD/CD player or try to use a good Copy of windows u need to install..Thanks and Good Luck..^_^
May 19, 2009 | Dell Vostro A860 Notebook
I downloaded a copy of windows vista and it expired,im trying to reinstall my hp windows xp recovery cd and its asking me for a password,cant remember if i ever did set up a password for this pc.how can...
At what point is it asking for a password? Has the computer formatted the hard drive yet? It sounds like you might be going in to Recovery Console instead of installing a fresh copy of Windows.
What you want to do is press Enter at the first screen, agree to the license, and then format your hard drive. After that, it will go through the installation without asking for a password. Remember - you'll lose all your data when you format.
Jan 23, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Imation atom usb driver vista
vista has this problem , see below webite
Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
http://support.microsoft.com/kb/940199/en-us
Jun 06, 2008 | Electronics - Others
About creating setup disk
no you cannot create an instillation from an installed copy of vista, altough the necessary files are there the is a lot more to the instilliation process than what is on your harddrive.. what you ned to do is uinstall fresh of the windows vista instilliation disc. if you dont have the disc i hope you got your srial... or you can download one using a torrent client such as utorrent and from this web site as the torrent
www.torrentspy.com.
Jan 06, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
